Bios password removal on a Unowhy dump
  • Buzzfuzz2k
    • Nov 2023
    • 29
    • france
    Hello Guys,
    I'm still having some troubles to remove a password on a bios chip. I have bought a new T48 (TL866II plus) because my batronix programmer didn't get it well...
    Computer information:
    Unowhy computer (NOT laptop)
    UYM6524702229
    SN: UYM6524702229
    Art: T309475
    I also get a UYM184E70E15
    Click image for larger versionName:	IMG_20231108_183557.jpgViews:	15Size:	206.7 KBID:	3180448
    Click image for larger versionName:	IMG_20231114_205141.jpgViews:	15Size:	1.08 MBID:	3180449
    Click image for larger versionName:	IMG_20231114_205130.jpgViews:	15Size:	1,000.9 KBID:	3180450
    I have unsolder the W25Q256JV chip and get it on the T48, it was well reconnised.
    Click image for larger version  Name:	CM231113-193434002.jpg Views:	15 Size:	213.2 KB ID:	3180451
    As it is a unowhy computer, password seems "hide" in 2 places between “…AMITSESetup” and “.NVRAM…”
    Click image for larger version  Name:	HxD_hcSyPrM4x4.gif Views:	67 Size:	132.8 KB ID:	3180447
    But I can't get it to work... here are my tests....
    1-- If i select W25Q256JV@WSON8 on T48 program, It's reading, i get a dump, with 2 places where the password "should" be stored. Here is the original dump attached W25Q256JV@WSON8.origin.BIN. I have made the modifications, save the new dump (also attached) W25Q256JV@WSON8.mod.BIN.
    I burn the chip but i had burning problem, it seems it does burn properly and i get this error when checking flash
    ERROR! FLASH Address:0x000000 Buf_Val:0x11 IC_Val:0x01
    I tried to solder it... but computer doesn't start at all.... nothing...
    2-- As i have 3 computers, i tryed another chip from a booting computer, and choose W25Q256JV(OTP)@WSON8. The OTP version seems to work, No error on reading or flashing (but it's longer time).
    i get the W25Q256JV(OTP)@WSON8.original.BIN file (attached) and when i try to remove the password parts, I only find ONE place to modify (instead of 2?).
    I then burn it, solder it and computer boot up normally... but password is still there...
    Any ideas?
    Also, when i program the chip, i have an option "OTP Secu R" not activate... does it could help?
    Many thanks for your help!
    • Buzzfuzz2k
      • Nov 2023
      • 29
      • france
      No one can help me this the new test i did?
      • traxformania
        TONGFANG "GM7TG7P" Bios Password Problem?
        by traxformania
        I tried :
        -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
        11-15-2023, 07:32 AM
      • Nopslide
        by Nopslide
        04-01-2024, 04:27 PM
      • outsider
        Panasonic FZ-G1 MK5 - BIOS password returning
        by outsider
        Hello
        I removed the BIOS password thanks to the help of one of the friends of this forum.
        https://www.badcaps.net/forum/troubl...61#post3637661
        The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
        06-17-2025, 12:51 AM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • Johnny h
        Asus M7600R BIOS Password request/removal
        by Johnny h
        I'm hoping someone can assist me.
        I have an Asus Vivobook 16x Pro OLED laptop which has a BIOS password, and I can't seem to find it.
        It still boots into Windows (boots from whatever SSD is installed but not from USB).
        The model number is M7600R and serial number is N8N0CX03H71131C.
        I tried AMITSESetup Decryptor but the password I got doesn't make sense (it's got a line break and special characters).
        I also tried to use *************** MOD EDIT ,redacted************** and it also gave me the funny password of
        Code:
        tmNx\'=QJQ
        04-10-2024, 06:13 AM
