Extract bios password from EliteBook 840 G8 Bios dump, possible?
  • rex98
    • Feb 2023
    • 1298
    • Mandaue CEBU, Philippines
    #561
    Originally posted by chocouy
    need to flash both again?
    just the main
    • Hachem25
      • Aug 2021
      • 55
      • algeria
      #562
      i lost the main bios for my hp 840 g8. is there any solution?
    • Hachem25
      • Aug 2021
      • 55
      • algeria
      #563
      my model is hp elitebook 840 G8
      sn 5CG1445VST.
      i lost​ the original bios. if someone can help me.
        SMDFlea commented
        Editing a comment
        Look through the whole thread you should find some working ones.
    • balobi
      • Jan 2015
      • 88
      • phillippines
      #564
      please help... unlock swat lock problem.
      attached lock file.
    • hoaca388
      Badcaps
      • Jan 2022
      • 12514
      #565
      attached lock file.
      Alway add serial number into your post.
      • gclagos0523
        • Sep 2021
        • 26
        • Philippines
        #566
        Help Please unlock password and disable absolute module? Thank you in advanced.
        HP Elitebook 840 G8
        SN# 5cg2273kfq
        • qayyum786
          • Aug 2018
          • 1959
          • INDIA
          #567
          HP Elitebook 840 G8
          SN# 5cg2273kfq
          At 1st boot press F10 and RESET BIOS to factory defaults
          • semajnoerrac
            • Jul 2022
            • 9
            • Philippines
            #568
            Good day pelase help me my HP 840 G8 is swat lock and BIOS might pasword as well. Thank you in advance..
            SN# 5CG211466H
            • minhdigital
              • Nov 2022
              • 766
              • Vietnam
              #569
              SN# 5CG211466H
              Send to you, try
              • semajnoerrac
                • Jul 2022
                • 9
                • Philippines
                #570
                Originally posted by minhdigital
                Send to you, try
                ThNK YOU IT WORKS, however i kept seeing this image below.. sorry im knew to this thank you in advance..
                • Danmoh
                  • Sep 2021
                  • 64
                  • Kenya
                  #571
                  You need to input the dmi,the serial number,product number,ct number,feature byte,bid number then lock mpm etc
                  • chocouy
                    • Jan 2024
                    • 12
                    • Philippines
                    #572
                    anyone else had a problem with the fn key on their keyboard after flashing?
                    • bykanovm
                      • Aug 2022
                      • 102
                      • Украина
                      #573
                      Help me unblock Absolute. I tried many methods, but it remains active.
                      ID V86UC#ABA
                      SN 5CG2131VHW
                      • minhdigital
                        • Nov 2022
                        • 766
                        • Vietnam
                        #574
                        ID V86UC#ABA
                        SN 5CG2131VHW
                        Send to you
                        • bykanovm
                          • Aug 2022
                          • 102
                          • Украина
                          #575
                          Send to you
                          Thanks It works​
                          • hanz07
                            • Oct 2021
                            • 18
                            • phillipeness
                            #576
                            good day please help swat lock
                            s# 5CG21144Y1
                            • minhdigital
                              • Nov 2022
                              • 766
                              • Vietnam
                              #577
                              s# 5CG21144Y1
                              Send to you, try
                              • hanz07
                                • Oct 2021
                                • 18
                                • phillipeness
                                #578
                                Send to you, try
                                SIR THE SWAT STILL SHOWING
                                Send to you, try
                                ABSOLUTE PERSISTENT IS DISABLE
                                  SMDFlea commented
                                  Editing a comment
                                  Don`t post in all CAPS .
                              • rex98
                                • Feb 2023
                                • 1298
                                #579
                                first boot press f10 Apply factory defaults and exit, second boot reset security defaults and exit. use BCU input your DMI and you can permanently disable absolute there.
                                Serial Number: 5CG21144Y1
                                Product Number: 3K0M1UC#UUF
                                CT Number: PQSNL00WBGE53F
                                Description: HP EliteBook 840 G8 Notebook
                                build_id: 21WWCVET601#SUUF#DUUF
                                Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mEmwn7nVngpD.4g
                                MAC Address: A8-B1-3B-E9-D0-B9​
                                • izaak94
                                  • Mar 2019
                                  • 140
                                  • mexico
                                  #580
                                  I have a computer with administrator and absolute lock, could you help me? I tried to unlock it by comparing it with other files but it has an endpoint error
                                  SN:5CG222503X
                                  • Buzzfuzz2k
                                    Bios password removal on a Unowhy dump
                                    by Buzzfuzz2k
                                    Hi Everyone,
                                    I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                    The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                    the Computer is a Unowhy small pc
                                    N° UYM6524702229
                                    After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                    My first attempt was to get the bios dump from windows...
                                    11-13-2023, 07:37 AM
                                  • Ahari
                                    by Ahari
                                    I...
                                    08-13-2025, 06:12 AM
                                  • traxformania
                                    TONGFANG "GM7TG7P" Bios Password Problem?
                                    by traxformania
                                    I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                    But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                    I'm trying to reset my bios without success.
                                    I tried :
                                    -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                    11-15-2023, 07:32 AM
                                  • Nopslide
                                    HP Omen 15-dh0052nf power-on & bios password
                                    by Nopslide
                                    Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                    My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                    Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                    04-01-2024, 04:27 PM
                                  • outsider
                                    Panasonic FZ-G1 MK5 - BIOS password returning
                                    by outsider
                                    Hello
                                    I removed the BIOS password thanks to the help of one of the friends of this forum.
                                    https://www.badcaps.net/forum/troubl...61#post3637661
                                    The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                    06-17-2025, 12:51 AM
