Try those. I no longuer have the PS5 with me.
playstation 5 digital firmware dump
If it works, check if the wifi is working too.Attached Filesif you find these attachements useful please consider making a small donation to the site
I tried that one( it's 2016 A) and the console came to life but yeah no wifi. The odd thing is that I reflashed the original bin file that was supposed to be corrupted and now the console works but still no WiFi. I wonder if it's a wifi module issue.Comment
Yes, I think that is an issue with the wifi. But I guess it is more a wifi firmware missmatch than a defect. Can you confirm, that the console serial number on the ps5 shell matches the infos on the original nor (0x001C7210)? Same thing with the mac adress from the wifi module (0x001C73C0 - 6 Bytes little endian)?
Here is another nor dump.Attached Filesif you find these attachements useful please consider making a small donation to the site
Yes, the serial numer matches with the console shell but i cant check the wifi mac address because i cant find it anywhere in the console shell. i will try that bin file.Comment
i guess im going to try to reflow the wifi chip. i bought this console with a 3 beeps of death, i dont know if the wifi issues was there before or if was caused by nor chip getting corrupted. Its just weird that the same bin file that was corrupted and was causing 3bod its now working.
Anyway if anyone needs a bin file for a CFI-2016 B01Y (EDM-041) (it may have wifi issues)Attached Filesif you find these attachements useful please consider making a small donation to the site
How would you go about repairing your existing nor read? I'm just trying to fix my own console. Shelling out 100+ dollars for your utility to use it once isn't exactly in the cards.Comment
Hi Everyone
Does anyone have the BIOS file for a PS5 CFI-1115A EDM 020 DISC Version?
Thanks in advanceComment
by AhariHi all,
I...-
by Tamo NekoHello everyone,
I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
What Happened:
I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.- I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
- My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
- A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
1 Photo-
by jorpecHi, all
I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
Thanks -
by MephysisHello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"? -
by gun4asHello everyone, I have an LG 23MP48HQ-P with a mainboard EAX65543134. After a power flicker, the monitor only shows the "No Signal" message but goes to a black screen with a brief flash when an HDMI/VGA cable is plugged in. I cannot enter the OSD menu. All main voltages (18V, 5V, 3.3V) are stable under load. I made a backup of the firmware, but it was *after* the fault occurred, so my backup is likely corrupted. I flashed it back with no change in behavior. I can only find the firmware for the 24M38H model online. Could someone please share a working firmware dump for the 23MP48HQ-P?...
08-25-2025, 04:28 AM -
- Loading...
