12V 10A CCTV camera system power supply pulsating
  • harp
    • Jun 2022
    • 592
    • Planet Earth
    #161
    Re: 12V 10A CCTV camera system power supply pulsating
    Is this one from attach?
    Please write the reading you get on each coil, say 3 red, 1 yellow...
    So, it is 3 coil
    Primary main
    Primary aux
    Secondary out
    What is resistance of each coil, and value of ring tester, and if you have transistor tester for inductance...
    Suspicious is primary main coil...
    Secondary output coil may have only few turns and appear in short?
    • rddube
      Aspiring Expert
      • Jun 2013
      • 908
      So, it is 3 coil
      Primary main
      Primary aux
      Secondary out
      Yes that is the blue ring tester I have. Attached are photos of the primary and secondary side of my transformer. Can you pinpoint where I should measure?
      • harp
        • Jun 2022
        • 592
        • Planet Earth
        #163
        First make a schematic of transformer windings on paper, using multimetar determine each coil and confirm no continuity to others coil, neither primary or secodary coils. On that schematic add note of all measurement you done.
        On pcb the secondary is all connected, but it seems there is a separate 2 coils. If one of coils is defect, and parallel connected to good one, nothing gona work.
        And get rid of all this solder balls around pins!
        I thing that on secondary is two coils, but check.
        On primary main coil is probably center tap, and it should be on half resistance from each side. I see suspicious markings on center tap pin, just like sparking...?
        • R_J
          • 9518
          The secondary side likely has 3 separate windings to supply the higher current (10a)
          The primary side has the feedback winding (blue) and the main primary winding which likely has a thermal fuse, the middle pin is where one end of the thermal fuse is connected.
          The primary fuse is likely between A & B or B & C The primary winding will be between the other pins
          • CapLeaker
            Leaking Member
            • 8002
            I agree with RJ. That’s how I see the transformer construction too. Showing a short with the ring tester on the primary winding, it’s game over.
            It does make sense, since everything else on the board has been triple and quadruple checked in wich ever what way, plus the primary had blown components.
            • rddube
              Aspiring Expert
              • Jun 2013
              • 908
              Well, not very good news as one of the primary windings shows a tremendous short!
              When measuring with ohmmeter, the shorted winding gives me .1 ohm, but then the good windings also give me .1 ohms.
              So I guess we're toast?
                master hoarder
                • May 2008
                • 12164
                • Bulgaria
                #167
                Maybe (likely?).
                The best way to find out is to open/break the transformer and see for yourself.
                But before doing that, there is STILL a way to test if the rest of this PSU is working: get another 12V power adapter and take the transformer from that. The donor adapter doesn't need to be rated for 12V and 10A - any switch-mode adapter will do, even one rated for just 1 Amp. The only thing to look for is an adapter that has a transformer with main and aux. windings on the primary and single output winding on the secondary. And the adapter has to be the same topology - discontinuous (flyback), which is what basically over 99.9% of small adapters use. So it should be pretty easy to find one. Once you do, just match the pins of the windings of the new transformer and that's it. (Hint: you don't need to solder the donor transformer to the PSU board - just use wires to connect the pins to the right spots. Old transformer needs to be removed for this to work, of course.)
                Now, there is a small chance the aux. winding from the donor transformer may be too low in voltage and not able to power the primary-side IC... but hey, still worth a quick test if you have some junk adapters around.
                DO use an incandescent "dim bulb tester" when testing the PSU with the "new" transformer, just in case. Dim bulb tester:
                https://www.badcaps.net/forum/showpo...4&postcount=70
                If the PSU does happen to work with the donor transformer, then you know yours is bust for sure... in which case, rewind it for a challenge?
                Yes, failed transformers are rare, but they can happen. A blowout on the primary can cause that sometimes, and it usually is the main winding on the primary that bites the dust. The secondary is wound with thick wire and can dissipate a lot of heat, even when fully stressed.
                You've come this far, so why not take it a notch further.
                • lotas
                  • Jan 2016
                  • 4475
                  • Russia
                  #168
                  This short-circuited turns meter measures only the primary (power) winding, it will not show on all other (secondary) windings.
                    • 30941
                    if your using a ringer, shorted secondary's usually supress the field in the primary and show up anyway.
                    • rddube
                      Aspiring Expert
                      • Jun 2013
                      • 908
                      Lotas you're right, Momaka gave me an idea and I pulled 2 other transformers from scap boards with pretty much the same winding configuration on the primary side, and both show the exact same results. So in the end, I think my transformer is good, the problem is elsewhere, but where??
                      • petehall347
                        • Jan 2015
                        • 4423
                        • United Kingdom
                        #171
                        did you check the switching frequency when testing it when it was all together ?
                        • rddube
                          Aspiring Expert
                          • Jun 2013
                          • 908
                          Not sure how to do that?
                          • CapLeaker
                            Leaking Member
                            • 8002
                            The secondary windings should measure close to a short less wire and thicker. The primary winding should show somewhat of a resistance since it has the longest wire. Look up at how a switching transformer is constructed. There are quite a few variables like wire length, thickness and coating thickness. When a primary measuring the same at 0.1 ohm like a secondary, I smell fish.
                            I do have another idea. Measure the inductance of the primary and secondary if you can.
                            • petehall347
                              • Jan 2015
                              • 4423
                              • United Kingdom
                              #174
                              basically the fet should be switching on and off somewhere over 10khz . this being controlled by the ic .
                              • rddube
                                Aspiring Expert
                                • Jun 2013
                                • 908
                                Ok, the primary being the one on the right in the photo (I think) measures 465 uH and the secondary measures 17.03 uH. When I measure another transforer I have with same configuration, I get 474 uH on the primary and 17.03uH on the secondary. Not sure what that means however?
                                • rddube
                                  Aspiring Expert
                                  • Jun 2013
                                  • 908
                                  Ok, thanks Petehall347, but how do I measure that?
                                  • petehall347
                                    • Jan 2015
                                    • 4423
                                    • United Kingdom
                                    #177
                                    with the frequency function on your meter if it has it .
                                    • CapLeaker
                                      Leaking Member
                                      • 8002
                                      Ok. So this is what I would expect. The primary winding is good then. The auxiliary winding would show a short as the wire length is much shorter than the primary one. The secondary probably shows a short too, since the wire length is also short and a thicker wire is used. Plus you actually measured 3 windings at the same time.
                                      More uH means more inductance, which also means more wire turns.
                                      • rddube
                                        Aspiring Expert
                                        • Jun 2013
                                        • 908
                                        Yes it has the frequency function, but how do I set this up? I need to resolder the transformer and put the frequency meter on the chip pins? What is the FET ?
                                        • CapLeaker
                                          Leaking Member
                                          • 8002
                                          First see how high of frequency your DMM can measure.
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                            by sam_sam_sam
                                            07-01-2024, 06:34 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
                                          • madan1
                                            555 based power supply getting too hot
                                            by madan1
                                            Good day.
                                            I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
                                            The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
                                            After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
                                            When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar...
                                            06-23-2025, 04:38 PM
