Extract bios password from EliteBook 840 G8 Bios dump, possible?
  • nesredin
    • Feb 2018
    • 36
    • ethiopia
    #541
    mode elitebook 840 g8
    SN=5CG227667N
    motherboaerd number = 6050a3426501-mb-a02
    • hoaca388
      Badcaps
      • Jan 2022
      • 11736
      #542
      SN=5CG227667N
      Unlocked
      • nesredin
        nesredin commented
        Editing a comment
        work perfect
        thank you
    • Hachem25
      • Aug 2021
      • 45
      • algeria
      #543
      I need help with this elitebook 840 G8
      sn 5CG1445VST.
      I have read it's ec ( probably) (on the back of the cpu ) but when choosing the chip i selected the wson 8*6 (3*256), after rewriting the new bios the pc didn't come on, and when i press the power button it blinks 7 times. i tries using a different chip but nothing. i even tried to use a firmware from the ones that are posted in this thread but nothing as well.
      i will attache the file that i read, and i hope someone can help me. thank you
      • hoaca388
        Badcaps
        • Jan 2022
        • 11736
        #544
        sn 5CG1445VST.
        HP EliteBook 840 G8_T76 EC
        • Hachem25
          Hachem25 commented
          Editing a comment
          unfortunattly it didnt work. i dont know why .
      • Hachem25
        • Aug 2021
        • 45
        • algeria
        #545
        i will attache this 2 photos maybe you'll spot if there is any missing components
        • hyditech
          • 272
          • nigeria
          #546
          Good after everyone, please me to unlock the password for hp zbook firefly 14 g8
          S/N 5CG2219Y3M
          same board number with 840 g8
          thanks
          • Vesko356
            Vesko356 commented
            Editing a comment
            Doesn't matter if it's the same motherboard or not, it's a different model.
            There is an existing thread for this model, find it and post your request there as per the rules.
        • chocouy
          • Jan 2024
          • 12
          • Philippines
          #547
          Good day, I was reading through the forums and have found (maybe) a solution to my problem.
          What I have gathered is that I need to remove the BIOS password first then edit DMI to remove SWAT lock?
          Are absolute persistence = SWAT = computrace the same?
          and lastly, how do I know which is the MAIN bios and the EC bios?
          Thanks!
          • chocouy
            • Jan 2024
            • 12
            • Philippines
            #548
            okay, managed to figure out which is the Main and EC chip
            EC - Back of Processor
            MAIN - Near Processor​
            • rex98
              • Feb 2023
              • 1278
              • Mandaue CEBU, Philippines
              #549
              Thanks!
              upload here the main and EC.
              • chocouy
                • Jan 2024
                • 12
                • Philippines
                #550
                hi good evening, here are my DUMPS
                • volinakis
                  • Jan 2021
                  • 2733
                  • N/A
                  #551
                  SN# 5CG21148K4
                  write only main chipset, at 1st boot press F10 to enter bios setup and restore factory defaults, save, then restore DMI with BCU.
                  • chocouy
                    • Jan 2024
                    • 12
                    • Philippines
                    #552
                    thanks but I have a problem with my laptop now, I tried editing the EC bin myself and flashed a bin that I have downloaded here to my own chip. now my laptop wont turn on, only blinking light and 0.040-0.045 amps power draw. I flashed my back up bin file but it's still the same, my solder is good, what could be the problem?
                    • volinakis
                      • Jan 2021
                      • 2733
                      • N/A
                      #553
                      maybe you didn't read correctly EC chip otherwise it should have worked if you write the original back. At G8 you have to modify main bios, not EC.
                      • chocouy
                        • Jan 2024
                        • 12
                        • Philippines
                        #554
                        if i have read incorrectly, can I use another EC bin from others?
                        • volinakis
                          • Jan 2021
                          • 2733
                          • N/A
                          #555
                          maybe, but you'll have problems with endpoint security. I don't know how to fix EC, maybe another member will help you to fix it.
                          • rex98
                            • Feb 2023
                            • 1278
                            #556
                            try my post at number 531 flash both main and ec.
                            https://www.badcaps.net/forum/troubl...18#post1872818
                            • chocouy
                              • Jan 2024
                              • 12
                              • Philippines
                              #557
                              tried flashing it with triple checking the bin files, now the laptop is flashing 7 times on capslock.
                              • chocouy
                                • Jan 2024
                                • 12
                                • Philippines
                                #558
                                hey! got the laptop finally working, I flashed both your BIOS and it loaded to the login screen of windows. but after a few minutes the SWAT lock activates again, any suggestions?
                                • rex98
                                  • Feb 2023
                                  • 1278
                                  #559
                                  flash it again. in first boot press f10 , reset security settings to default. if you don't do that absolute wont be deactivated.
                                  • chocouy
                                    • Jan 2024
                                    • 12
                                    • Philippines
                                    #560
                                    need to flash both again?
                                    • Buzzfuzz2k
                                      Bios password removal on a Unowhy dump
                                      by Buzzfuzz2k
                                      Hi Everyone,
                                      I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                      The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                      the Computer is a Unowhy small pc
                                      N° UYM6524702229
                                      After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                      My first attempt was to get the bios dump from windows...
                                      11-13-2023, 07:37 AM
                                    • traxformania
                                      TONGFANG "GM7TG7P" Bios Password Problem?
                                      by traxformania
                                      I tried :
                                      -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                      11-15-2023, 07:32 AM
                                    • Nopslide
                                      by Nopslide
                                      04-01-2024, 04:27 PM
                                    • outsider
                                      Panasonic FZ-G1 MK5 - BIOS password returning
                                      by outsider
                                      Hello
                                      I removed the BIOS password thanks to the help of one of the friends of this forum.
                                      https://www.badcaps.net/forum/troubl...61#post3637661
                                      The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                      06-17-2025, 12:51 AM
                                    • Habble7
                                      by Habble7
                                      Suspected Cause:
                                      Troubleshooting Attempts:
                                      05-22-2025, 07:28 AM
