Help with Motor Control Board - ProForm treadmill
  • Crrose
    • Dec 2013
    • 165
    • Usa
    #61
    Re: Help with Motor Control Board
    I also just tested the red and black wires that go from board to motor and not getting any reading at all but I do have 121.9v on AC1 and AC2.
      • 31196
      you may find that the 2 terminals that connect to the motor look like they are shorted together on the meter.
      that's called "static braking"
        What DC voltage do you get on the two legs of each Zener Diode you just put in.
        The DCV on those two filter caps should be around 160VDC (measured right at the two legs).
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          #64
          Originally posted by Crrose
          How would I apply 24v externally to the relay?
          I was thinking you had applied 24v to the motor to test it - I see it was 18v but
          that might also be enough to test the relay. Or perhaps a 24v printer adapter?
          • Crrose
            • Dec 2013
            • 165
            • Usa
            #65
            I get 6.6 and DZ1 and 24.2 on DZ4. I can't test the filter caps with it hooked up to the board due to the mounting frame being in the way and if I remove it then the heat sink will not work.
              DZ1 15V Zener and you are getting 6.6V
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                #67
                From the AC it goes to the rectifier - BR1 comes out of there at around 160v
                and on to the Big Caps so if no voltage at the Caps it could be a problem with the BR1.
                • Crrose
                  • Dec 2013
                  • 165
                  • Usa
                  #68
                  Yes, 6.6 on the 15v now.
                  • Crrose
                    • Dec 2013
                    • 165
                    • Usa
                    #69
                    How can I test the Bridge rectifier and the big caps with the board removed?
                      So what resistance do you get on that resistor sitting above those two Zeners, and the other one next to it?
                      • Crrose
                        • Dec 2013
                        • 165
                        • Usa
                        #71
                        I haven't tested them yet because there is a mounting place under the board that I have to remove to get to them.
                        • Crrose
                          • Dec 2013
                          • 165
                          • Usa
                          #72
                          Never mind, I thought you were talking about the large caps.
                          • Crrose
                            • Dec 2013
                            • 165
                            • Usa
                            #73
                            I get 50v on inside and 35.6v on outside one.
                            • selldoor
                              Slow Learner
                              • Dec 2010
                              • 7870
                              #74
                              You can test the bridge like a double diode should have 4 pins 2 AC and 2 DC.
                              Bridge rectifier test when pins are in a straight line +....~ ~....-
                              a) put your multimeter in diode test mode
                              b) put your red lead on plus + DCpin side and the Black lead on adjacent ~ AC pin - record reading
                              c) reverse the leads - recording reading
                              Then repeat the test on the other two pins
                              b) put your black lead on negative -DC pin side and the red lead on adjacent ~ ACpin - record reading
                              Then for good measure change meter to ohmsq200 test the two middle pins
                              (AC pins) for shorts
                              You cant test the big caps with the board removed if the heatsink has to be detached to remove the board. Is it possible to securely solder insulated wires to the cap legs (joints) then reassemble and carefully test to the end of the wires
                              I am off to bed now - early start tomorrow!!
                                I am looking for resistance not of the resistors, but the Voltages sure look kind of low.
                                BTW, you can also check the DC Voltage of the MCU ST62Txx between PIN 9 (Vdd) and pin 10 (Vss) to see if it has running Voltage (around 5VDC).
                                • Crrose
                                  • Dec 2013
                                  • 165
                                  • Usa
                                  #76
                                  I will get back to this tomorrow, been fiddling with it since 7:30 this morning.
                                  • keeney123
                                    Lauren
                                    • Sep 2014
                                    • 2536
                                    You will still need to check that the black, white and red wire connections. making sure you are getting the +5 and -5 volts speed control coming into the SCR board that is really a Mosfet board. I would think that these voltages turn on the gate of the Mosfet. If the mosfet is driving the motor there should be at least either the source or drain with the high DC voltage on it.
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 5037
                                      • New Zealand
                                      #78
                                      The black one broke in half when I tried to remove it from the board
                                      That's a sure-fire way to know it's bad
                                      -David VanHorn
                                      • Crrose
                                        • Dec 2013
                                        • 165
                                        • Usa
                                        #79
                                        When I checked the black, white and red wires I get 7v red/black and 2v white/black.
                                        • Crrose
                                          • Dec 2013
                                          • 165
                                          • Usa
                                          #80
                                          I get 8.3v on pins 9 and 10, if I checked the right pins, last 2 on the left side if looking down on it.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • Yanleb
                                            LG 60PK550 Logic Control Board EBR63450301
                                            by Yanleb
                                            Hi all, I just want to share the repair of my 60PK550-UA TV set.
                                            The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                                            But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                                            All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                                            C57: 3.30V
                                            C61:...
                                            07-20-2023, 12:38 AM
                                          • cyclones
                                            Motor control board repair
                                            by cyclones
                                            I have a motor control board I am trying to repair. I've been told the motor is fine, but the control board will only make the motor go one direction but not the other. Power comes in through a linear transformer and then a rectifier bridge and then filter caps. No schematics for the board. Relays on the board are 24V so I started by setting my bench PSU to 24V and injecting voltage. There are several LEDs. All but one LED lights up. There are test points labelled +15V, 0V and -15V. When checking voltage potential between +15V and 0V, I get a perfect 15V. For -15V to 0V, my meter shows approximately...
                                            10-30-2021, 10:39 PM
                                          • eagleeyez
                                            Treadmill Motor Control Board 032669-IF
                                            by eagleeyez
                                            I am looking for this Treadmill Motor Control Board 032669-IF schematic or how to fix it myself if someone can guide me and let me know what parts to change...
                                            I hope someone can help!
                                            Thanks.
                                            10-11-2020, 04:40 PM
