playstation 5 digital firmware dump
+ More Options
Posts
  • Shibz1996
    • Jul 2024
    Please share Bios for CFI-121A. Tried one in the tread, showing invalid file error on PS5 NOR Modifier. Please help
    • ubreakifixer33
      • Jul 2024
      Hello still looking for cfi-1015b edm-010 bios firmware digital edition. Can anyone help with that?
      • Telscrt Telion
        • May 2023
        • Nigeria
        #103
        To reconfirm your PS5 BIOS file, use the PS5 Nor Modifier to obtain details like the MAC address and serial number. Then, obtain another BIOS file, whether digital or on disc, and place it in the PS5 Nor Modifier. Take note of the data serial number and use a hex editor to modify the new BIOS file. It's preferable if the new BIOS file is the same model as your own.
        In the hex editor, use your main BIOS file as the source to edit the new BIOS file.
        Insert:ThumbnailSmallMediumLargeFullsizeRemove
        Sc​
        Then, use the PS5 Nor Modifier to verify if the serial number and MAC address have changed. Finally, choose the model and edition to generate.
        • shvanmajd
          • Nov 2014
          • Iraq
          #104
          i have ps5 disk version cfi-1216a edm-031 61gg with 3 blod
          • cicetto
            • Nov 2015
            • 6
            • italy
            #105
            I've flashed a CFI-1016A, now PS5 boot but it won't to update with error su-101217-2, I've seen it has no wifi MAC Address.
            What can I do?
            • RotteNova383
              • Aug 2024
              • 3
              hello all. I've tried many different bios files for my 1015A disk edition, edm010. to no success. the most recent one i used another IC from a 1015A and used that NOR modifier to change serial..making sure i chose 1015A and DISK. console turns on and sometimes takes the disk and copies it, then it wont accept a disk at all... im really lost at this point, this seems relatively easy, but i must be missing something... I'd like to be able to use my original BIOs file and just fix whatever error is there, but i've no clue. any help would be GREATLY appreciated
              • Cobbes
                • Mar 2024
                • 26
                If your PS5 ist starting to the home menue and the disc drive is able to accept and copy PS5 discs, the data itself of the NOR is ok. You wouldn't get to this point if the NOR data is not ok.
                What is exactly the problem and what is the error message from the disc drive?
                If your disc drive is accepting disc but have trouble to read it and shows the error "Can't recognize...", the laser is mostly done.
                • Mousetohome
                  • Sep 2024
                  • 4
                  Could someone help me out looking for a 1115B or this one to be fixed? I tried a 1116A no luck on it. Turned into a no power no beeps. I reflashed to this but still 3 beeps
                  Thank you!
                  • cicetto
                    • Nov 2015
                    • 6
                    • italy
                    #109
                    What can I do?
                    I've replaced wifi chip J20H100 but I've still no MAC Address in wifi and I can't update PS5
                    • Cobbes
                      • Mar 2024
                      • 26
                      I had a similar issue where the wifi MAC was not shown, but BT worked. After replacing the southbridge the wifi MAC was shown again.
                      • Cobbes
                        • Mar 2024
                        • 26
                        Thank you!
                        I would try the attached dump.
                        • Cobbes
                          • Mar 2024
                          • 26
                          The name of the dump ends with .BIN but must be .bin for the PS5 NOR Modifier.
                          • Darky777
                            • Sep 2024
                            • 5
                            • Mexico
                            #113
                            Hello! I am new here, but I´m looking for a good dump of a CFI-1200a disc version to get rid of a 3 BOD console. Thanks in advance
                            • Fotik
                              • Mar 2018
                              • 4
                              • Russia
                              #114
                              Hello, I need a dump for edm-030 cfi1200a. Thanks in advance.
                              • Alex9k
                                • Sep 2015
                                • Украина
                                #115
                                ps5 disk version cfi-1216a dump no tested
                                • waleedoo
                                  • Nov 2016
                                  • 71
                                  Model : PS5
                                  Board Name : EDM-020
                                  Issue : 3 BEEPS
                                  ProdID : CFI - 1116A​
                                  • mohammed aram
                                    • Apr 2015
                                    • 74
                                    • egypt
                                    #117
                                    worked for me edm-031 southbridge 61gg
                                    thank you
                                    • Joztu
                                      • May 2022
                                      • 46
                                      • Nigeria
                                      #118
                                      H
                                      • anthonybaystate
                                        • Dec 2023
                                        • 3
                                        Does anyone have a PS5 Slim Digital Bios? EDM-040, CFI-2015B, thank you.
                                        • Gecko702
                                          • Oct 2024
                                          Hello, I just recently joined, I'm looking to fix my phat PS5 disc but id rather dump my BIOS and use a good working one just by hex editing, so how do I dump my .bin? I'm not sure if it has to do with the blue light of death and I get the UART code: "80830000 Shutdown or Freeze After SAM_IPL Loaded - GDDR6 Data Line Issue (Replace)" and yet cant go to safe mode and some times this code too: "C0020303 APU Not Responding - Trying Init or Reboot" not sure if my APU is dead or something with the BIOS? fuses are fine too, motherboard is EDM010 and CFI-1015A I just want to get my doubts cleared before I buy another PS5 thanks!
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • Tamo Neko
                                            Request for MX25VB8035F (1MB) Firmware Dump – Asus TUF Gaming H670-Pro
                                            by Tamo Neko
                                            I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
                                            What Happened:
                                            I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.
                                            • I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
                                            • My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
                                            What I Need:
                                            • A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
                                            02-12-2025, 11:29 PM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
                                          • gun4as
                                            Need firmware dump for LG 23MP48HQ-P
                                            by gun4as
                                            Hello everyone, I have an LG 23MP48HQ-P with a mainboard EAX65543134. After a power flicker, the monitor only shows the "No Signal" message but goes to a black screen with a brief flash when an HDMI/VGA cable is plugged in. I cannot enter the OSD menu. All main voltages (18V, 5V, 3.3V) are stable under load. I made a backup of the firmware, but it was *after* the fault occurred, so my backup is likely corrupted. I flashed it back with no change in behavior. I can only find the firmware for the 24M38H model online. Could someone please share a working firmware dump for the 23MP48HQ-P?...
                                            08-25-2025, 04:28 AM
                                          • eurocomputerland
                                            Canon iSensys MF264DW II, firmware memory dump
                                            by eurocomputerland
                                            Hi, i have canon mf264 printer which is stuck in download firmware mode and I'm after a firmware memory dump for this model, so I can try to rewrite. Thanks for your kind help!
                                            07-22-2025, 04:48 AM
