HP 840 G7 password
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae.. -
Re: HP 840 G7 password
I Just need to program the 16MB file or both file?
I only did the 16MB file last time.
Thank for your help/Comment
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
HP_840_G7_32mb swat locked need help tnxx..Attached Filesif you find these attachements useful please consider making a small donation to the site
good morning can anyone help me to unlock my 840 g7 16mbAttached Filesif you find these attachements useful please consider making a small donation to the site
Read back through some older posts and you`ll find out how to unlock it yourself.
https://www.badcaps.net/forum/showpo...42&postcount=4
.Comment
here is your unlocked fileAttached Filesif you find these attachements useful please consider making a small donation to the site
Re: HP 840 G7 SECURITY ERROR
Hp endpoint security controller problem error
need patch file this bios am waiting your answerAttached Filesif you find these attachements useful please consider making a small donation to the site
Hello everyone, I bought a laptop from ebay, used it for half a year and it was blocked by k12 device frozen 4891.
I thought to go into the bios settings, but the bios has a password.
installed Windows without changing the settings, I thought it was a matter of boot security.
I read the forum and bought a 341 programmer, successfully flashed the BIOS and removed the password using RcUNLOCK
I made a new Windows and everything worked for 3 days, when the error k12 of freezing the device appeared again ...
started reading further, it turns out there is a second bios of 32 mb
I took it off and considered the dump. How can I find in the editor, in the bios for 32 mb related to k12 help unlock
hp g7 840Attached Filesif you find these attachements useful please consider making a small donation to the site
I uploaded a 16 MB bios dump from the bottom of the board, it contained the administrator password rc unlock helped to remove it, but the freezing error still appears.Hello everyone, I bought a laptop from ebay, used it for half a year and it was blocked by k12 device frozen 4891.
hp g7 840
Just in case, I'll attach my working dump, 16 mb at the bottom
I took from 188 messages an unlocked BIOS for 16 and 32 mb I flashed both, nothing starts, the laptop turns on and off, the cooler spins, the caps lock flashes 5 timesAttached Filesif you find these attachements useful please consider making a small donation to the site
help me unlock please it has bios password and computrace swatlock. in attached the bios main and the 2 ec.
i need the one that is MPM unlocked i can put DMI via mpm.Attached Filesif you find these attachements useful please consider making a small donation to the site
can you post here the block address you edit in hex? i tried RCU it doesn't boot no display. specific block starting and end. i tried copmparing files unlocked and my dump it has so many differences i dont know which block need to be modified.Comment
try only 32mbAttached Filesif you find these attachements useful please consider making a small donation to the site
THANK YOU i managed to unlock by myself. i used rcu it works and i compared the unlocked computrace bin in winhex and modified mine it also works.Attached Filesif you find these attachements useful please consider making a small donation to the site
Channel: BIOS Requests ONLY!
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
by chunhualoHI I have forgotten my old laptop Alienware 13 r1 bios password .
Can anyone find the master password for my laptop
The service tag number is : 2JJVH12-
by Zain Ahmashelp me to unlock bios password ADVAN Soulmate board code: apn21s
- Loading...
