Lenovo Thinkpad Ec Pwd Bypass
- BIOS_Acer_1.14_W11x64.zip ???
mainboard DA0PS9MB8E0 ??
This laptop came with a corrupted BIOS (bricked / no start / no led) so I found a working bios online but I couldn't get past the BIOS password thing.
Lenovo Thinkpad 13 Gen 2
TYPE: 20J2
S/N: LR-0AVXSZ- BIOS_Acer_1.14_W11x64.zip ???
(I can't also delete the wrong comment).
BIOS: https://www.sendspace.com/file/peve8qComment
try all of this and give feedbackThis laptop came with a corrupted BIOS (bricked / no start / no led) so I found a working bios online but I couldn't get past the BIOS password thing.
TYPE: 20J2
BIOS: https://www.sendspace.com/file/peve8qAttached Filesif you find these attachements useful please consider making a small donation to the site
I'm stuck at "Entering Setup" boss.
I flashed all the BIOSes you provided and the first one asked me to enter a valid code or something so I chose 1234
and after that the Password requirement never showed up but I'm stuck a this "Entering Setup" message.
Tried all the BIOSes and same thing.Attached Filesif you find these attachements useful please consider making a small donation to the site
Give me the name. Who is the first?
Patched is autopatcher
[ HOW TO USE THE PATCH ]
STEP 1: Flash and replace current BIOS with the generated patch file
STEP 2: Boot the machine
STEP 3: Press ENTER/F1/etc. to enter BIOS settings
STEP 4: Enter any character when asked for Supervisor Password
STEP 5: Press enter when it shows Hardware ID
STEP 6: Press space bar 2x when asked
STEP 7: Turn off machine
STEP 8: Restore original BIOS
STEP 9: Reset BIOS settings to factory default
[ NOTES ]
When booting the patched BIOS you might have to:
- Hold the anti-tamper switch down the whole time (use tape)
- Remove the hard disk or replace it with a locked one
https://www.badcaps.net/forum/troubl...al#post1809652
NOPWD and NOPWD NVar is no pasword forever.
Enter clean password bios twice and Clear security chip
After restore original bios
retry other version of autopatcher
I tried bios_PATCHED.bin
[ NOTES ]
okok boss!! I'm gonna try it again
I tried everything but it's stuck at "Entering Setup" boss.
When I remove the NVME it's stuck at the LENOVO logo.
Maybe the BIOS I found is not compatible with the model?
I found the original BIOS from the Lenovo Website but I don't know how to modify it to the actual BIN file to flash:
https://pcsupport.lenovo.com/us/en/p...3-B07A93E0428CComment
Have you tried your original dump yet?
https://www.badcaps.net/forum/troubl...39#post1307139Attached Filesif you find these attachements useful please consider making a small donation to the site
I think I messed up big time for not following your steps when I first flashed the bios_PATCHED.bin.
Now no matter what firmware file I flash I'm stuck at "Entering Setup".
No password required, nothing, just stuck at this message.
Maybe the ITE chip got a wrong infoermation or something! :'(
Anyway thank you for your help boss!
You replied to me all the time ♥Comment
Have you tried the last file in the post? 25Q128FV without patch. Just this one.
Windows boot and work ?? just bios setup stuck
If Windows is working, check the password status using PowerShell and a script.
Or use the Lenovo Golden Key USB flash drive.
EEPROM Operations/EEPROM Dump (last page)
Capture the screen.
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Boss, the laptop finally worked!!!
Capture the screen.
I flashed the 25Q128FV rom and it finally entered the BIOS menu!
Thank you so much!
It still has blue screen when windows is starting up but I'll try to install a new one and try Lenovo Golden Key
I have a problem with this Lenovo ThinkPad T490 model, type 20N3, serial number 21R1A6. Using the EC bypass method, I can access the BIOS settings, but when I try to reset the supervisor password, it shows an error
Formset Main 1247C8E8... Failed to save storage. System. Status:Write Protected.
Legacy boot on/ Security boot OFF.
If I reset the password without saving with F10, the password comes back and I can't enter the BIOS.Comment
Hi Maxpower3 ,
thank you very much for your guide, I have succesful removed the supervisor password from my T490 NM-B901, even without removing the MB. I removed the SSD, my additional RAM and the battery before the procedure.
To help others as well, I have grounded the pin 10 with 12 on J9301 wich is next to the additional DDR slot.
Attaching some pictures for clarification.
Good luck! 😉Attached Filesif you find these attachements useful please consider making a small donation to the site
Can you confirm whether pin 10 needs to be used on this model please?I have a problem with this Lenovo ThinkPad T490 model, type 20N3, serial number 21R1A6. Using the EC bypass method, I can access the BIOS settings, but when I try to reset the supervisor password, it shows an error
you can use pin 6, 8 or 10 shorted to the ground. 10 is better because is close to 12 which is ground. My method for laptops who have LPC port: power on laptop and after 3 seconds I short pin 10-12 with a small screwdriver 3 times while I press F1 repeatedly. It works almost every time.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Thank you volinakis, it works — I can enter the BIOS, but for some reason I can't save any changes. I get the same message every time. I'm only having this issue with this model. Is it possible that the EC is write-protected?Comment
Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or RepairThis specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-06-2024, 11:40 AM
- Loading...
