Extract bios password from EliteBook 840 G8 Bios dump, possible?
  • qayyum786
    • Aug 2018
    • 1959
    • INDIA
    #621
    Originally posted by aldopc
    Hellp me elitebook 840 g8, Hello, can someone help me rebuild the main bios, I have received this device with another base case, from an elitebook 845 g8, for the same reason I do not have the original serial number, I only have the dump of the ec chip, the board has the corvette code 6050A3217501-MB- A01 the main bios comes empty....
    post another 32mb bios
    • aldopc
      • Jul 2017
      • 485
      • Chilito
      #622
      I don't have the other bin, it came empty, just FF FF FF
      • qayyum786
        • Aug 2018
        • 1959
        • INDIA
        #623
        try
        • aldopc
          • Jul 2017
          • 485
          • Chilito
          #624
          It doesn't work bro I don't have an image...only fan speed...can you make another try please
          • SteK
            • Nov 2019
            • 23
            #625
            Hi could someone please remove bios password on HP Elitebook 840/G8
            SN 5CG2271620
            please see attached zip file
            • aldopc
              • Jul 2017
              • 485
              • Chilito
              #626
              Test ando comments.
              • rex98
                • Feb 2023
                • 1298
                • Mandaue CEBU, Philippines
                #627
                here. just put the original DMI data from the laptop, its located in the stickers. use BCU tool.
                • minhdigital
                  • Nov 2022
                  • 766
                  • Vietnam
                  #628
                  Send to you, try
                  • minhdigital
                    • Nov 2022
                    • 766
                    • Vietnam
                    #629
                    SN 5CG2271620
                    Send to you
                    • SteK
                      • Nov 2019
                      • 23
                      #630
                      Hi could anybody help with bios password for HP Elitebook 840 Aero G8 if poss.
                      SN 5CG2271W7D
                      Thanks in advance.
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12513
                        #631
                        SN 5CG2271W7D
                        Thanks in advance.
                        Where is backup file ?
                        • SteK
                          • Nov 2019
                          • 23
                          #632
                          SN 5CG2271W7D
                          Thanks in advance.​
                          • qayyum786
                            • Aug 2018
                            • 1959
                            • INDIA
                            #633
                            At 1st boot press F10 and RESET BIOS to factory defaults, save, restart and password will go on. After that enter in to bios setup and in Main tab you have "set machine unique data" and write there what it's written on the label inside the cover
                            OR
                            use hp bcu tool to fill dmi and fix MPM
                            • abdelilahocs
                              • Nov 2018
                              • 119
                              • morroco
                              #634
                              Originally posted by Vesko356
                              Re: hp elitebook 840 g8 bios password
                              Here you are:
                              this works fine with me it clear password but after i have message of hp endpoint security controller problem
                              • abdelilahocs
                                • Nov 2018
                                • 119
                                • morroco
                                #635
                                Originally posted by hoaca388
                                Re: Extract bios password from EliteBook 840 G8 Bios dump, possible?
                                Description : HP EliteBook 840 G8
                                CT Number : 6LGWR0EWYF795L
                                Serial number : 5CG12869TG
                                SKU number : 3E9K6UP#ABA
                                Feature byte : 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mEmwnVng.Q4
                                Build Id : 21WWCVCT601#SABA#DABA
                                Product Number : 3E9K6UP
                                i flashed the second ship with this flash then clear manufacture mode error and its solved
                                • Berlusconi
                                  • Apr 2024
                                  • Ukraine
                                  #636
                                  Hello!
                                  Can you help to unlock my hp elitebook 840 g8, please
                                  it has admin BIOS password
                                  S/N# 5CG2128TV9
                                  ProdID: 613Q1UT#ABA
                                  Build ID:21WWCVET601#SABA#DABA​
                                  • Edgars UK
                                    • Jul 2023
                                    • 28
                                    Good evening .
                                    Please help remove PWR clean elitebook 840 G8 bios.
                                    Main and EC dumps are in attached file.
                                    Thanks in advance.
                                    M/B CORVETTE-6050A3217501-MB-A01
                                    s/n 5CG1515CKB​
                                    • rex98
                                      • Feb 2023
                                      • 1298
                                      #638
                                      Originally posted by Edgars UK
                                      Good evening .
                                      Thanks in advance.
                                      s/n 5CG1515CKB
                                      here only frash this ec
                                      • Edgars UK
                                        • Jul 2023
                                        • 28
                                        Thank you very much. You are a star.
                                        Have a nice day.​
                                        • rex98
                                          • Feb 2023
                                          • 1298
                                          #640
                                          Originally posted by Berlusconi
                                          Hello!
                                          S/N# 5CG2128TV9
                                          ProdID: 613Q1UT#ABA
                                          maybe you still need this.
                                          first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
                                          use BCU
                                          here's your DMI:
                                          Serial Number: 5CG2128TV9
                                          Product #/SKU: 613Q1UT#ABA
                                          CT Number: PQSNU00WBGF7RJ
                                          Description: HP EliteBook 840 G8 Notebook
                                          BuildID: 21WWCVET601#SABA#DABA
                                          Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBapaqauawb8bUbhcAdpdqfAfPguhKhkj4jhk8mEmGmwn7nVngpppq.Ne
                                          MAC Address : 60:6D:3C:C3:21:74​
                                          • Buzzfuzz2k
                                            Bios password removal on a Unowhy dump
                                            by Buzzfuzz2k
                                            Hi Everyone,
                                            I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                            The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                            the Computer is a Unowhy small pc
                                            N° UYM6524702229
                                            After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                            My first attempt was to get the bios dump from windows...
                                            11-13-2023, 07:37 AM
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
