HP 840 G7 password
  • smallvhin
    • Jul 2015
    • 195
    • philippines
    #341
    same issue admin password.
    iM using uploaded file here. Its working
    they show end point security
    I reset security settings no luck.
    clean my bios file
    main & ec
    more thanks🙏
    • rex98
      • Feb 2023
      • 1319
      • Mandaue CEBU, Philippines
      • Computer hardware repair
      #342
      clean my bios file
      main & ec
      more thanks🙏
      are you kidding me? you said clean me!. you didn't mention any bios password or absolute. next time describe your problem.
      • rex98
        • Feb 2023
        • 1319
        #343
        Master pls. help me to clean dump file.
        SN:5CG0465ZFL
        ProdID: 24X44UC#UFF
        more thanks master🙏
        only flash this main do not touch the EC.
        First boot press f10 reset bios to factory defaults and exit, 2nd boot reset security settings to defaults and exit.
        Use BCU to fill these DMI info. you can permanently disable absolute in BCU.
        Serial Number: 5CG0465ZFL
        Product Number: 24X44UC#UUF
        CT Number: PJSCQ00WBEGEIO
        Description: HP EliteBook 840 G7 Notebook
        build_id: 20WWCMBT601#SUUF#DUUF
        Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mE.ye
        MAC Address: 60-6D-3C-7A-61-10​
        • smallvhin
          • Jul 2015
          • 195
          • philippines
          #344
          late reply master.
          more thanks it's working 👍
          • thelibrary
            • Jul 2018
            • 19
            • philippines
            #345
            swat lock remove pls
          • rex98
            • Feb 2023
            • 1319
            #346
            serial number?
            • thelibrary
              • Jul 2018
              • 19
              • philippines
              #347
              ELITEBOOK 840 G7 swat lock remove pls.
              sn: 5CG050CDQQ
              • hoaca388
                Badcaps
                • Jan 2022
                • 12684
                #348
                sn: 5CG050CDQQ
                AAA
                If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
                Subscribe to support us. It only takes 1 minute:
                https://www.badcaps.net/settings/subscriptions
                • thelibrary
                  • Jul 2018
                  • 19
                  • philippines
                  #349
                  do i need to flash both?
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12684
                    #350
                    Yes
                    • trepachka
                      • Oct 2022
                      • 499
                      Hi, I have a Elitebook 840 G7 laptop. It had a admin password until got rid of it using a bin file in one of the postings.
                      However, on every boot, I am getting "There is a problem with the HP Endpoint Security Controller". Can you help me remove this message from popping up?
                      S/N 5CG1247CPR
                      ProdID 2Z4G6UC#ABA
                      I am also attaching both bin files.
                      • alfredposadas09
                        • Aug 2020
                        • 342
                        • Philippines
                        #352
                        S/N 5CG1247CPR
                        ProdID 2Z4G6UC#ABA
                        can u read ur 32mb main again because the file is corrupted
                        • trepachka
                          • Oct 2022
                          • 499
                          Ok, I am attaching original bin files. So, this one has the admin password in it. If you could just remove the password, this should fix my other issue as well.
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12684
                            #354
                            CCC
                            • trepachka
                              • Oct 2022
                              • 499
                              After reflashing the bin files, caps lock is blinking 7 times.
                              • m.sabry2110
                                • Oct 2017
                                • 135
                                • egypt
                                #356
                                try
                                • trepachka
                                  • Oct 2022
                                  • 499
                                  Yes, these files worked for me. The password was gone and I had to use BCU to get out of the manufacturing mode by filling out empty fields. Otherwise, computer is good to go. Thank you.
                                  • malangg
                                    • Sep 2014
                                    • 34
                                    #358
                                    HI, CAN YOU PLEASE REMOVE PASSWORD FOR ME. THANKX IN ADVANCE
                                    • rex98
                                      • Feb 2023
                                      • 1319
                                      #359
                                      serial number?
                                      • alfredposadas09
                                        • Aug 2020
                                        • 342
                                        • Philippines
                                        #360
                                        first boot press f10 then go factory default setup
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • MONDTECH
                                          x1403za r2.1 bios uefi password any one clear my bin file
                                          by MONDTECH
                                          serial NBN0CV10581747C
                                          board id X1403ZA MAIN BOARD R2.1
                                          bin file
                                          https://drive.google.com/file/d/1jBD...ew?usp=sharing
                                          12-12-2025, 10:40 PM
                                        • miharestore
                                          ThinkPad L14 Gen 4 BIOS Password Unlock - Possibilites
                                          by miharestore
                                          Dear Badcaps,
                                          Is there any available method to perform a bios password unlock on an ThinkPad L14 Gen 4?
                                          CPU is Ryzen 3 PRO 7330U.
                                          What about though Lenovo? It has the best support plan. They asked for the receipt, however it was sold though a reseller.
                                          As a sidenote I was always able to unlock any dell laptop with the master code by simply asking dell and providing a reseller/refurbisher receipt.
                                          Thank you very much!
                                          01-09-2026, 10:52 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          Hi everyone
                                          09-06-2025, 05:47 PM
                                        • Nopslide
                                          HP Omen 15-dh0052nf power-on & bios password
                                          by Nopslide
                                          Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                          My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                          Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                          04-01-2024, 04:27 PM
