Sony KDL-46HX850 Can't upgrade/update firmware
  • dkneyle
    • Dec 2013
    • 446
    • Electronics, Gardening
    Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
    Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about 5 seconds, but it goes no further. Are there any clever suggestions for what I need to do?
    I downloaded the software, which supposedly is the most recent version from here: https://drivers.softpedia.com/get/TV...re-2-120.shtml
    Of course, Sony is no help. "We no longer support that model. It is an old TV." It is only 12 years old, in wonderful condition, and it now has operational hardware - the only thing missing is Sony's firmware inside it! Sony simply refuses to enter into any sort of discussion about the TV. SHAME SHAME SHAME
  • Diah
    • Feb 2013
    • 6655
    what you did correct... but USB should no more than 4GB formatted FAT32 MBR Mode --- only leave the TV in this state over 40 minutes while yellow green flashing.. later you screen will light up
    • dkneyle
      • Dec 2013
      • 446
      Why do you say MBR Mode? I've formatted as FAT32 and FAT16; still can't get the firmware to load.
      • dkneyle
        • Dec 2013
        • 446
        Firmware refuses to load up. I communicated with the guy that sold me the mainboard. Bear in mind, the TV is 46 inch, the board came from a 55 inch TV. But they are use same mainboard. Seller says the TCON has a firmware in it as well, which knows the mainboard is not correct for size of TV, hence why it wants the firmware upgraded. Given the mainboard had failed, I'm wondering if the T-Con was also damaged and might be preventing the firmware upgrade?
        I've not had any experience with this nonsense of Smart TVs and the need for firmware upgrades. Anyone want to offer their thoughts on what might be going on here?
        By the way, I've followed all the procedures for firmware upgrade. The USB memory chip flashes for a few seconds, so it seems it is being read. But it goes no further.
        • weisian
          VSX-1021 - Update Error 1, DSP replaced, potentially need working firmware dump
          by weisian
          I have a VSX-1021 that dropped the UE22 error on me and is no longer was working. I've then done the following:
          1. Tried updating the firmware with a firmware I found online but it hangs at 20% and ultimately shows "Update Error 1". I didn't check prior to attempting the firmware upgrade but the firmware after shows "***" for the DSP numbers. This was before I looked online that pushing an update through with a bad DSP chip could corrupt the firmware.
          2. Tried reflowing the original DSP chip (D810K013BZKB4000) but firmware version remains "***"...
          03-12-2026, 05:54 AM
        • Boardview and Schematic Bot
          How To Check BIOS / EC firmware version for MSI notebook & Update it
          Not sure how up to date this is....
          How To Check BIOS/EC firmware version for MSI notebook?
          Please check BIOS/EC version by [Help Desk] or [BIOS Setup Utility]
          1. How to check BIOS/EC version by Help Desk?
          1.1. Open MSI Help Desk.
          Note: Help Desk is a built-in application for MSI notebooks. If you couldn’t find this software in your Windows system, please download and install MSI Help Desk from product.
          1.2. Click the [System Info].
          1.3. BIOS and EC firmware version will display on screen.
          03-27-2026, 01:12 PM
        • Diah
          needed Sony firmware PKG3.008EUA for any of this Model
          by Diah
          any one had Copy of this firmware PKG3.008EUA , its last Firmware and deleted from Sony Server support page. doesn't matter which region , it can be used for several Model .
          i did find old Version, but need this one to solve Smart function of this Sony TV which never had in its working life internet confection. the resent Version as in attached Photo
          Model share this Firmware are :
          KD-49X8505B, KD-55X8505B, KD-55X9005B, KD-65S9005B, KD-65X8505B, KD-65X9005B, KD-65X9505B, KD-70X8505B, KD-75S9005B, KD-79X9005B, KD-85X9505B, KDL-32W705B, KDL-32W705C, KDL-32W706B, KDL-40W605B,...
          02-11-2026, 04:21 PM
        • madyoyo
          Sony KDL60w685a need firmware update
          by madyoyo
          Hello everyone.
          I replaced the mainboard on a KDL60w685a, and now it blinks green and yellow. I think i need to update the firmware. But it's not available from Sony website.
          Does anyone have the firmware for this TV?
          01-06-2023, 01:41 PM
        • thesteve
          Sony experts? 2nd bricked BAT Board after firmware update KDL-55EX720
          by thesteve
          So I bought another main board from eBay and the same thing happened.
          I got the firmware file from the Sony website. My model was listed and everything matched.
          sony_tvupdate_2011_4027_aaa_auth.zip was the file.
          Extracted to a folder: "sony_dtv0FA10A01A0A1_00000301"
          with file: 00000301_07e8046a.bin inside.
          Loaded it into the root of an otherwise empty USB thumbnail bought from around the same time as the TV. Not too old, not too new.. under 2Gig.
          The file reads perfectly. Lots of "disk activity"...
          07-17-2021, 04:59 PM
