A guide on how to troubleshoot 2 seconds to black
This is a sticky topic.
  • buyerninety
    replied
    Re: A guide on how to troubleshoot 2 seconds to black
    i.e.; 'using a spare CCFL previously obtained.'
    AAhh, I understand.
    Another suggestion;
    On this webpage;
    http://pkrobot.freehostia.com/LCDRepair9.htm
    the guy took apart an LCD ( HP VS19 ) and found that he had forgotten
    to record how all the diffuser screens were meant to be reorientated
    for reassembly. These 'diffuser screens' (is there a better word for them?)
    could be mentioned e.g.;
    DISASSEMBLY
    Behind the LCD screen there may be multiple 'diffuser screens' which diffuse the LCD panels
    light evenly - take careful note of their orientations, so you know the order
    to put them back in during reassembly.
    >or maybe 'take careful note of their orientations, so they can be correctly reassembled.'
    >Also in Safety, maybe add wording like this?;
    SAFETY
    Most of the tests below require a multimeter, but all the ones that I write about are with
    power OFF and unplugged and with sufficient time having passed for any stored voltages
    (e.g. in the capacitors) to have dissipated. The CCFL test does not require a multimeter, but
    there is VERY HIGH VOLTAGE (600V to 1000V).
  • SteveNielsen
    replied
    Will the idea work in reverse, i.e. the ckt from a CFL to test a CCFL tube? I have a CFL with broken glass. It was broken when I moved into this place and I'm sure the mercury has long since dispersed so no worries there.
    replied
    "The CCFLs light up the panel and they can be bad due to age, bad solder, bad connection or a variety of reasons. The easiest way to test for bad CCFLs is to have a least one other CCFL.
    Let's assume that you have a LCD with 4 CCFLs (numbered 1 to 4) and a spare."
    He meant that you should have aknown good spare lamp for testing such as one you removed from the LCD panel that has cracked screen but still have good lamps.
    For people that does not have spare lamps for testing, you can use this:
    https://www.badcaps.net/forum/showthread.php?t=19987
    I myself keep a lot of spare lamp assemblies from broken LCD screen assemblies.
    http://s807.photobucket.com/albums/y...klight%20lamp/
  • Rtech
    replied
    d) Have never seen a Spare ccfl ::Having not read the Post suggest it may have meant TEST CCFL.
  • buyerninety
    replied
    "and plug in spare CCFL"...
    a)Most panels contain a spare CCFL?
    b)Many panels contain a spare CCFL?
    c)Panels occaisionally have a spare CCFL?
    d)Panels rarely contain a spare CCFL?
    Please clarify in the guide which of the above statements most closely
    reflects current manufacturing practice.
    (If there are brands which pretty much always provide spare CCFL,
    maybe identify them down in the thread - they're the ones I'd be
    keeping an eye out for!
    I'm surprised any manufacturer provides spare anything inside electronic
    equipment.)
  • buyerninety
    replied
    a)Most panels contain a spare CCFL. (?)
    b)Many panels contain a spare CCFL. (?)
    c)Panels occaisionally have a spare CCFL. (?)
    d)Panels rarely contain a spare CCFL. (?)
    equipment.)
  • retiredcaps
    replied
    Part 3
    Misc suggestions
    1) Post clear focused pictures in the following format. Please DO NOT post pictures inline as they slow down the loading of pages.
    For best picture quality and clarity take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focused pictures. Try to get a photo that is 2000x2000 resolution and less than 2MB or as close as possible.
    Here is an example of the picture composition we want.
    https://www.badcaps.net/forum/showpo...94&postcount=1
    2) Use clear coherent language with grammar and punctuation. If you can't articulate your problem, no one can or will help you.
    3) Make an effort and do some research before posting.
    4) If you are new, please read the FAQs before posting. You are more likely to get help if you do.
    5) Post MORE information that little. A post that says "MY MONITOR DOES NOT WORK. HELP ME" is likely to be ignored. The more information you give, the better.
    Changes in revision 0.3
    1) added another test for bad CCFLs
    2) added an example of poor soldering causing "2 seconds to black"
    3) added tutorial link for replacing CCFL
    4) added explanation on why bad caps cause "2 seconds to black"
    5) added section on bad CCFL wiring with pictures
    6) added more links to pictures and case studies
    7) added procedure on how to choose replacement caps
    8) corrected some grammar
    9) removed dead links
  • retiredcaps
    replied
    Part 2
    4) Bad inverter transformer
    The transformer (T designation) converts the low voltage into high voltage to drive the CCFLs. These can be bad. A simple test is to measure the resistance of the secondary windings. If you look at the transformer, these will be the thinner guage windings/wires. Sometimes you can tell which are the secondary inverter transformer pins. If you cannot, then you have to use "brute force" and measure all possible combinations as explained below.
    If you have a manual range multimeter, set it to 2k ohms (two thousand). You can test for open windings "in circuit" on the transformer (with power off and unplugged).
    Power off and unplug monitor. WAIT 5 MINUTES BEFORE STARTING the ohms measurements. Waiting allows the capacitors and other components to discharge.
    a) Number the pins on the transformers anyway you like
    b) black probe on pin 1, red on pin 2 - record ohm
    c) black probe on pin 1, red on pin 3 - record ohm
    d) black probe on pin 1, red on pin 4 - record ohm
    e) etc
    f) black probe on pin 1, red on pin last - record ohm
    g) black probe on pin 2, red on pin 3 - record ohm
    h) black probe on pin 2, red on pin 4 - record ohm
    i) etc
    j) black probe on pin 2, red on pin last - record ohm
    k) black probe on pin 3, red on pin 4 - record ohm
    l) etc
    m) finally, black probe on pin last-1, red on pin last - record ohm
    A 3% variation or more in the secondaries suggests a bad transformer. For example, if one reading is 950 ohms and the other is 750 ohms, then one of the transformers is bad.
    This test is not exhaustive as it does not detect all faults.
    Here is an example of what to measure.
    http://lcdparts.net/TransformerDetai...ProductID=2724
    Here is a case study.
    https://www.badcaps.net/forum/showthread.php?t=12121
    5) Bad CCFL/wiring
    a) Pay ATTENTION as there is a VERY HIGH VOLTAGE (600V to 1000V)! No multimeter is required for this test.
    The CCFLs light up the panel and they can be bad due to age, bad solder, bad wiring connection or a variety of reasons. The easiest way to test for bad CCFLs is to have a least one good CCFL. If you see a pinkish/redish hue, this is a sign that your CCFLs are dying.
    Let's assume that you have a LCD with 4 CCFLs (numbered 1 to 4) and a good spare. We are trying to narrow down which CCFL is bad by substituting in a good one.
    Pay ATTENTION as there is a VERY HIGH VOLTAGE (600V to 1000V)! As a safety precaution, it might help to have someone around when you are doing this if something screws up.
    a) TURN POWER OFF and unplug the monitor and wait 1 minute
    b) disconnect CCFL #1 and plug in spare CCFL into spot #1
    c) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
    d) TURN POWER OFF and unplug the monitor and wait 1 minute
    e) reconnect CCFL #1 and disconnect CCFL #2 and plug in spare CCFL into spot #2
    f) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
    g) TURN POWER OFF and unplug the monitor and wait 1 minute
    h) reconnect CCFL #2 and disconnect CCFL #3 and plug in spare CCFL into spot #3
    i) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
    j) TURN POWER OFF and unplug the monitor and wait 1 minute
    k) reconnect CCFL #3 and disconnect CCFL #4 and plug in spare CCFL into spot #4
    l) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
    If you have a bad CCFL, one of the tests above should show you which one. If you still have "2 seconds to black", then we can assume it is not due to a bad CCFL.
    Here are pictures of some bad CCFLs
    https://www.badcaps.net/forum/showthread.php?t=10078
    https://www.badcaps.net/forum/showthread.php?t=8978
    b) Alternatively, if you do not have a spare CCFL, then try this test.
    b) disconnect all CCFLs expect #1
    e) disconnect all CCFLs expect #2
    h) disconnect all CCFLs expect #3
    k) disconnect all CCFLs expect #4
    If one of the CCFLs does not light up, it is likely physically damaged (cracked) or the wiring is completely broken to it. Take out that CCFL and inspect it. If all 4 CCFLs do show "2 seconds to black", one or more can still be bad. This test only discovers a completely dead CCFL or completely broken wiring.
    PlainBill describes the procedure if they are in pairs at
    https://www.badcaps.net/forum/showpo...&postcount=297
    c) Sometimes the CCFLs are fine, but the wiring has degraded and makes intermittent contact with the CCFL. Some examples can be found at
    https://www.badcaps.net/forum/showpo...5&postcount=18
    https://www.badcaps.net/forum/showpo...6&postcount=44
    d) Replacing a CCFL is a delicate operation. See "Lamp Soldering Tutorial" at http://ccflwarehouse.com/lasotu.html to see what steps are involved. CCFLs can be sold "bare" or "pre-harnessed". The latter is easier to replace and install, but is more expensive.
    6) Bad/cold/poor solder joints
    Inspect the backside of the board carefully with a microscope or magnifying glass and look for bad solder joints. Here is a link to photos of good and bad solder joints.
    http://workmanship.nasa.gov/lib/insp...uirements.html
    Here is an example of a bad solder joint causing 2 seconds to black.
    https://www.badcaps.net/forum/showthread.php?t=12134
    7) other bad components
    These components are less likely to cause 2 seconds to black, but I have included them just in case.
    7.1 Voltage regulators
    Voltage regulators (U designation) can be bad. They can be shorted or output the incorrect voltage. The test described below only tests the former.
    If you have a manual range multimeter, set it to 200 ohms (two hundred). You can test voltage regulators "in circuit" for shorts by (power off and unplugged)
    a) black on pin 1- red on pin 2 - record ohms
    b) black on pin 1- red on pin 3 - record ohms
    c) black on pin 2- red on pin 3 - record ohms
    If any reading is less than 30 ohms you might have shorted voltage regulator. Remove from circuit and repeat the tests to verify.
    7.2 Resistors
    Resistors (R designation) can be blown or become open.
    You can test resisiors in circuit by (power off and unplugged)
    a) put black probe (com) on one pin and red probe on other pin - read/record ohm
    Compare the ohms reading with the color code or marking on the resistor. If the value is not the same, you will have to remove the resistor and test it out of circuit to verify.
    http://en.wikipedia.org/wiki/Electronic_color_code
    7.3) Bad Diode
    Diodes (D or ZD designation) can be bad. To test a diode in circuit,
    a) put your multimeter in diode test mode
    b) put your black lead on one side and the red lead on the other - record reading
    c) reverse the leads - recording reading
    A good diode should read 0.4V to 0.7V in one direction and 0L in the other. If you get a reading in both directions, you will have to desolder one leg and retest to verify.
    8) Inverter IC sense circuitry/feedback
    This is probably the hardest to describe and hardest to troubleshoot. If you are at this stage, you do need a basic knowledge of how to use a multimeter, some electronics knowledge, and decent troubleshooting skills,
    One of the Inverter IC's function is to monitor the environment. If something "goes wrong" or falls outside the specified operating range, the IC shuts down the backlights to protect them -> 2 seconds to black.
    PlainBill describes 2 seconds to black best in these posts ...
    https://www.badcaps.net/forum/showpo...5&postcount=25
    https://www.badcaps.net/forum/showpo...10&postcount=4
    The standard procedure to identify inverter IC, find its datasheet, and look at its "typical application" diagram. The next step is to measure the voltages on each of the inverter IC pins and compare them to the specified datasheet. If any value is outside the specified operating range, then we have to determine what component or components is causing that.
    The components that are part of the sense circuitry might include diodes, resistors and capacitors (see section 7). Or the inverter IC itself might be bad.
  • retiredcaps
    replied
    REVISION 0.3 - Dec 16, 2011
    More revisions are sure to come. Make sure to read the latest posts for corrections or input from others.
    I wrote this to help others by sharing what I have learned. This information is nothing new, but it is scattered all over different threads.
    This is NOT a definitive guide as others have far greater knowledge and experience.
    Description of problem
    You turn on your LCD monitor and it displays a computer image on your screen and then suddenly it turns off after 1 or 2 seconds. The power LED stays on (or green) and you can/may still see the computer image by shining a flashlight on it. This is called "2 seconds to black".
    Where the problem lies
    Since you are seeing the image, but with no backlight, we will assume for now that the power and logic board are working properly.
    Tools needed to troubleshoot
    You will need the following tools to troubleshoot:
    a) multimeter
    b) camera to take clear focused pictures
    c) solder iron to replace components
    Personality Traits required
    a) ability to follow directions
    b) troubleshooting skills
    c) determination
    d) willingness to learn
    e) patience
    f) ability to articulate your problem clearly
    If you don't have at least one of the traits above, sell or give away your monitor to someone else. Seriously. Don't dump in the garbage. Recycle it properly please.
    SAFETY
    Most of the tests below require a multimeter, but all the procedures that I write about are with power off and LCD unplugged. The CCFL tests do not require a multimeter, but there is VERY HIGH VOLTAGE (600V to 1000V).
    I take no responsibility for any of the tests below that may cause you or your monitor any harm. If you are not comfortable, do not try it. Ask someone knowledgeable for help.
    Multimeter
    If you have a manual range multimeter, set it to 200 (two hundred) ohms. Touch the black and red probe together. It should read between 0.1 or 0.5 ohms. If it is higher than 1.0 ohm, there is something likely wrong with your multimeter. Either the test leads are frayed internally and/or the battery is dying which will result inaccurate readings.
    If your multimeter reads "1" or "0L", it means the measurement is outside your chosen range. Don't confuse "1" on the left hand side of this display with 1.0 on the right hand side. The first means out of range and the second means 1.0 unit of your measurement.
    Do NOT use the continuity or "beep" feature of your multimeter for measurements. Some multimeters "beep continuous" for resistance readings less than 1.5k ohms.
    Always post the actual results of your measurements when asking for help.
    Possible causes
    Here are some of the possible causes of "2 seconds to black". Your LCD monitor may have one or all the following. I suggest reading all the possible causes and then applying the ones that make the most sense to your situation.
    1) Bad Capacitors
    Capacitors (C designation on the PCB board) die from age, heat, and shoddy build quality. Capacitors DO NOT have to be visibly bloated in order to bad. They can be out of tolerance uF (a 1000uF measures 20uF) and/or have high ESR (ohm). A multimeter will be insufficient to test for ESR. For that you need an ESR tester which costs between $50 and $300.
    Bad capacitors will not provide stable reliable power which may cause "2 seconds to black".
    Most members here will recommend that you replace ALL capacitors with reputable brands from reputable sellers. Brands like Rubycon, Panasonic, Nichicon and United Chemicon are suggested. A list of recommended caps can be found at
    https://www.badcaps.net/forum/showthread.php?t=2280
    The one exception might be the largest capacitor on the power board which rarely, but not never, fails.
    Here is an example of how to choose capacitors with respect to capacitance, voltage, diameter, height, ripple and ESR.
    https://www.badcaps.net/forum/showpo...4&postcount=19
    2) Shorted Transistors/MOSFETs
    On some LCD brands (example: Benq) the transistors (C5707) are sometimes shorted. Transistors are usually marked with a "Q" designation.
    If you have a manual range multimeter, set it to 200 ohms (two hundred). You can test for shorted transistors "in circuit" (with power off and unplugged)
    a) put black probe on pin 1 and red probe on pin 2 - read/record ohm
    b) put black probe on pin 1 and red probe on pin 3 - read/record ohm
    c) put black probe on pin 2 and red probe on pin 3 - read/record ohm
    If any reading is less than 30 ohms you might have shorted transistor. Remove the transistor and repeat the tests out of circuit to verify.
    Note: a shorted transistor would likely cause a very brief flash of the backlight or no backlight.
    Mosfets
    If you have a manual range multimeter, set it to 200 ohms (two hundred). This is for 3 pin ICs only. You can test a mosfet (Q, IC designation) "in circuit" by (power off and unplugged)
    If any reading is less than 30 ohms you might have shorted mosfet. Remove from circuit and repeat the tests to verify.
    Some mosfets are more than 3 pins. To test those, identify the part number and search for its datasheet. Once you find the datasheet, the pins will be designated source (S), gate (G), and drain (D). It will probably be documented as S1, S2, G1, G2, D1, D2.
    Simply test
    a) black on pin S1- red on pin G1 - record ohms
    b) black on pin S1- red on pin D1 - record ohms
    c) black on pin G1- red on pin D1 - record ohms
    Repeat for the "2" pins. That is S2-G2, S2-D2, G2-D2.
    Note: a shorted mosfet would likely cause a very brief flash of the backlight or no backlight.
    https://www.badcaps.net/forum/showthread.php?t=17659
    3) Open fuse
    Some boards will have a fuse (F designation) or picofuse (PF designation) and they may be open because a transistor was shorted or some other component went bad.
    If you have a manual range multimeter, set it to 200 ohms (two hundred). You can test for open fuses "in circuit" by (with power off and unplugged)
    a) put black probe on one pin and red probe on other pin - read/record ohm
    A reading of less than 1.0 ohms indicates a good fuse. Anything higher than 1.0 ohm is a sign of an open fuse. Do NOT replace fuses and turn on the power back on without checking for what caused the fuse to go open otherwise you will just be replacing the fuse again.
    Note: In older monitors, some inverter boards have 2 fuses. One fuse could be bad and one could be good which results in 2 seconds to black. In newer LCD monitors, there is usually only one fuse protecting the inverter section. If that fuse is bad, you would get NO backlight flash (i.e. no 2 seconds to black).
    https://www.badcaps.net/forum/showthread.php?p=197027
  • DTLMG
    replied
    Didnt I read there were some youtube videos somewhere? Im interested in learning how to do the voltage readings on the PSU. I am a visual person as I am older.
  • jgmanza
    replied
    Thanks. This is very useful, thanks.
  • flightengineer
    replied
    Hi all.. it was very helpful steps .
    at least for me and i`m thankful to you.
  • billy66
    replied
    Excellent update! I've been putting together a troubleshooting guide notebook for me to refer to often... I'll be printing this out and using it often. THANKS!
  • retiredcaps
    replied
    Part 2
    4) Bad transformer
    The transformer (T designation) converts the low voltage into high voltage to drive the ccfls. These can be bad.
    If you have a manual range multimeter, set it to 2k ohms (two thousand). You can test for open windings "in circuit" on the transformer by (with power off and unplugged)
    e) etc
    i) etc
    l) etc
    I'm guessing the secondaries should read 950 ohm (this will vary for different transformers). If one secondary is 950ohm and the other is 750ohm, that would indicate a problem. A 4% variation or more in the secondaries suggests a bad transformer.
    This test is not exhaustive as it does not detect all faults. For that, you will need a ring tester to test the coils.
    Here is a youtube video showing the process on how to measure secondaries
    http://www.youtube.com/watch?v=eNuGWBPRGKA
    or if you have a ring tester, see this video
    http://www.youtube.com/watch?v=HMUazhb0bhc
    5) Bad CCFL
    The CCFLs light up the panel and they can be bad due to age, bad solder, bad wiring connection or a variety of reasons. The easiest way to test for bad CCFLs is to have a least one other good CCFL. If you see a pinkish/redish hue, this is a sign that your CCFLs are dying.
    If any ohm reading is less than 30 ohm you might have shorted voltage regulator. Remove from circuit and repeat the tests to verify.
    7.2 Resistors
    http://en.wikipedia.org/wiki/Resistor#Resistor_marking
    7.3) Bad Diode
    Misc suggestions
    1) Post clear focused pictures AFTER reading
    https://www.badcaps.net/forum/showthread.php?t=1868
    Please do not post pictures inline as they slow down the loading of pages.
    For best picture quality and clarity take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focused pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
    Here is an example of the pictures we want.
    5) Post MORE information that little. A post that says "MY MONITOR DOES NOT WORK. HLEP (sic) ME" is likely to be ignored. The more information you give, the better.
    Changes in revision 0.2
    1) added "case studies"
    2) added youtube videos
    3) added info on how to test mosfets, voltage regulators, resistors
    4) added info how a sense circuit works with inverter IC
    5) added instructions for manual multimeter
    6) added info about testing "in circuit"
    7) added info about using continuity setting on multimeter
    8) added info about pinkish/redish hue on ccfl
    9) fixed up some obvious typos, spelling and grammar
    10) added section on multimeter
    11) added board PCB designations
    12) forum member pedro suggested that I change the good fuse reading to suggest a range rather than a "hard" value of 0.3 ohms
  • retiredcaps
    replied
    UPDATED and REVISED - PART 1
    REVISION 0.2 - Nov 3, 2010
    I wrote this to help others by sharing what I have learned over the last 6 months. This information is nothing new, but it is scattered all over different threads.
    You turn on your LCD monitor and it displays a computer image of your screen and then suddenly it turns off after 1 or 2 seconds. The power LED stays on (or green) and you can still see the computer image by shining a flashlight on it.
    Since you are seeing the image, but with no backlight, we will assume for now that the power board and logic board are working 100%. That leaves the inverter section to check.
    a) multimeter
    c) solder iron to replace components with optional desolder wick or pump
    b) some troubleshooting skills
    c) determination
    e) patience
    SAFETY
    Most of the tests below require a multimeter, but all the ones that I write about are with power off and LCD unplugged. The CCFL test does not require a multimeter, but there is VERY HIGH VOLTAGE (600V to 1000V).
    Multimeter
    If you have a manual ranging multimeter, set it to 200 (two hundred) ohms. Touch the black and red probe together. It should read 0.3 or 0.4 ohms. If it is higher than 1.0 ohm, there is something wrong with your multimeter.
    If your multimeter reads "1" or "OL", it means the measurement is outside your chosen range. Don't confuse "1" on the left hand side of this display with 1.0 on the right hand side. The first means out of range and the second means 1.0 unit of your measurement.
    Do NOT use the continuity or "beep" feature of your multimeter for measurements. Some multimeters "beep good" for resistance readings less than 1.5k ohms.
    Possible causes
    Here are some of the possible causes of "2 seconds to black" in no particular order. Your LCD monitor may have one or all the following. I suggest reading all the possible causes and then applying the ones that make the most sense to your situation.
    1) Bad Capacitors
    Most members here will recommend that you replace ALL capacitors with reputable brands from reputable sellers. Brands like Rubycon, Panasonic, and United Chemicon are suggested. A list of recommended caps can be found at
    PCBONEZ talks about how to choose the right series at
    https://www.badcaps.net/forum/showpo...47&postcount=3
    If any ohm reading is less than 30 ohm you might have shorted transistor. Remove the transistor and repeat the tests out of circuit to verify.
    Mosfets
    If you have a manual range multimeter, set it to 200 ohms (two hundred). You can test a mosfet (Q, IC designation) "in circuit" by (power off and unplugged)
    If any ohm reading is less than 30 ohm you might have shorted mosfet. Remove from circuit and repeat the tests to verify.
    Simply test
    https://www.badcaps.net/forum/showthread.php?t=8598
    3) Open fuse
    Note: In older monitors, some inverter boards have 2 fuses. One fuse could be bad and one could be good which results in 2 seconds to black. In newer monitors, there is usually only one fuse protecting the inverter section. If that fuse is bad, you would get NO backlight flash (i.e. no 2 seconds to black).
    continued in Part 2 below ...
  • alexanna
    replied
    I will read over the Pm, it will be later this evening.
    Thanks Al.
  • retiredcaps
    replied
    Originally posted by alexanna
    Retiredcaps what would be the best way to add some suggestions to your thread. Once they are posted here it's like writing them in stone. I just want to make sure you agree with them.
    Al.
    Good timing on your question.
    I have been making changes for 0.2 in the last 48 hours so any feedback would be appreciated.
    There are a lot of corrections as I have learned more in the last 45 days since revision 0.1.
    I'll send you or anyone else who wants a copy of 0.2 (PM me). I have thick skin. Don't hold back on the comments.
    I'm hoping to post 0.2 in the next week or so.
  • alexanna
    replied
    Retiredcaps what would be the best way to add some suggestions to your thread. Once they are posted here it’s like writing them in stone. I just want to make sure you agree with them.
    Al.
  • retiredcaps
    replied
    Originally posted by CompSol
    In my case, I get the black screen after 2-3 seconds, but then if I try to turn the monitor off and on several times, eventually it turns on and works properly. It takes about 20 minutes turning it off and on, sometimes longer, today it took much longer, but the monitor turned on finally and runs.
    Start a new thread with your problem and the make/model of the monitor. What you are describing is a classic sign of bad caps.
    If you take your monitor apart, you will probably find obviously bad caps.
  • CompSol
    replied
    I`ve been experiencing that these days, however, I`d like to ask, if all that above does apply in a case when monitor turns on eventually and then runs as nothing is happening? In my case, I get the black screen after 2-3 seconds, but then if I try to turn the monitor off and on several times, eventually it turns on and works properly. It takes about 20 minutes turning it off and on, sometimes longer, today it took much longer, but the monitor turned on finally and runs. Once I turn the monitor off, I`m in the "2 seconds to black" issue again.
    Should I look for another possible cause to the problem in addition to the ones listed above?
  • Rick_1234
    LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
    by Rick_1234
    Good evening, gentlemen.
    I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
    To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
    https://drive.google.com/file/d/1L6S...ew?usp=sharing
    Things I tried
    - Bought a new AC adapter thinking that was the problem but the problem...
    06-22-2024, 04:44 PM
  • sew333
    Pc shutdown, monitor flickered with no signal after 10 seconds
    by sew333
    My pc:
    10850K stock 4800mhz stock Kraken X73 good temps
    2x16 GB DDR4 GSKILL 3000mhz XMP
    Seasonic Tx-850 Ultra Titanium
    Gigabyte Rtx 3090 Gaming OC
    Aorus Z490 Pro Gaming
    1 TB SSD
    4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
    Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
    Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
    Power...
    02-22-2022, 10:27 AM
    by momaka
    03-15-2023, 10:17 PM
  • keepread
    Dell monitor PSU vs Dell laptop PSU
    by keepread
    Hi there!
    Someone gave me their old monitor, it's Dell S2715ht.
    The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
    Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
    10-30-2025, 04:45 PM
  • DanPoka
    Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
    by DanPoka
    I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
    Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
    This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
    02-15-2025, 05:05 AM
