SVOD4 NPCX997
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1222
    • France
    #41
    or this
    • ArtHunting
      • Sep 2023
      • 23
      Originally posted by Maxpower3
      or this
      Many errors then shutdown
      • ArtHunting
        • Sep 2023
        • 23
        try this one. I don't really believe it, it's a test. maybe error
        Bad SWP Data
        • Maxpower3
          Bad Veteran
          • Feb 2018
          • 1222
          • France
          #44
          which ? there is no more number so normal.
          try forcing by holding ESC during boot when F1
          edit : with a functional with password. Can you give me the bios version. picture of setup menu
          • ArtHunting
            • Sep 2023
            • 23
            I was only able to remove the svp by completely clearing the eeprom. Then I recovered the serial number and other data via GoldenKey. Tested it on two T14 Gen3 laptops. Thanks for your help!!!
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1222
              • France
              #46
              possible to have a reading with svod after initialization with golden key
              • ArtHunting
                • Sep 2023
                • 23
                this dump without svp and after golden key
                • Maxpower3
                  Bad Veteran
                  • Feb 2018
                  • 1222
                  • France
                  #48
                  It's interesting to see the shifts.
                  Click image for larger version  Name:	image.png Views:	0 Size:	654.2 KB ID:	3580971
                  But your file no longer looks at all like the original.
                  I don't understand why either, I marked ThinkPad T14 gen3 and ThinkPad T14 Gen 3,
                  it's not the same!
                  Click image for larger version  Name:	image.png Views:	0 Size:	30.4 KB ID:	3580972
                  you had no error.
                  spelling in plnsrv.ini
                  Click image for larger version  Name:	image.png Views:	0 Size:	1.9 KB ID:	3580973
                  I would have needed a dump after initializing the eprom with golden key without number.
                  full init
                  Click image for larger version  Name:	image.png Views:	0 Size:	308.3 KB ID:	3580975
                  • ArtHunting
                    • Sep 2023
                    • 23
                    it's not the same!
                    you had no error.
                    full init
                    About ThinkPad T14 gen3 and ThinkPad T14 Gen 3, this is my faill. When i wrote with golden key first time Model Type make mistake, then I rewrote the value correctly. I'm sorry, but the laptops have already been given to the client, so I can't read the dumps.
                    Thanks again for your help.
                    • victrix1
                      • Apr 2020
                      • 6
                      • Poland
                      #50
                      Nm-e981 rev.1
                      no detect
                      please help me
                      • volinakis
                        • Jan 2021
                        • 2718
                        • N/A
                        #51
                        Originally posted by victrix1
                        Nm-e981 rev.1
                        no detect
                        please help me
                        don't choose any motherboard, just select "Novuton" in mode of programmer.
                        • victrix1
                          • Apr 2020
                          • 6
                          • Poland
                          #52
                          It's works, thank you.
                          Please remove bios password​
                          • volinakis
                            • Jan 2021
                            • 2718
                            • N/A
                            #53
                            I think you have to downgrade EC, read what Maxpower3 wrote.
                            • Maxpower3
                              Bad Veteran
                              • Feb 2018
                              • 1222
                              • France
                              #54
                              try maybe bad svp error
                              • victrix1
                                • Apr 2020
                                • 6
                                • Poland
                                #55
                                How to repair svp error?
                                • Maxpower3
                                  Bad Veteran
                                  • Feb 2018
                                  • 1222
                                  • France
                                  #56
                                  the file did not work
                                  you must also respect the rules with the serial number and the model of the PC
                                  PF47E8MX
                                  ​ThinkPad T16 Gen 1
                                  • arestlessknight
                                    • Jul 2024
                                    • 11
                                    Hello all,
                                    I was in the other thread (about shorting to ground as a bypass).
                                    I have a T14s Gen 3 AMD:
                                    Serial: PF4PM76Y
                                    Type: 21CGS0VT54
                                    I'd have to open it up again to get the board revision but it has an npcx977 security chip.
                                    My goal with this post was to understand the requirements for removing the SVP, etc.
                                    It looks like I would need the SVOD4 programmer to write the npcx977.
                                    Do I need anything else? Something to flash the bios? Ribbon Cable for MoBo sold separately?
                                    I will probably purchase the required tools next paycheck.
                                    • volinakis
                                      • Jan 2021
                                      • 2718
                                      • N/A
                                      #58
                                      Originally posted by arestlessknight
                                      Hello all,
                                      Serial: PF4PM76Y
                                      Type: 21CGS0VT54
                                      I got mine with extension card and 14 pcs flex cable so check before purchase if they are included.
                                      • arestlessknight
                                        • Jul 2024
                                        • 11
                                        Hello, I am back. I have the SVOD 4 programmer and software, as well as the ribbon connector breakout and a variety of ribbon connectors. I am trying to flash a T14 Gen 3 AMD as well (NM-E441 Rev 1.0). My serial and product id are provided above. Maxpower3 Which ribbon header do I need to connect to on the motherboard? I do not see a ribbon in my set that works for the two headers closest to the security chip. Thanks in advance!
                                        • volinakis
                                          • Jan 2021
                                          • 2718
                                          • N/A
                                          #60
                                          32x0.5mm
                                          • 2elw
                                            SVOD4 PCB pictures + parts
                                            by 2elw
                                            Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
                                            STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
                                            GW1N-UV9UG169C6/I5 FPGA - Its a...
                                            07-04-2025, 12:23 PM
                                          • couillu76
                                            yoga x390 (x13 to confirme )nuvoton npce288/388 sv password removal guide with svod4
                                            by couillu76
                                            before you start the procedure read the bios eeprom and save it you might need it at the end
                                            1do not power on your svod yet
                                            2plug you ribbon 30x0.5 to the left of the keyboard connector
                                            3test pin with testeur if it beep go to next stage
                                            4 open svod software select 1.8v
                                            5 now plug your svod
                                            6 select nuvoton
                                            7 plug charger on the board/laptop
                                            8 press read id
                                            9 select 256k
                                            10 read nuvoton
                                            11 save reading, now unplug the svod
                                            12 open HxD software and open your 256k file the one you just saved
                                            13look...
                                            03-26-2023, 06:19 AM
                                          • vanminhscdt@gmail.com
                                            Read EC NPCX997 Lenovo T14 Gen 4
                                            by vanminhscdt@gmail.com
                                            I can't read EC Npcx997, device not found
                                            Can anyone help me?
                                            Where did I go wrong or what else am I missing to read it?​
                                            Lenovo T14 Gen 4
                                            S/N :PF4YA55W
                                            M/B : NM-F261 RE 1.0
                                            Thank...
                                            03-31-2025, 12:46 AM
                                          • x16
                                            Lenovo L14 gen 2 unlock with svod4
                                            by x16
                                            I have a problem with a Lenovo L14 gen 2 (intel) with Nuvoton npce68b.
                                            I connected my svod4 with a 32pin cable to the keyboard connector. Ground is also connected and power for the mainboard. I can read the Nuvoton ID, but the dump is always empty. Does anyone have an idea?
                                            12-09-2024, 03:15 AM
                                          • magicpc
                                            Svod 4 reading emmc
                                            by magicpc
                                            Hello, is svod 4 able to read emmc? Do I need a special board or is it enough to solder into the pinout and insert the other side of the cables into the programmer? somehow especially set the svod?
                                            08-29-2022, 02:41 PM
