HP 840 G7 password
https://www.badcaps.net/donateComment
Re: HP 840 G7 password
Do you have a programmer? Find on the motherboard (both sides) the chips with the 128 and 256 symbols on the chip, for example 25Q128BV.., 25Q256FV... use that programmer to back up the contents of these chips and upload them here.↵
i tried again this files but still lock btw thank you for reply
feedback for this file thank you sir the lock is gone but i cant default factory when i turn on it will stuck on restart no display and this message when turn on "hp endpoint security control problem" how to turn off this message everytime i turn on
Re: please help me remove the bios password hp 840 g7
Here's your Unlocked Bios, if the password still present upload your another chip (EC), it could be 16MB or 32MB.
In the first boot go to Bios Menu and disable security options (Default).Last edited by SMDFlea; 03-29-2023, 03:47 AM.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
ok this is how it was. the first one was 32 mb. now I am sending 16 mb, first I started 32 mb in hpunlocker . the pass is still present ., then I started 16 mb in hp unlocker . it took time to start, but when it did, the pass was still thereLast edited by SMDFlea; 03-29-2023, 03:47 AM.Comment
maybe you should do both at the same time and not separately. I hope you understand how and thinkComment
Program the both files together (Unlocked Files), and follow the steps in my previous post.Attached Filesif you find these attachements useful please consider making a small donation to the site
Channel: BIOS Requests ONLY!
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
by chunhualoHI I have forgotten my old laptop Alienware 13 r1 bios password .
Can anyone find the master password for my laptop
The service tag number is : 2JJVH12-
by Zain Ahmashelp me to unlock bios password ADVAN Soulmate board code: apn21s
- Loading...
