Re: the gutless, bloated, and fried power supply hall of shame
I will change those caps too as soon as the electronics store here opens again, they provide genuine Pannies. (in 2 weeks time or so) Unfortunately i only had the 3 panasonic caps laying here, all the other swapped caps come from used units. Since this unit got a 2012 date code and was unused, i took the gamble that the 5vsb caps will hold up for now. The 2200uf teapo / 1000uf chengx caps didn't fit in the 5vsb spot unfortunately.
It can be done. But to be honest, this psu is going to be used in a modern system, and -5v was only really needed for isa and old pci cards. Oh, and the ocz rambooster also liked to have a -5v rail. Because the psu already is quite compactly packed, adding components that won't be used does not make that much sense. If i was going to use it for older hardware i would certainly add the circuitly for better compatibility.
I was quite impressed by the stability of the power supply. During the load test it ran a little on the hot side, but not too hot. Inductors, transformers and way overspecced rectifiers usually run perfectly fine at these higher temperatures. It probably classifies as a good 250w unit with 12v heavy systems or as a 300w unit when the 5v rail is also loaded a bit more heavily.
The pcb traces are fairily short because of the small pcb, filling the main power traces on the secondary side with solder tin also helped a bit i think. This helps the voltage regulation too.
