HP 840 G7 password
  • hani55
    • 101
    • morocco
    #161
    Re: HP 840 G7 password
    Originally posted by miansh621
    add orignal dmi data
    Can you explain the method please
    • hoaca388
      Badcaps
      • Jan 2022
      • 11735
      #162
      What do you have after that announcement?
      • hani55
        • 101
        • morocco
        #163
        Thank you, my friend. It works, but the back is a problem system is booting
        manfacturing
        • hani55
          • 101
          • morocco
          #164
          ]Thank you, my friend. It works, but problem system is booting
          • hani55
            • 101
            • morocco
            #165
            Thank you very much, the problem was solved by setting the bios
            Best forum and best members
            • RatGoku
              • Jan 2023
              • 3
              Elitebook 840 G7 Bios password and Swatlock removal help would be appreciated.
              • hoaca388
                Badcaps
                • Jan 2022
                • 11735
                #167
                Post files from two spi chips here.
                • RatGoku
                  • Jan 2023
                  • 3
                  How do I find these?
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11735
                    #169
                    Do you have a programmer? Find on the motherboard (both sides) the chips with the 128 and 256 symbols on the chip, for example 25Q128BV.., 25Q256FV... use that programmer to back up the contents of these chips and upload them here.
                    • RatGoku
                      • Jan 2023
                      • 3
                      I do not have a programmer.
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11735
                        #171
                        https://www.badcaps.net/forum/showpo...40&postcount=2
                        • gharibe61517
                          • Dec 2022
                          • algeria
                          #172
                          Originally posted by Vesko356
                          Try:
                          hi bro can you help me to unlock this bios file bin for hp840 g7
                            • 20888
                            If you read back through some of the older posts you will know what your next step should be...
                            • Marc97
                              • Jan 2016
                              • 189
                              • Phillipines
                              #174
                              Originally posted by vougheart
                              i tried again this files but still lock btw thank you for reply
                              feedback for this file thank you sir the lock is gone but i cant default factory when i turn on it will stuck on restart no display and this message when turn on "hp endpoint security control problem" how to turn off this message everytime i turn on
                              • SHONE984
                                • Mar 2022
                                • 33
                                • stockholm
                                #175
                                Re: please help me remove the bios password hp 840 g7
                                Here you are:
                                hi there. i have the same problem i try whit hpunlocker but coming same for pass.
                                • hardware1
                                  • Sep 2021
                                  • 2930
                                  • N/A
                                  #176
                                  Here's your Unlocked Bios, if the password still present upload your another chip (EC), it could be 16MB or 32MB.
                                  In the first boot go to Bios Menu and disable security options (Default).
                                  all donations are welcome,
                                  • SHONE984
                                    • Mar 2022
                                    • 33
                                    • stockholm
                                    #177
                                    ok this is how it was. the first one was 32 mb. now I am sending 16 mb, first I started 32 mb in hpunlocker . the pass is still present ., then I started 16 mb in hp unlocker . it took time to start, but when it did, the pass was still there
                                    • SHONE984
                                      • Mar 2022
                                      • 33
                                      • stockholm
                                      #178
                                      maybe you should do both at the same time and not separately. I hope you understand how and think
                                      • gsmtim
                                        • Oct 2018
                                        • 33
                                        • philippines
                                        #179
                                        please remove admin lock and swat lock
                                        • hardware1
                                          • Sep 2021
                                          • 2930
                                          • N/A
                                          #180
                                          Program the both files together (Unlocked Files), and follow the steps in my previous post.
