Samsung Syncmaster 245BW
  • nordhaus
    • Apr 2012
    • 21
    Re: Samsung Syncmaster 245BW
    All great tips from retiredcaps!
    Yes, I tend to be a tool junkie, but I try to make purchases with other purposes in mind as well. My pry tools will also work well for some of my other hobbies/tasks. And I've been wanting a step up soldering iron for over a decade now (I don't even know the wattage setting of my old Radio Shack model, and I never liked using it). The Hakko was a pleasant surprise to use!
    I also have 3 Samsung monitors of similar vintage, so I fully expect that at some point I'll be tearing into those too at some point.
    I did forget to mention my Multimeter. Mine is an Ideal brand (includes a temperature probe function too).......I got it from Lowe's and it cost about $35. I got it because it had numerous functions, and also had a huge digital readout (I have bad eyes). I've used other Ideal products (computer networking and network line continuity testers) and have been happy.
    Lowe's and Home Depot do sell the cheapie models too, but I'd be wary of those. They don't look too good.
    N~
      Hair dryer is another good tool, same for the Compressed air duster use it upside down for cooling components.
      • jetadm123
        • 2169
        #503
        Great work nordhaus! Just out of curiousity, if you still have original cap CM802, can you please do a quick resistance test with your meter? I'd be interested to know if it opened or shorted out. Even better if you can measure capacitance on your meter. Thanks!
        • nordhaus
          • Apr 2012
          • 21
          Ugh, sorry! Once I put in the CM802 replacement and saw that the monitor suddenly began working, I tossed the old one out. Not that this is a good indicator, but on visual inspection, the old capacitor looked fine - no bulges or burn marks or other unusual marks. It was also solidly connected (I noted earlier in the thread that someone had a CM802 that was partly broken off their board).
          Earlier, I did change the RM resistors as well, as one of them was definitely out of spec (I measured that one, earlier in this thread).
          N~
          • G_Sup
            • Apr 2012
            • 4
            New here! I found this topic via Google and boy am I happy I found you! I had the same symptom as a few of you here... blue light, but no screen. After reading through this whole thread I was about to replace all capacitors and resisters using a kit for the 245BW which can be found on Amazon. A few said that the culprit was one bad resister, so I started with that. BOOM! My monitor works!!!!! Thanks so much!
            • G_Sup
              • Apr 2012
              • 4
              Here is the pic of the culprit!
              • selldoor
                Slow Learner
                • 7870
                #507
                Well done G Sup - you may want to consider why the resistor went bad - was it because of the caps not functioning correctly?. To extend the life of your monitor you should
                think about changing the caps anyway.
                • G_Sup
                  • Apr 2012
                  • 4
                  Great point! I will later on for sure since I have all of them. I really need to buy a better solder though. My wife uses the monitor and she doesn't use it as frequently as I use my computer, so I'll do it in the near future.
                  • slidewire
                    • Feb 2011
                    • 10
                    #509
                    Samsung, model# 245BW (LCD Monitor)--
                    Symptom: no backlight, no grid; and there is no significant bias voltage going to the inverter board.
                    Cure: RB805 (68 ohms; open) located on power module.
                    • G_Sup
                      • Apr 2012
                      • 4
                      I believe that was the resistor I was explaining?
                      • nabob
                        • Apr 2012
                        • canada
                        #511
                        Thank god I have found you, I was about to throw my 245BW at the trash when I did a google search and came across this post! I had the power light still on and no image, I have no welding experience and I even replaced the three fault resistors RB805-806-807! And YAY! it works. A welding kit cost me $ 15 and has three resistors for $ 1. I save hundreds of dollars cause the monitor is back in business and work flawlessly since 3 days now 24 hr a day thanks to you guys! Thank you all very much
                        • JMSki
                          • May 2012
                          Here is a pdf scan I came across while troubleshooting my 245BW Syncmaster. I believe it ties in with Aruba's post.
                          • Whiskey 7
                            Hello all.
                            I just wanted to throw my thanks to all who contribute to the information herein.
                            Thank you very much
                            I have had my beloved Samsung 245b some years when it "winked" out one day weeks ago to my horror..
                            I dashed out and lashed out and bought a pair on 23" LG monitors (they're so light these days)... and they weren't quite the same and my challenge was to get the old 245b working again...
                            I googled and found some information and jumped straight in and bought a repair kit for like $25 (AUD).
                            I googled some more and found and read some more suggestions and thoughts here.
                            Well, I initially replaced those 3 resistors mentioned frequently here and she fired up and I have the caps if I feel the need.
                            My only advice if you will, is to replace those first, then try and get the picture as I did. It might just save you some extra work and grief.
                            Again, thank you to all those contributors.
                            • bradh
                              • Jul 2012
                              Thanks for all the tips on here. My monitor was making a clicking noise as mentioned in this thread. After a day or two of clicking the screen went blank but the blue power light was still on. I found the RB805 resistor bad. I replaced it and the two next to it and it fixed the problem. Hopefully it holds.
                              • rmg_hrr
                                • Mar 2012
                                • 27
                                • India
                                #515
                                Hay all I am having 2043NWX monitor and get Blue screen and no signal message pops if remove the input, also replaced most of the caps.
                                here is the link to thread I posted https://www.badcaps.net/forum/showthread.php?t=19613
                                which resistor you are taking about?
                                Will my monitor work if I replace it?
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  #516
                                  @rmg hrr I am having some difficulty in understanding why you have posted in this thread
                                  you do not have a 245BW and the boards do not bear any resemblance If you read the thread there are clear pictures of the boards and the resistors?.
                                  Unless you have anything useful to add do not post here - use your own thread.
                                  • Philboye
                                    • Jul 2012
                                    • 3
                                    Hi guys, I am new to the forum so please bear with me if this has been discussed before.
                                    I am trouble shooting a 245BW power supply and like many have no 5.3 V or 24V. I had one bad bulged cap (1000 uf) but replaced three of the four in that area (one 2200 uf, two 1000 uf). I also have an open circuit on on RB805 (68 ohm). I am only getting 165V on the bulk cap CP803 instead of 380v (the cap is slightly bulged).
                                    So my questions are 1) instead of replacing the three series 68 ohm resistors why not use one 200 ohm 2 watt?
                                    2) Has anyone experienced the bulk cap (82uf) having a low voltage like 165V? Was the issue the cap?
                                    Philboye
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      #518
                                      NO, don't change the components. The 3 resistors are there for a reason. It could be acting as a voltage divider.
                                      You can put in bigger watt resistors as others have done.
                                      The PFC won't turn on until you fix the resistors and change out the bad caps. After that, the PFC should turn on.
                                      If you think the large filter cap is bulged, post a picture of it following instructions in my sig file below exactly.
                                      --- begin sig file ---
                                      --- end sig file ---
                                      • jetadm123
                                        • 2169
                                        #519
                                        Philboye
                                        Since the 3 resistors are 68 ohms 1/2W each connected in series, you have a total of 204 ohms 1.5W. The 200 ohm 2W resistor should work. You just need to figure out which 2 out of the 6 holes you solder the resistor to.
                                        You're probably seeing 165V across CP803 because the PFC circuit has not started yet. Once it starts, the voltage will increase.
                                        Ha hah! retiredcaps beat me to it!
                                        • tibimakai
                                          • Jan 2012
                                          • 3680
                                          I'm fighting with one of these too (173A power supply).
                                          I haven't found anything wrong, but I have replaced the most common components, since I will be keeping this monitor for myself.
                                          Electrolytic capacitors, including the 82uF were replaced w/Pana FM/FC(except the 82uF) ones. I still have to replace the 18nF, will do it today.
                                          I have replaced the 3x68 Ohm/2W resistors which they get very hot at the moment.
                                          My problem is as everybody else's, black screen, power button is solid blue and no 5.3V or 24V(they are 0V). PFC stage won't start, it sits at 165V. No PS_ON voltage, only ST_BY.
                                          I have ordered F9222L IC, just in case that I will need it. I haven't figure out the pin layout of this IC yet, but preliminary measuring doesn't look good. Measuring at three pins way to high voltages, 2x 150V and one 165V(this is probably fine). The rest of the pins are pretty much 0V.
                                          What else can I check? I have read through many posts about these monitors, but nothing seems the same as mine. I haven't checked the BR/BQ transistor yet, but I have ordered a BR transistor just in case.
                                          I will try using a power supply on the PS_ON pin, see if anything happens.
                                          These monitors need the same 3.3V?
                                            09-07-2024, 05:50 AM
                                          • soopacrucial
                                            by soopacrucial
                                            Hi folks,
                                            10-29-2024, 02:40 PM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
