Benq G2255 doesn't power on - amber power light when plugged in
  • rddube
    Aspiring Expert
    • Jun 2013
    • 907
    Re: Benq G2255 doesn't power on - amber power light when plugged in
    Will, just in case (it might have no bearing) but R802 is a 304 resistor which is 300K ohms, and I get 25K ohms across it?
    Ok, for resoldering the 2 pin and removing jumpers. I will also resolder every through hole component from the transformer pin 7 to CN801, including CN801.
    Thanks again for your incredible support and knowledge!
    • will62
      • 229
      • usa
      #142
      Something quick to check... R838, R839 & R837 are used in the current detection circuit on cn801. R842, R843 & R841 are for the cn802 circuit. The pairings below should be very near each other on resistance check:
      R842-R838
      R843-R839
      R841-R837
      Also, is D801 marked "A1"?
      • rddube
        Aspiring Expert
        • Jun 2013
        • 907
        Pairing of :
        R842-R838
        R843-R839
        R841-R837
        read the same value.
        Also, is D801 marked "A1"? Yes it is marked A1.
        • will62
          • 229
          • usa
          #144
          Replying to your question about R802:
          C805 and R802 go to pin 7. That is your enable pin. C805 is to remove ripple from the signal, and R802 is pulling the pin low to keep the chip off until it receives a sufficient voltage from your main board. We know the chip is running, so R802 is not a problem.
          • will62
            • 229
            • usa
            #145
            The attached is a pin-out on that diode. Please check it. If not 100% sure on checking, watch a video on checking a diode.
            • rddube
              Aspiring Expert
              • Jun 2013
              • 907
              These are the readings I get on D801.
              • will62
                • 229
                • usa
                #147
                You're going to have to lift the top pin, or take the diode out of circuit. In diode mode, reverse biased (red to either of the bottom pins) meter should read OL.
                • rddube
                  Aspiring Expert
                  • Jun 2013
                  • 907
                  Hi Will,
                  I'm a little nervous about removing the diode or lifting the top pin, because last time I worked on a diode I guess my iron was too hot, so I killed it. Do you have any advice on how I should heat it (like not more than XX degrees)? I checked my inventory of used parts (motherboards, pcb boards, etc.) and didn't find another A1 diode, so this is the only one I have. If I kill it, I could get some from Digikey, but any advice you can give me on how to work it would be welcome! Tks!
                  • will62
                    • 229
                    • usa
                    #149
                    Before attempting the diode lift, check your other boards for same size diodes, and give me the markings on them. In the mean time, I'd like to rule out connector problems. Going to need you to take some resistance readings. With lamp connectors plugged in, back probe each wire and take resistance to the points in the pic. Just give me color and resistance. If you don't have back probe tips, put an alligator clip on a pin or needle. Follow the wire in from the back of the connector until you hit the metal barrel.
                    • will62
                      • 229
                      • usa
                      #150
                      For the diode lift/removal, try ~350c. Go a little higher if solder is not melting quickly. Adding flux and fresh solder helps a lot. Practice on your old parts boards first. Watch the video below. We're going to have to get back to that diode pretty soon.
                      https://www.youtube.com/watch?v=LADgxZgyJ04
                      • rddube
                        Aspiring Expert
                        • Jun 2013
                        • 907
                        ok,
                        Blue: .3 ohm
                        Red: .4 ohm
                        Yellow: .4 ohm
                        Black: .4 ohm
                        Some other diodes same size I have on boards are:
                        A7W (lots)
                        DB6
                        5D
                        AAAA (not sure if this is a diode)
                        3D
                        5C
                        B6
                        and probably some others.
                        • rddube
                          Aspiring Expert
                          • Jun 2013
                          • 907
                          Ok, Will thanks for the advice. I practiced on a few diodes on scrap boards with flux and fresh solder and wick and it's working! I feel much more confident. Had my iron set at 350 degrees with a flat tip and it works pretty well.
                          Ready when you say go!
                          Tks
                          • will62
                            • 229
                            • usa
                            #153
                            No problem with the connectors. Try lifting that top pin on d801 and recheck
                            the diode. I'll look into those markings that you listed.
                            Also, can you give me the resistor values for those 3 pairings on post #143?
                            • rddube
                              Aspiring Expert
                              • Jun 2013
                              • 907
                              Here you go for the resistor values. Off to my surgical task of lifting that leg. Will report in a few minutes.
                              • rddube
                                Aspiring Expert
                                • Jun 2013
                                • 907
                                Ok, Will, checked the diode. Lifted the pin, was fairly easy with your guidance.
                                Measuring in diode mode, black to lifted pin and red to either of the 2 other pins I get 0L. When I reverse the probes, I get .580V on one and .582V on the other.
                                Does that mean the diode is good?
                                Will, you mention in an earlier post while we were diagnosing with the jumpers on pin 2 and 3 and 1 and 16 that we have an over current problem? Can we not measure current at different points on the trace of CN801 to see where it might be coming from while we jumper C803? Probably a dumb question, but my Fluke measures milliamps.
                                • rddube
                                  Aspiring Expert
                                  • Jun 2013
                                  • 907
                                  Another thing to consider. On CN801, coming from the transformer there is a blue cap (C831) on the trace from pin 7 of the transformer going to ground and it is marked
                                  10J
                                  3KV
                                  Whereas on the CN802 connector line coming from the transformer pin 8 I see a blue cap (C834) on this trace to ground marked
                                  8
                                  3KV
                                  SEC
                                  Why different values? Shouldn't they be the same?
                                  • will62
                                    • 229
                                    • usa
                                    #157
                                    Diode checks good, you can put it back down. The chip is measuring amperage by checking the voltage drop across a known resistor, so it's actually looking for the voltage to be in a certain range.
                                    Might be a good thing to check the actual current on each connector so that we can see if there is a significant difference between them, or the chip just thinks there is because of an out of range component in the circuit.
                                    You'd have to lift the end of R841 and R837 (one at a time), and measure current between the lifted end of resistor to the pad it was lifted from. Power on, check lights and measure amps. (jumper on pin5)
                                    • rddube
                                      Aspiring Expert
                                      • Jun 2013
                                      • 907
                                      Will, also in post #127, did you notice Vmax on pin 2 and 3 with the cfl's in the original position? Quite a difference in voltage?
                                      Or is it my oscilloscope that is not that accurate?
                                      Will try to do the current testing (never have done current testing in the past, I think I need to change where I plug my probes in the Fluke, but I'll check) probably tomorrow night. Having a snow storm here which will last overnight so will have to get on the road early so as to not be late at work.
                                      Have a good evening and talk to you tomorrow. And again, thank you!
                                      • will62
                                        • 229
                                        • usa
                                        #159
                                        C831, C833 & C832 form a capacitive voltage divider for the chip to monitor voltage on cn801. The values are critical. You can see that they had to parallel
                                        C833 and C832 in order to get an accurate divider. C834, C835 & C836 serve the same purpose for connector cn802. We don't have a voltage problem on the chip, so I would leave well enough alone with all 6 of those.
                                        What I am curious about is C817. What is it marked, and do you have a possible replacement on another board?
                                        Edit: I'll look back at those voltages. You're welcome and stay safe on those roads.
                                        • rddube
                                          Aspiring Expert
                                          • Jun 2013
                                          • 907
                                          Ok, but C831 and C834 don't have the same values. But the other 2 caps on each line looks to be excactly the same (they are SMD so I am going by color and size) on each line.
                                          In fact C817 is marked the same as C834
                                          8
                                          3KV
                                          SEC
                                          and it is close to C831. Could they have inadvertently been swapped during fabrication? Should I try and swap them around?
                                          No, I don't have another a replacement for 8 3KV SEC, in fact they don't have them on DigiKey either. Momaka mentionned in thread #111 "It's probably an 8.2 pF capacitor (as that's a standard value).", but I don't have any marked exactly like that. The spares I have are marked 5 on another inverter board and all sorts of marks on caps from scrap power supplies (I can see 3KV) at the AC entrance, but not sure what the other values are. I can unsolder some and give you the exact markings if you want me to.
                                          • huzo
                                            HP 470 G5 blinking amber light no power
                                            by huzo
                                            The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
                                            So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
                                            I've tried flashing the bios...
                                            interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
                                            06-08-2023, 04:08 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • zwect
                                            Dell Latitude 5420 / GDF40 LA-K491P REV 3.0 / Amber / Orange light when power button is pressed
                                            by zwect
                                            I have this Dell Latitude 5420 with ST: CMF62F3, board GDF40 LA-K491P REV 3.0 that does not power on, i already searched for some clues about this problem that happens on mine but no BIOS i downloaded and flashed did anything.
                                            Only when the power brick is connected, when pressing the power button an amber light lights up at the front and slight decreases its brightness, the RAM and the CPU seem to heat up if the laptop is left connected but nothing else, other than USB devices getting powered.
                                            Here is the original BIOS dump from the 25R256JVEN chip.
                                            09-11-2024, 05:54 PM
                                          • ipatch
                                            troubleshooting microsoft surface pro 4 no power no led charge light
                                            by ipatch
                                            hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                            10-05-2023, 11:59 AM
                                          • russpall
                                            LG 39ln540v - red light flashes twice, no power to LED driver?
                                            by russpall
                                            Hi there,
                                            I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                                            The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                                            08-27-2024, 01:07 PM
