Please share Bios for CFI-121A. Tried one in the tread, showing invalid file error on PS5 NOR Modifier. Please help
playstation 5 digital firmware dump
Hello still looking for cfi-1015b edm-010 bios firmware digital edition. Can anyone help with that?Comment
To reconfirm your PS5 BIOS file, use the PS5 Nor Modifier to obtain details like the MAC address and serial number. Then, obtain another BIOS file, whether digital or on disc, and place it in the PS5 Nor Modifier. Take note of the data serial number and use a hex editor to modify the new BIOS file. It's preferable if the new BIOS file is the same model as your own.
In the hex editor, use your main BIOS file as the source to edit the new BIOS file.
Insert:ThumbnailSmallMediumLargeFullsizeRemove
Sc
Then, use the PS5 Nor Modifier to verify if the serial number and MAC address have changed. Finally, choose the model and edition to generate.Attached Filesif you find these attachements useful please consider making a small donation to the site
i have ps5 disk version cfi-1216a edm-031 61gg with 3 blodAttached Filesif you find these attachements useful please consider making a small donation to the site
hello all. I've tried many different bios files for my 1015A disk edition, edm010. to no success. the most recent one i used another IC from a 1015A and used that NOR modifier to change serial..making sure i chose 1015A and DISK. console turns on and sometimes takes the disk and copies it, then it wont accept a disk at all... im really lost at this point, this seems relatively easy, but i must be missing something... I'd like to be able to use my original BIOs file and just fix whatever error is there, but i've no clue. any help would be GREATLY appreciatedComment
If your PS5 ist starting to the home menue and the disc drive is able to accept and copy PS5 discs, the data itself of the NOR is ok. You wouldn't get to this point if the NOR data is not ok.hello all. I've tried many different bios files for my 1015A disk edition, edm010. to no success. the most recent one i used another IC from a 1015A and used that NOR modifier to change serial..making sure i chose 1015A and DISK. console turns on and sometimes takes the disk and copies it, then it wont accept a disk at all... im really lost at this point, this seems relatively easy, but i must be missing something... I'd like to be able to use my original BIOs file and just fix whatever error is there, but i've no clue. any help would be GREATLY appreciated
What is exactly the problem and what is the error message from the disc drive?
If your disc drive is accepting disc but have trouble to read it and shows the error "Can't recognize...", the laser is mostly done.Comment
Could someone help me out looking for a 1115B or this one to be fixed? I tried a 1116A no luck on it. Turned into a no power no beeps. I reflashed to this but still 3 beeps
Thank you!Attached Filesif you find these attachements useful please consider making a small donation to the site
I would try the attached dump.Attached Filesif you find these attachements useful please consider making a small donation to the site
ps5 disk version cfi-1216a dump no testedAttached Filesif you find these attachements useful please consider making a small donation to the site
Model : PS5
Board Name : EDM-020
Issue : 3 BEEPS
ProdID : CFI - 1116AAttached Filesif you find these attachements useful please consider making a small donation to the site
Hello, I just recently joined, I'm looking to fix my phat PS5 disc but id rather dump my BIOS and use a good working one just by hex editing, so how do I dump my .bin? I'm not sure if it has to do with the blue light of death and I get the UART code: "80830000 Shutdown or Freeze After SAM_IPL Loaded - GDDR6 Data Line Issue (Replace)" and yet cant go to safe mode and some times this code too: "C0020303 APU Not Responding - Trying Init or Reboot" not sure if my APU is dead or something with the BIOS? fuses are fine too, motherboard is EDM010 and CFI-1015A I just want to get my doubts cleared before I buy another PS5 thanks!Comment
by AhariHi all,
I...-
by Tamo NekoHello everyone,
I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
What Happened:
I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.- I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
- My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
- A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
1 Photo-
by jorpecHi, all
I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
Thanks10-17-2025, 03:51 AM -
by MephysisHello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"? -
by gun4asHello everyone, I have an LG 23MP48HQ-P with a mainboard EAX65543134. After a power flicker, the monitor only shows the "No Signal" message but goes to a black screen with a brief flash when an HDMI/VGA cable is plugged in. I cannot enter the OSD menu. All main voltages (18V, 5V, 3.3V) are stable under load. I made a backup of the firmware, but it was *after* the fault occurred, so my backup is likely corrupted. I flashed it back with no change in behavior. I can only find the firmware for the 24M38H model online. Could someone please share a working firmware dump for the 23MP48HQ-P?...
08-25-2025, 04:28 AM -
- Loading...
