Extract bios password from EliteBook 840 G8 Bios dump, possible?
  • sonerpc
    • Oct 2015
    • 34
    • turkey
    #441
    Re: Extract bios password from EliteBook 840 G8 Bios dump, possible?
    Originally posted by hoaca388
    Don't ask anymore, post 2 files bios + ec + serial number here, no one can help you if you don't attach the bios.
    There is a bios lock on the hp 840 g8 device. Can you please help? The ec and main bios are in the link. I am also writing the serial number. Thank you very much in advance.I would be very grateful if you could help me urgently, badcaps family. Thank you very much.
    download ec and main bios: https://www.dosy*******************ar https://www.dos********************ec_bios_.rar
    SN:5CG20962WF
    • chachatech07
      • Sep 2022
      • 19
      • philippines
      #442
      Rewrite the locked files to see how it works.
      sir im using AsProgramer to write the chip.. using default confuguration is there anything that i need to do first..
      if its not to much to ask may sir you give me the steps and setting i need to do first before i flash the chip?
      sorry for the ovious ignorance. im trying to learn please.
        • 21620
        SN:5CG20962WF
        Attach files directly to your post instead of linking to external websites
        • sonerpc
          • Oct 2015
          • 34
          • turkey
          #444
          badcaps family can you please remove the bios password for hp 840 g8. thanks in advance
          SN:5CG20962WF
          • sonerpc
            • Oct 2015
            • 34
            • turkey
            #445
            OK Sorry my dear friend.ı dont know.now ok ı think
            • hoaca388
              Badcaps
              • Jan 2022
              • 12249
              #446
              ok sorry my dear friend.ı dont know.now ok ı think
              ffffff
              • sonerpc
                • Oct 2015
                • 34
                • turkey
                #447
                ffffff
                Thank you very much brother. I will try it and get back to you. Isn't it enough to write the ec bios you sent? I will not do anything to the main bios.
                • chachatech07
                  • Sep 2022
                  • 19
                  • philippines
                  #448
                  Hello guy quick question here.. is it possible that a bad flash file can cause the laptop to have no power? charge led no light?
                  model is HP elitebook 840 G8 thanks appreciate your answers
                  • sonerpc
                    • Oct 2015
                    • 34
                    • turkey
                    #449
                    The device does not turn on at all. I don't know what mistake I made. The problem is, when I press the power button, the white light on the caps lock flashes 7 times. The computer has caused me trouble. Does anyone have any ideas?
                    What exactly is your mistake?
                    • chachatech07
                      • Sep 2022
                      • 19
                      • philippines
                      #450
                      i just flash the bios chip externally. then it happens so im kinda confused , dies a curruoted bios file can cause that laptop err0r.
                      i had the samething using other firmware posted here. does anyone know to solve this error?
                      • sonerpc
                        • Oct 2015
                        • 34
                        • turkey
                        #451
                        Is your problem the same as the one I wrote about?
                        • chachatech07
                          • Sep 2022
                          • 19
                          • philippines
                          #452
                          yes exactly have you gotten a solution for that?
                          • sonerpc
                            • Oct 2015
                            • 34
                            • turkey
                            #453
                            As far as I researched, the caps lock key flashing white 7 times is a bios error. Make sure that the bios integrated is completely soldered in place. Make sure that the bios is intact.
                            • chachatech07
                              • Sep 2022
                              • 19
                              • philippines
                              #454
                              yes and maybe improffer or incorrect firmware? mine now ir not showing power led when pluged in the led on the charging , caoslock and power button lit the gone .
                              • dezel
                                • Mar 2021
                                • 9
                                • Philippines
                                #455
                                Hello guys,,, i have here 840-G8 problem is Swat locked and admin password.
                                please help me to remove.
                                SN# 5CG211453K
                                thank you.
                                • rex98
                                  • Feb 2023
                                  • 1289
                                  • Mandaue CEBU, Philippines
                                  #456
                                  SN# 5CG211453K
                                  thank you.
                                  i modified your bios its absolute and password unlocked. it would take a few minutes before first boot just be patient.
                                  5CG211453K
                                  3K0M1UC#UUF
                                  PQSNL00WBGE6L5
                                  give feedback please.
                                  • yygg123456
                                    • Apr 2022
                                    • 5
                                    • 中国
                                    #457
                                    I need to unlock the bios password for 840 G8. Here are the two BIOS chip data I copied using a programmer. Thank you for your efforts!!
                                      • 21620
                                      Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
                                      • chachatech07
                                        • Sep 2022
                                        • 19
                                        • philippines
                                        #459
                                        Hi after few flash the atatua of ny laptoo has change from no power ro blinking amverlight on the charging po.. both while rumming on battery and witho. led stays blinking amber
                                        any idea whay the problem
                                        ut
                                        • dezel
                                          • Mar 2021
                                          • 9
                                          • Philippines
                                          #460
                                          5CG211453K
                                          3K0M1UC#UUF
                                          PQSNL00WBGE6L5
                                          thank you password is removed but the ssd is not detected and i have this error product information is not valid
                                          • Buzzfuzz2k
                                            Bios password removal on a Unowhy dump
                                            by Buzzfuzz2k
                                            Hi Everyone,
                                            I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                            The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                            the Computer is a Unowhy small pc
                                            N° UYM6524702229
                                            After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                            My first attempt was to get the bios dump from windows...
                                            11-13-2023, 07:37 AM
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
