HP 840 G7 password
  • aivan11
    • Nov 2016
    • 6
    • philippines
    #201
    Re: HP 840 G7 password
    Originally posted by alfredposadas09
    only remove swat lock is it okay for you?
    yes my problem is swat locked bios., but can you clean all dumps so then i can study if it is okay., do you mean that if i need to clean bios password also right?
    • alfredposadas09
      • Aug 2020
      • 342
      • Philippines
      #202
      Here is your swatlocked removed make sure to reformat ur ssd
      • alfredposadas09
        • Aug 2020
        • 342
        • Philippines
        #203
        i dont have the solution to open the bios administrator password but I can assure you that this bios now is no more absolute
        • alfredposadas09
          • Aug 2020
          • 342
          • Philippines
          #204
          no need to open the administrator just flash the main bios beside in ram slot
          • aivan11
            • Nov 2016
            • 6
            • philippines
            #205
            i'll try this one brother, feedback later..checked PM bro
            • aivan11
              • Nov 2016
              • 6
              • philippines
              #206
              job done swat lock removed,, thanks bro for helping...
              • Bigpunk
                • Aug 2015
                • 5
                Hello guys, I have a machine with a bios password, which I have tried to remove as described in many posts here. I also tried with the RCUnlocker_v_1_0... unfortunately without success. Can you help me to unlock it? I've attached both BIOS files below.
                • alfredposadas09
                  • Aug 2020
                  • 342
                  • Philippines
                  #208
                  Originally posted by bigpunk
                  hello guys, i have a machine with a bios password, which i have tried to remove as described in many posts here. I also tried with the rcunlocker_v_1_0... Unfortunately without success. Can you help me to unlock it? I've attached both bios files below.
                  here is your unlock file
                  • Bigpunk
                    • Aug 2015
                    • 5
                    NICE! I have access to the bios again.
                    Is there a way to get rid of the "HP Endpoint Security Controller Problem" message? It appears at every start now.
                    • alfredposadas09
                      • Aug 2020
                      • 342
                      • Philippines
                      #210
                      yes send 32mb bios beside in your ram slot
                      • Bigpunk
                        • Aug 2015
                        • 5
                        Is attached in post #207 (both files)
                        • alfredposadas09
                          • Aug 2020
                          • 342
                          • Philippines
                          #212
                          is attached in post #207 (both files)
                          flash it again.. 32mb and my 16mb that i gave you.. U must flash it again
                          • Bigpunk
                            • Aug 2015
                            • 5
                            You Sir, You are a genius beyond measure! It works flawlessly
                            THANK YOU!
                            btw this time I was too lazy to desolder the eeprom off the board :P
                            • alfredposadas09
                              • Aug 2020
                              • 342
                              • Philippines
                              #214
                              great
                              • Bigpunk
                                • Aug 2015
                                • 5
                                Should I enter values other than the serial number and product ID while the laptop is in program mode?
                                On every restart It counts down from 30 and when it drops to zero I probably won't be able to change anything anymore or will I?
                                • alfredposadas09
                                  • Aug 2020
                                  • 342
                                  • Philippines
                                  #216
                                  yes manually
                                  • tariom18m
                                    • Sep 2018
                                    • 15
                                    • algeria
                                    #217
                                      VIP Moderator
                                      • Aug 2018
                                      • 4386
                                      • Bulgaria 🇧🇬
                                      #218
                                      Program 16MB chip only, leave the 32MB as is, and consider donating to the forum if you're happy with the result..
                                      Become a Badcaps supporter
                                      Thanks to all supporters.​
                                      • airblade
                                        • Jan 2019
                                        • 58
                                        • Home
                                        #219
                                        please remove swat lock.. thanks
                                        • peterhui
                                          • Oct 2019
                                          • 9
                                          HI!!!
                                          I've attached both files.
                                          Need Admin bios password remove.
                                          I tried RCUnlocker on the 16MB file. (It not boot up to HP logo at all).
                                          Restore the original file, system works but the bios password still there.
                                          Need help.
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            Hi everyone
                                            09-06-2025, 05:47 PM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
                                          • chunhualo
                                            Please Help unlock bios password for Alienware 13 r1 bios password 7digit service tag
                                            by chunhualo
                                            HI I have forgotten my old laptop Alienware 13 r1 bios password .
                                            Can anyone find the master password for my laptop
                                            The service tag number is : 2JJVH12
                                            03-16-2025, 04:13 AM
                                          • Zain Ahmas
                                            unlock bios password ADVAN soulmate apn21s.
                                            by Zain Ahmas
                                            help me to unlock bios password ADVAN Soulmate board code: apn21s
                                            Yesterday, 01:14 AM
