Extract bios password from EliteBook 840 G8 Bios dump, possible?
First boot press f10 reset bios to factory defaults and exit, 2nd boot reset security settings to defaults
Use BCU here's your DMI info:
Serial Number: 5CG222503X
Product Number: 46L32UC#ACH
CT Number: PQSMT00WBGP6LL
Description: HP EliteBook 840 G8 Notebook
build_id: 21WWCVDZ602#SABA#DACH
Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAfPguhKhkjhk8mEmwn7nVngpDpnpqpr.78
MAC Address: 3C-18-A0-C2-BA-A0βComment
i need tpm reset tool for reset my hp elite i5 laptop bitlocker unlock purpose.
thanks with regards,
Ganesh babuComment
Hello all! I have just bought Elitebook 840 G8 i7 11th gen. It has a Bios Admin password as far as I was able to see trying to F10. For the rest is OK, boots to windows, acts normally.
Yet I want to be able to change the OS installed (win11) with Linux but can't access the BIOS....
Have allready desoldered and read the Bios and EC chips.
I need the help of some knowledgeable folks for unlocking the BIOS!
Thanks in advance!!!
SN: 5CG2390NZ6
ProID: 6A3P3AV
build_id: 21WWCVET601#SABZ#DABZComment
do not touch the EC.
Serial Number: 5CG2390NZ6
Product Number: 6A3P3AV
CT Number: PQSNP00WBH51X1
Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUcAdpdqeMfPgSguhKj4jhk8mEmVmwn7nVngpDpq.ef
MAC Address: 38-CA-84-56-38-E7
Hi can you please unlock my hp elitebook 840 g8
it has a bios password and Bit locker password
mbd id: 6050A3217501-mb-a01
sn - 5cg1473pcb
prodid - 4S1H8PA
this is my backup
Thank You in AdvanceAttached FilesComment
First boot press F10 reset bios to factory defaults & Restart, 2nd boot reset security settings to defaults.
search here bios config utility in forum in case you don' know.
Use BCU to fill these DMI INFO
Serial Number: 5CG1473PCB
Product Number: 4S1H8PA#ACJ
CT Number: PKUHC00WBFYBT9
build_id: 21WWCVCT602#SACJ#DACJ
Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBapaqauawb8bUbhcAdUdpdqfPguhKhkjhk8mEmwnVngpD.3n
MAC Address: C8-5A-CF-E4-88-F6Comment
do not touch the EC
can you unlock my hp elitebook 840 g8, please?
ProdID:16X35AVComment
I think I'm talking rubbish...but while I'm waiting for an 840 G8 to arrive with a bios password to unlock, I'll try to do my best! Sorry if I asked a stupid question. If I understand, do you need a dump of both the BIOS and the EC?Comment
Hi but can these files be flashed to any 840 g8?
Mα»i khoαΊ£n quyΓͺn gΓ³p cho badcaps Δα»u Δược hoan nghΓͺnh, hΓ£y nhαΊ₯p vΓ o liΓͺn kαΊΏt nΓ y Δα» quyΓͺn gΓ³p. CαΊ£m Ζ‘n tαΊ₯t cαΊ£ nhα»―ng ngΖ°α»i α»§ng hα»----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Thanks for your kind reply. I read the discussion from the beginning, especially post #9, and studied the original files with the patched ones. Furthermore, I also tried to patch some BIOS present here and make a comparison. I must say that I achieved an excellent result by comparing my patched files and yours do not present any difference. It still remains unclear to me why other values are also moved, while there is one that is not touched as in post #9. For me it's a professional deformation, I like to understand why, it's not enough for me to have someone do it for me. Thank you all for the valuable information on this forum and sorry for my bad English.Comment
@hoaca388β
I have read through the posts, and unfortunately, it's still a little unclear. Do I need to purchase a programmer to remove/reveal the bios password, or are there files you provide to help identify or remove the password? I see people posting files, but how are they getting them if the BIOS are locked. If I do need to purchase a programmer, is there one you recommend where I don't have to remove the bios chip?Comment
@hoaca388β
by Buzzfuzz2kHi Everyone,
I'm facing a problem with a locked bios with a password and i can't find how to remove it...
The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
the Computer is a Unowhy small pc
NΒ° UYM6524702229
After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
My first attempt was to get the bios dump from windows...-
by traxformaniaHello,
I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
I'm trying to reset my bios without success.
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
Channel: BIOS Requests ONLY!
by outsiderHello
I removed the BIOS password thanks to the help of one of the friends of this forum.
https://www.badcaps.net/forum/troubl...61#post3637661
The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...-
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
- Loading...
