Benq G2255 doesn't power on - amber power light when plugged in
+ More Options
Posts
  • rddube
    Aspiring Expert
    • Jun 2013
    • 950
    Re: Benq G2255 doesn't power on - amber power light when plugged in
    Ok, so I took voltage readings on the MP10091 with all 3 resistors in place:
    Pin 1: 5.54V
    Pin 2: 0.136V
    Pin 3: 0.136V
    Pin 4: 0.092V
    Pin 5: 0.0V
    Pin 6: 1.207V
    Pin 7: 3.58V
    Pin 8: 3.91V
    Pin 9: 5.54V
    Pin 10: 0.0V
    Pin 11: 0.0V
    Pin 12: 5.88V
    Pin 13: 13.3V
    Pin 14: 13.01V
    Pin 15: 15.22V
    Pin 16: 15.19V
    • Dumah Brazorf
      • Jun 2013
      • 179
      • Italy
      #62
      I think you read the right side top/bottom instead of bottom/top.
      If R804 is dropping 5V it should passing ~0,5A so 2,5W. It should be hot.
      • rddube
        Aspiring Expert
        • Jun 2013
        • 950
        You're quite right Dumah, my error. Should look like this, sorry for the error:
        Pin 1: 5.54V
        Pin 2: 0.136V
        Pin 3: 0.136V
        Pin 4: 0.092V
        Pin 5: 0.0V
        Pin 6: 1.207V
        Pin 7: 3.58V
        Pin 8: 3.91V
        Pin 16: 5.54V
        Pin 15: 0.0V
        Pin 14: 0.0V
        Pin 13: 5.88V
        Pin 12: 13.3V
        Pin 11: 13.01V
        Pin 10: 15.22V
        Pin 9: 15.19V
        • Dumah Brazorf
          • Jun 2013
          • 179
          • Italy
          #64
          Maybe you should use a 10k resistor for the white connection.
          Check resistance of your lamps leads and on the blue high voltage caps.
          • will62
            • Dec 2016
            • 229
            • usa
            #65
            Can you flip your meter over to AC and remeasure pins 1,2,3 & 16?
            • rddube
              Aspiring Expert
              • Jun 2013
              • 950
              Ok, checked the resistance on the lamp leads and I get for both 0L. Also, c831 and C834 give me 0L and C817 gives me 449ohms.
              • rddube
                Aspiring Expert
                • Jun 2013
                • 950
                Switching my meter to AC gives me the following:
                Pin 1: 15.4mv dropping
                Pin 2: 5.5mv dropping
                Pin 3: 15.2mv dropping
                Pin 16: 21.6mv dropping
                • rddube
                  Aspiring Expert
                  • Jun 2013
                  • 950
                  Will62: You asked me if I have an oscilloscope in another thread, and yes I do. It is a very basic one JYE Tech DSO138 (those small chinese Oscilloscopes that come in a kit) but it works!
                  • will62
                    • Dec 2016
                    • 229
                    • usa
                    #69
                    OK, chip appears shut down. I'm adding another pic with the voltages you measured. About this time, I'd be looking for gate pwm signal with the oscope.
                    But you won't see it if chip is down. Let's see what Budm recommends.
                    One oddity: Both gate drives should be 0V if chip is down. You have 0V on BG (bottom), But 13V on TG (top).
                      I would put the scope pin on the GATE drive pin and keep it there then power up the board and you should see the drive signal, if the drive signals are present for both GATE that means the inveter transformer primary will get the drive Voltage and will try to fire up the lamp if that does not happen then to protection will kick in, or if it detects over current when the MOSFET are driven, the protection also kicks in, this will happen very fast. the circuit will have to try to drive the lamps first if there is problem (I.E lamp do not conduct) within set time then protection will kick in.
                      The typical protection circuit used in the CCFL will shutdown the circuit:
                      1) It will detect if the lamp will conduct current and stay conduction when the Firing Voltage is applied to the lamps, if the lamps do not conduct then the shutdown occur. The detection circuit detect the error on the lamp return side of each lamp, so one bad lamp will shutdown the circuit. Some circuit may try to fire up the lamps up to three times.
                      2) if the lamps are not connected then it will detect no lamp current flow due to no load connected so you do not want to have over 1000V at the lamp connector present without load otherwise it will start arcing to the near by circuit.
                      3) Over current will also shutdown the circuit.
                      Some circuit may have 3 seconds timer, if the false is present during the first 3 seconds then the circuit is shutdown, thus 3 seconds to black, everything has to be working within 3 seconds for the circuit to stay on.
                      The MP1009 looks to have only 300mSec.
                      • rddube
                        Aspiring Expert
                        • Jun 2013
                        • 950
                        Hello gentlemen,
                        I have to admit that at this point, I feel a little confused although I understand your explanation Budm, I think this is getting beyond my skills for repair.
                        We are trying to get the inverter working, but I also have a problem with the logic board, so down the end, it might not be economically viable to repair this monitor? What do you think?
                        Also, there seems to be 2 gates but only one Mosfet and one inverter transformer?
                        Budm, you didn't comment on this quote? Is this normal?
                        On the mosfet, I measured again between S1 and D1 and get 475K, on S2 and D2 I get 47K?? Should I be measuring it out of circuit? On that topic I succeeded in removing a AF4910N from the other board. When I measure S1 and D1, I get mega ohms resistance, same from S2 to D2.
                        • Dumah Brazorf
                          • Jun 2013
                          • 179
                          • Italy
                          #72
                          Q808 is 2 mosfets in 1 package.
                          The circuit alter readings indeed.
                          • rddube
                            Aspiring Expert
                            • Jun 2013
                            • 950
                            If I remove AP9962AGM and it is not good, I haven't been able to find any of those chips on the net, seems they don't sell them anymore??
                            • will62
                              • Dec 2016
                              • 229
                              • usa
                              #74
                              This one is pretty close. You can get 3pcs. for ~$7 (non-rohs?). (shipping would take about 2-3 weeks)
                              https://www.ebay.com/itm/3PCS-AP9962...oAAOSwLVZVj0~5
                              As far as the 13V on pin 11 (Top gate drive), can you lift pin 4 on the mosfet so we can see if the 13V is coming from inside the driver chip or from the mosfet?
                              On similar circuits, pin 12 (SW, 13.3V) connects to source2, drain1 and the transformer primary. I know we should have voltage on source2, but I don't think that we can get voltage on gate2 without a short.
                              If you decide to continue on the project, you could try one of the 30V mosfets, just so you could move on in the troubleshooting.
                              This mosfet could work as well. It is $0.86 + shipping:
                              https://www.mouser.com/productdetail...Gz3mDeSA%3D%3D
                              • rddube
                                Aspiring Expert
                                • Jun 2013
                                • 950
                                Ok, so I did lift pin 4 from the mosfet and still get 13V on pin 11, so it's coming from the driver chip.
                                So what do you think a next step could be, change the mosfet for the 30V one?
                                • will62
                                  • Dec 2016
                                  • 229
                                  • usa
                                  #76
                                  I would go back to post#70 and do what Budm recommended. While you've got everything set up, go ahead and look at the pic in post #65. Check the waves on OV1,2 & LI1,2. Check voltage ripple as well. As Budm mentioned, shutdown will happen quickly, so you need to start each test from power off, caps drained.
                                  Some other notes:
                                  1. Based on the 13V not coming from gate, and your previous mosfet checks, that mosfet may be OK.
                                  2. We have a pin-out of the MP10091ES, but no datasheet. I've been going back to the MP1009 datasheet, hoping that the pin specs are similar. They may not be.
                                  3. If chip is shut down, I'd expect both gate drive pins to be 0V. I may be wrong here, need someone else to chime in.
                                  4. The datasheet for Mp1009 shows that the max pwm voltage on pin 8 (dbrt) is 2V. Right now we have 3.9V jumped to that wire. Is that causing a problem? May be different for MP10091ES.
                                  Hope you don't quit, it's just starting to get interesting.
                                  • rddube
                                    Aspiring Expert
                                    • Jun 2013
                                    • 950
                                    So I decided to take the plunge and change that AP9962 for the 30V version AF4910N, and guess what!
                                    Well first after doing the switch of Mosfets, I plugged everything back main board, CFL connectors, etc. and plugged in the monitor - amber light just like when I started. Then I remembered Budm saying I probably have 2 problems, i.e. mainboard and power board.
                                    So I did the 3 resistor setup without main board, plugged to the CFL's and bingo, they turned on for about 2-3 seconds and went out. I unplugged the powerboard, waited a few seconds, plugged in and CFL'S came on and stayed on for approximately 10 seconds. I unplugged the power waited again another 5-10 seconds, plugged it in again and this time nothing - zilch. I did the test 3 or 4 times and they wouldn't come on again.
                                    So I unplugged everything, kept the resistors in and went and took voltage measurements on the chip and got exactly the same results as before from pin 1 to 16 - exactly.
                                    When I changed the Mosfet and before applying power, I got approx 475K ohms between S1 and D1 and approx 370K between S2 and D2. Now after the test and everything I get 1.2 mega ohms between S1 and D1 and about the same thing between S2 and D2.
                                    What do you think?
                                    • rddube
                                      Aspiring Expert
                                      • Jun 2013
                                      • 950
                                      Will62, Mouser charge 20$ to ship to Canada. Do you think this could be good, as Digi-Key charge 8$ shipping. How many should I get, considering that there is something else which blows the Mosfet?
                                      https://www.digikey.ca/product-detai...6-1-ND/4862961
                                      • will62
                                        • Dec 2016
                                        • 229
                                        • usa
                                        #79
                                        I would get 3.
                                        • rddube
                                          Aspiring Expert
                                          • Jun 2013
                                          • 950
                                          I plan on changing the Caps on this board, so will be ordering a set of caps. Is there anything else I should get like the blue cap that measures 475ohm, would that be a cap to change? Is there any caps related to the Mosfet that should be changed?
                                          Tks.
                                          • huzo
                                            HP 470 G5 blinking amber light no power
                                            by huzo
                                            The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
                                            So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
                                            I've tried flashing the bios...
                                            interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
                                            06-08-2023, 04:08 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • zwect
                                            Dell Latitude 5420 / GDF40 LA-K491P REV 3.0 / Amber / Orange light when power button is pressed
                                            by zwect
                                            I have this Dell Latitude 5420 with ST: CMF62F3, board GDF40 LA-K491P REV 3.0 that does not power on, i already searched for some clues about this problem that happens on mine but no BIOS i downloaded and flashed did anything.
                                            Only when the power brick is connected, when pressing the power button an amber light lights up at the front and slight decreases its brightness, the RAM and the CPU seem to heat up if the laptop is left connected but nothing else, other than USB devices getting powered.
                                            Here is the original BIOS dump from the 25R256JVEN chip.
                                            09-11-2024, 05:54 PM
                                          • ipatch
                                            troubleshooting microsoft surface pro 4 no power no led charge light
                                            by ipatch
                                            hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                            10-05-2023, 11:59 AM
                                          • russpall
                                            LG 39ln540v - red light flashes twice, no power to LED driver?
                                            by russpall
                                            Hi there,
                                            I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                                            The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                                            08-27-2024, 01:07 PM
