playstation 5 digital firmware dump
  • BwE
    • Dec 2024
    • 12
    [QUOTE=Xtristi x;n3580179]
    edited by admin... you can not post your software or other adverts on this forum.
    • BwE
      • Dec 2024
      • 12
      deleted by admin and user banned for 7 days. not specifically for these posts but because they contacted users shilling their software after being told not to
      • Xtristi x
        • Feb 2017
        • 4
        Why was my post deleted then? I was never in contact with BWE ever? check my messages I haven't received a single one ever on this platform, well mostly because I forgot to introduce myself like 8 years ago😂. Nor has he ever told me to endorse his product? It was a legitment fix to a problem. I mostly lurk here as you can see my account age vs posts as most have been answered when finding problems using this forum, this particular question hasn't been and he had a legitment solution, to which I ended up finding myself as his comments were always deleted before anything. The practices here aren't even the best or rely on copying data with zero procedures described and doing things blindly using other consoles data. I'm not shilling his products, its literally a solution to a problem and worked perfectly. Honest question, how would we go about helping others if the best/easiest solution for a diy'r is a cost effective paid service? Should I not reference them at all? I know you have strict rules about endorsement, but who has actually posted anything in this thread that would lead to fixing a Nor file? Other than copying someone else's data and flashing it, which is more a work around vs an actual fix? Probably as to why people here are now having issues with mac addresses and wifi modules not working because they are just flashing addresses from other consoles.
        On a side note I know he's not very accepted in the community because of his semi unsightly business practices as seen before, But if its a legitment fix, why not tell people there is a way?
        If this sort of thing isn't accepted then my apologies, truly. But it was an actual solution to my problems, and I feel like people could benefit.
        • pacwcbs
          • Nov 2015
          • 28
          • Dominican Republic
          #164
          • T.K.
            • Dec 2024
            Hi Guys, hoping to get a bios dump for a PS5 CFI-2015-040
            • T.K.
              • Dec 2024
              Originally posted by M11111
              i have a PS5 bios bin ? EDM-040, CFI-2016 ......thanks
              can i get that!
              • AgentNovac
                • Jan 2023
                • 12
                • South Africa
                #167
                Hi, I need bios for cfi-1216a edm-030 please
                • Cobbes
                  • Mar 2024
                  • 27
                  Check what southbridge is on your cfi-1216a edm-030
                  After start, check if WiFi is working and showing its MAC in system infos.
                  • AgentNovac
                    • Jan 2023
                    • 12
                    • South Africa
                    #169
                    YOU ARE AMAZING! THANKS SO MUCH! IT WORKED!!!
                    • cr8179891
                      • Jul 2019
                      • usa
                      #170
                      Originally posted by crasher381
                      I'm about to replace the HDMI port on a cfi-1215a edm-033 69gg board, I attached the file here in case you want to try it.
                      thank you dude, this saved me on a cFi-1215a with 3 beep, took a few writes for it to take but it fired up.
                      • Unspun01
                        • Jun 2011
                        • 349
                        Hi. I read this entire thread, and I need to ask - Besides reading the NOR, and flashing contents back to the NOR, is anyone actually writing all ZEROS (00) or all ONES (FF) to the NOR to see if their actual NOR chip is actually good? Many people using this thread seem to be downloading NOR dumps, or reading/patching and writing to their NOR chips without seeing if the actual chip is working properly.
                        Some of the posts on here even say they read the NOR, and re-programmed the NOR with the same .BIN file and it seemed to work. This tells me the NOR chip might be dodgy, and may lead to another future failure.
                        Can anyone here provide some testimony that they have tested NOR chips by writing all 00 or all FF back-to-back and VERIFY if the contents of their NOR chips actually match exactly what is expected?
                        If even one bit does not verify it could cause issues and hints at a possible bad IC.
                        So far, I have not seen any evidence that anyone is verifying their NOR performance, or that the contents they are programming are accepted bit-for-bit on the IC itself.
                        Not criticizing anyone. I just genuinely want to know if the NOR contents corruption is a software issue, or a hardware issue.
                        As others in this forum have cautioned, we should not just download random things from the internet (due to console specific things like serial number, LAN mac address, WIFI mac address, disc or discless, any many others) without knowing what the risks are. Many people may have good NOR contents but the chip is not working correctly.
                        Hope to hear some other people's experiences.
                        • Xtristi x
                          • Feb 2017
                          • 4
                          i know my revelprog the will verify contents match uploaded or saved vs actual eeprom data. So I'm sure it's all up to the person or program that is being utilized. At the same time using an oscilloscope and verifying clock and data transfer from Southbridge to the chip will verify whether or not things are working as intended IC wise.
                          • techcity
                            • Aug 2023
                            Originally posted by eznacho
                            Need CFI-1215B EDM-030 digital version. Thanks in advance.
                            Did you ever find this? I am also looking for this file. CFI-1215B EDM-030
                            • Karlhartl
                              • Dec 2018
                              • Kenya
                              #174
                              Hi Guys, i have this CFI-1200A EDM-030 69GG firmware 9.20 donor dump needed please anyone help out
                              • murshad
                                • Oct 2023
                                • 5
                                • india
                                #175
                                hey i have this ps5 for repair it shows error su-103121-8 it came up with drive controller chip so i saw the cod3r was doing that disk edition to digital edition via just rewriting a digital versions bios for try need working bios of a digital version and ,odel number is CFI-1208A
                                • Cobbes
                                  • Mar 2024
                                  • 27
                                  Why not fixing the issue with the disc drive? There are two fuses (12v and 5V) on the mainboard near the disc drive power connector and at least two fuses on the disc drive daughter board.
                                  If it is unfixable in case of a bad SIE chip, than it would be an option to edit the bios data. You can dump the original bios and use TheCod3rs program or do it manually to change the offset 0x001C7011 from 02 (BD) to 03 (digital) to prevent the check for the drive at the update.
                                    • 31260
                                    as BWE has decided to bring up the subject of software,
                                    i'll just post these interesting links to free stuff
                                    https://github.com/TheCod3rYouTube/PS5NorModifier
                                    https://github.com/andy-man/ps5-wee-tools
                                    • murshad
                                      • Oct 2023
                                      • 5
                                      • india
                                      #178
                                      thanks bro
                                      I actually swapped BD board it shows same error , thats why i trying to edit bios .and i changed the offset but not turning on after that . i put og bios its turning on iam posting my og dump..
                                      and my bin is not working on the codErs nor modifier .
                                      • Cobbes
                                        • Mar 2024
                                        • 27
                                        The error su-103121-8 means that the SIE chip on the BD board is not responding.
                                        This could be no power on the BD board, due to a bad fuse at the connector on the mainboard or missing data connections. The BD board can not be swapped if the BD should be working after the repair.
                                        If you are using TheCod3r s software to edit the offset, rename the .BIN to .bin
                                        • murshad
                                          • Oct 2023
                                          • 5
                                          • india
                                          #180
                                          Its working ok
                                          I swapped means i put SIE chip to anothor working BD Board
                                          Anyway thankss
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • Tamo Neko
                                            Request for MX25VB8035F (1MB) Firmware Dump – Asus TUF Gaming H670-Pro
                                            by Tamo Neko
                                            I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
                                            What Happened:
                                            I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.
                                            • I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
                                            • My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
                                            What I Need:
                                            • A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
                                            02-12-2025, 11:29 PM
                                          • jorpec
                                            Dump/Firmware needed TV Kunft 19CG86813 Board T.EME380.61 Panel ECG185BB-LC4
                                            by jorpec
                                            Hi, all
                                            I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
                                            10-17-2025, 03:51 AM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
                                          • gun4as
                                            Need firmware dump for LG 23MP48HQ-P
                                            by gun4as
                                            Hello everyone, I have an LG 23MP48HQ-P with a mainboard EAX65543134. After a power flicker, the monitor only shows the "No Signal" message but goes to a black screen with a brief flash when an HDMI/VGA cable is plugged in. I cannot enter the OSD menu. All main voltages (18V, 5V, 3.3V) are stable under load. I made a backup of the firmware, but it was *after* the fault occurred, so my backup is likely corrupted. I flashed it back with no change in behavior. I can only find the firmware for the 24M38H model online. Could someone please share a working firmware dump for the 23MP48HQ-P?...
                                            08-25-2025, 04:28 AM
