12V 10A CCTV camera system power supply pulsating
  • petehall347
    • Jan 2015
    • 4440
    #121
    Re: 12V 10A CCTV camera system power supply pulsating
    i take it the supply voltage is stable at the main cap ? think this mentioned so ..
    pin 6 you missed for some reason ..
    • rddube
      Aspiring Expert
      • Jun 2013
      • 954
      post a nice list of present voltages at the ic to compare with what they should be .. lets see if its doing what it is told or if doing as intended with this fault condition .
      So here we go, everything reinstalled factory:
      Pin 1 - Gnd - 0V
      Pin 2 - .1V - .393V jumping around erratically
      Pin 3 - 15V to 20.6V jumping around erratically
      Pin 4 - 0V
      Pin 5 - .1V to .249V jumping around erratically
      Pin 6 - 0V
      Pin 7 - 11.3V - 16.8V jumping around erratically
      Pin 8 - .0V
      • rddube
        Aspiring Expert
        • Jun 2013
        • 954
        Sorry pin 6 I had written down but did not put it in the list for some reason:
        pin 6 - 0V
        • petehall347
          • Jan 2015
          • 4440
          #124
          best i can think is drain power from main cap . mains power disconnected first of course .then measure resistances each pin reference pin 1 ground .
          • rddube
            Aspiring Expert
            • Jun 2013
            • 954
            Pin 1 - Gnd -
            Pin 2 - 0.656MΩ
            Pin 3 - 1.487MΩ
            Pin 4 - 28.09kΩ
            Pin 5 - .915MΩ
            Pin 6 - 1.1Ω
            Pin 7 - 1.2MΩ charging
            Pin 8 - 9.54kΩ
              • 31246
              pin7 is fed by a diode - can you check it.
              • petehall347
                • Jan 2015
                • 4440
                #127
                does it have an ntc connected to pin 5 ? if so what value is written on it ?
                pin 5 needs to be over 1.05v or pwm is disabled
                • harp
                  • Jun 2022
                  • 642
                  • Planet Earth
                  #128
                  If you disconnect psu from mains, and remove secondary output diode and then feed adjustable 10-14v to output terminals, so that tl431 circuit is working, you can monitor opto transistor resistance (primary side) and confirm that switch on at 12v point. Set on 12v with trimpot 1K.
                  Ok, so did the above test - removed secondary output diode, injected 12V on the output and took measurements of optocoupler resistance primary side:
                  No voltage applied (power off) - 3.191K ohms
                  10V applied - 1.086Mohms
                  12V applied - 1.086Mohms
                  13.3V applied 1.088Mohms
                  Strange, I was expect that resistance go down from initialy... What is optocoupler marked name?
                  So it seem the problem is on primary side, or transformer.
                  From pin6 to ground is power resistor, what value, I see brown gray silver gold, and you measure 1.1R?
                  And I notice one more thing... where is ground, you noted like GND or 0V... if ground isnt 0.000v that means that somewhere on board is short witch pull up a ground awhile. Is ground pulsating last digit-two also?
                  • lotas
                    • Jan 2016
                    • 4784
                    • Russia
                    #129
                    Yes, you correctly noticed that the current resistor shows R3 1.1 Ohm, but it should be 0.18 Ohm, this could be a problem.
                      • 31246
                      just a thought.
                      when you take these readings, are you getting the ground from the input for the input-side and from the output for the output side?
                      because the 2 grounds arent linked.
                      • petehall347
                        • Jan 2015
                        • 4440
                        #131
                        or meter error .
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8339
                          What do you read by just touching the two probes together?
                          • rddube
                            Aspiring Expert
                            • Jun 2013
                            • 954
                            Ok, so I guess my old Fluke needs calibration - I used another (cheaper) multimeter and R3 measures .1 ohm...when I put my probes together it measures 0.0 ohms. So R3 is good.
                            The ground I use to make the measurements on the IC are the main caps ground which is on the primary side. When I put 0V for pin 1, it was just that that's what I recorded to later realize it's ground.
                            The optocoupler is maked EL 817 - this is the 3rd optocoupler, but I think they are all good.
                            Quite a mystery!
                            • rddube
                              Aspiring Expert
                              • Jun 2013
                              • 954
                              Pin 5 is not connected to anything so probably not used?
                              • petehall347
                                • Jan 2015
                                • 4440
                                #135
                                rules that out then ..
                                what is connected to pin 4 ?
                                • rddube
                                  Aspiring Expert
                                  • Jun 2013
                                  • 954
                                  Pin 4 is connected to R9 a 28kohm resistor.
                                  • CapLeaker
                                    Leaking Member
                                    • Dec 2014
                                    • 8339
                                    Quite a mystery!
                                    Probably doesn't need calibration, rather a good cleaning where the probes go in and a quality new set of probes. Sometimes you can kind of restore them a little by cleaning with 99% alcohol followed with some Deoxit.
                                    • rddube
                                      Aspiring Expert
                                      • Jun 2013
                                      • 954
                                      Probably doesn’t need calibration, rather a good cleaning where the probes go in and a quality new set of probes. Sometimes you can kind of restore them a little by cleaning with 99% alcohol followed with some Deoxit.
                                      Ok, cleaned the probes and deoxed them, but the lowest I get with very high quality probes is .5 ohms, there is no way to 0 it. Whereas the cheaper tester Tais TA118A is dead 0 ohms when connecting the 2 probes together. It cost +- 40$ compared to the Fluke 87 V which had cost me over 500$. Probably need calibration and cleaning, but they're asking over 300$ CAD to do this at Fluke, not worth it.
                                      • harp
                                        • Jun 2022
                                        • 642
                                        • Planet Earth
                                        #139
                                        Open the fluke and clean pcb rotary switch with contact cleaner, and its parts in plastic on button side.
                                        Optocoupler have npn inside, and when lights go on, resistance go rapidly down. Check this whats are going on, even it is not your primary problem. When you feed secondary with 12v, you must have about 2.5v on tl431 reference pin1.
                                        • rddube
                                          Aspiring Expert
                                          • Jun 2013
                                          • 954
                                          Ok, will try that for the Fluke.
                                          For the 2.5V, you want me to remove the output diode and test again injecting 12V in the output side?
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                            03-31-2024, 02:12 PM
                                            07-01-2024, 06:34 AM
                                          • shamsudeen
                                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                            by shamsudeen
                                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                            07-19-2025, 07:14 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
