LCD 19" BENQ T905 problems
  • capullaco
    • Aug 2010
    • 40
    #41
    Re: LCD 19" BENQ T905 problems
    In pairs? What do you mean? The others seem ok,which other should I replace?
    • capullaco
      • Aug 2010
      • 40
      #42
      The diodes are ok
      Really,thanks a lot retiredcaps,not only youre helping me,but im learning a lot.
      Again,thanks.
      • capullaco
        • Aug 2010
        • 40
        #43
        Ok,found another blown transistor.
        I have marked them on the pic attached.
        Between them there is a gray box called C826
        Is like the 2nd pic attached.
        It has a "K" on top, and on one of the sides reads:
        R75 MP
        .22 160
        T2 05MLK13
        What type of capacitator is? Which mesure? Is there any way to test it with the multimeter?
        • Rtech
          • Jul 2010
          • 1095
          #44
          If it looks in good order,ie. not swollen or split,then it is probably Ok,I have never seen one of these fail ....YET.Just ensure that you resolder the pins, because dy joints on these do happen regularly.
          • retiredcaps
            • Apr 2010
            • 9271
            #45
            Yes, that I is what I meant by fail in pairs.
            http://en.wikipedia.org/wiki/File:Condensators.JPG
            http://en.wikipedia.org/wiki/Capacitor#Capacitor_types
            This picture is much better than the original. In the original, we could not see the entire board because of the angle.
            That is why clear focused top down view pictures are so valuable.
            --- begin sig file ---
            --- end sig file ---
            • capullaco
              • Aug 2010
              • 40
              #46
              Shape seems OK, but it was between the 2 blown transistors, so I thought it could be blown also...
              • capullaco
                • Aug 2010
                • 40
                #47
                What is the value of the polyester caps?
                Someone said, 220 nF 160V but I have read on another site that is 0,022 micro F.
                Maybe the guy misspelled it and added a 0?
                AFAIK 220nF = 0,22 micro F
                On one side of the cap says " .22 160 " but is 0,22 pico? nano?
                On top of the cap there is a "K".
                • PlainBill
                  • Feb 2009
                  • 7034
                  One quick and easy way to get the answer to this is to go to a site such as Digikey or Mouser. Look up the physical size of .22 uF, 22nf and .22nF 160 volt caps. It becomes very easy to determine which is correct.
                  PlainBill
                  • capullaco
                    • Aug 2010
                    • 40
                    #49
                    Ok, after changing the blown transistors and fuse, and replacing all the Elite caps I tested the display.
                    It showed the BenQ logo!...but it just stayed for 2 secs, and it wasnt properly lighted, like if the brightness was low.
                    Between those 2 secs, there are some artifacts, like color inverted image,etc..
                    Also, the display started to stink a bit, so I disconnected it.
                    What can it be now?
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #50
                      What can it be now?
                      Did you resolder all the transformer pins and other components as suggested in post #21?
                      • capullaco
                        • Aug 2010
                        • 40
                        #51
                        Err...no
                        Which ones are the transformers? The box like ones?
                        • jetadm123
                          • 2169
                          #52
                          Err...no
                          What retiredcaps is talking about are the 4 inverter tranformers. If you look at the first photo in post #26, they are the 4 small square yellow boxes on the left side of the photo. You should use desoldering braid to soak up the old solder from the transformer pins and then apply new solder. Do this for all 4 transformers.
                          • capullaco
                            • Aug 2010
                            • 40
                            #53
                            Ok im gonna try. But do you think those fuckers are gaving those problems? The display started to stink when I turned it on
                            • capullaco
                              • Aug 2010
                              • 40
                              #54
                              Ok, so I was going to resolder the transistors today,but tried the display first.
                              Its broken again
                              Guess Ill have to change the fuse and the transistors again
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #55
                                Read post #21. Look at the very last sentence.
                                • capullaco
                                  • Aug 2010
                                  • 40
                                  #56
                                  Ok, my mobile is working again.
                                  Took photos of 'problematic' bits:
                                  Code:
                                  Photo number. Description
                                  1. Those are the transistors that were originally blown.Theyre blow again (the left arrow actually indicates the trans,not the cap :p)
                                  2.The bottomside of those transistors.Those 2 yellow points,are bridged (they have continuity and the polimeter beeps with the diode/continuity beep setting).
                                  Im not sure if they should be bridged... One is a pin of the 'K' cap of the 1st pic and the other one is a SMD named "JR10"
                                  3.Those are another bridged point.The cap pin is bridged with a drop of tin that it was already on the board.I think its ok
                                  4.I tried to compare those bridged with the image posted here, but im not sure, so I marked them
                                  5.Two new blown transistors.I dont know if they were blow before, but theyre now.They have a heatsink and theyre glued to it.
                                  Also, theyre special and are larger with a hole for a screw. Its one piece, I mean its not a transistor glued to another one. Wonder if I will be able to buy that type of transistor...Also, I dont know they ID, but I guess the guy in the shop will know.
                                  6.Those are the things I have to resolder right? Are they marked correctly? What are those two things marked as '?' ? Should I resolder them also?
                                  7.Finally, this is the bit I said it was burnt.but the transistor under it its fine.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #57
                                    Yes, because you chose to ignore 3 people telling you 4 times to resolder the transformers. This problem with the Benqs has been known for about 2 years now. When people say you *must* resolder the transformer it is because they have experienced what you have.
                                    We can lead a horse to water ...
                                    Here is the technical explanation why the transistors short out.
                                    https://www.badcaps.net/forum/showpo...&postcount=269
                                    A poor analog might be the following (I can see PlainBill shuddering right now). Imagine a car engine as the transformer. When the bolts holding down the engine are loose, it shakes all the components of car.
                                    You take the car to the mechanic (Eric the car guy). Eric says I can fix the loose radio, loose hoses, loose steering wheel, etc from all the damaged caused by the engine for $500.
                                    Eric also HIGHLY recommends that he rebolts and remounts the engine. It will cost $1000. You balk. 2 days later, the engine causes the same damage. This time Eric charges you $1000 because the engine caused more damage than the first time.
                                    Eric again recommends remounting and rebolting the engine, but this time it is $1500 because of more damage. You balk again.
                                    And so on ...
                                    2.
                                    If you follow the circuit green pcb trace you should be able to tell if they are on the same circuit path or not. If they are, then it is not a problem if they are bridged.
                                    I started here on these forums back in April 2010, but I can't remember a single case where a bridged connection has been documented as a problem.
                                    I asked a similar question. See
                                    https://www.badcaps.net/forum/showth...+solder+joints
                                    That is a good idea, but be aware that there are possibly many revisions of this board. Manufacturers can change the boards as they see fit.
                                    The picture's angle makes it hard to see, but those are probably dual diodes? They should have 2 diode symbols pointed towards the center.
                                    What measurements did you get for these dual diodes?
                                    Yes, resolder those. L indicate an inductor. T is a transformer.
                                    Some browning is normal. As long as the transistor underneath tests okay, it is fine.
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      #58
                                      One other suggestion.
                                      Once the new parts come in, check them all out of circuit to ensure they are good.
                                      When you get all the repairs done, put away the monitor for 2 days. Come back 48 hours later with post #21 printed and go through each sentence top to bottom and bottom to top (i.e doublecheck all your work).
                                      That will give your brain some time to process the repair.
                                      Additionally, BEFORE you power up. Doublecheck all the components again to make sure they are soldered in properly, oriented correctly (not backwards) and retest them with your mulitmeter "in circuit".
                                      Then and only then, apply power.
                                      • capullaco
                                        • Aug 2010
                                        • 40
                                        #59
                                        Thanks again retiredcaps.
                                        If I didnt resolder the transformers, its because I wasnt sure which ones were them, until jetadm123 pointed them out.
                                        That being said, I also didnt research more, because after checking that the fuse and the transistors were blown, I thought that those were all the problems the PCB had.
                                        One thing im still not sure:
                                        Code:
                                        Desolder all 4 transistors and the polyester caps (between the transistors
                                        Is the polyester cap the 'K' cap from my first pic? Theyre 2 so it makes sense, but just to be sure.
                                        About the dual diodes, yes they are.Theyre named "DXXX" and they have this printed on one side:
                                        YG902C2
                                        -->|--|<-- CI
                                        40 121
                                        I managed to unstick them from the heatsink.
                                        But how do I test them? I tried this but I dont know if its correct:
                                        - Black (COM) on 2nd pin RED on 3rd: 400
                                        - RED on 1st pin BLACK on 2nd: 400
                                        Those values are with the diode setting ( -->|) of the polimeter. Other combinations didnt show results.
                                        The things I need to resolder, I just need to unsolder them and sold again with new tin or is there any other action involved? I ask because the soldering on those things seems ok , at least on looks.
                                        One more thing, should I resolder those things marked as '?' on the 6th pic?
                                        • PlainBill
                                          • Feb 2009
                                          • 7034
                                          And so on ...
                                          Actually, that is an excellent analogy. You teach well, Grasshopper!!
                                          PlainBill
                                          • Caspar
                                            BENQ GW2780-T power board blown
                                            by Caspar
                                            Hi all, I am looking for some help in ID'ing some parts in an attempt to fix a power supply from a GW2780-T monitor. The power supply PN is 715G7300-P02-006-0V3R. I have been looking around for the PN and it appear the board was used by other OEMs as well (ASUS, Viewsonic). If anyone has a schematic, it would be helpful.
                                            Quick look on the underside of the board, I can see:
                                            -D905 is blown - ? value
                                            -R920 is open - 1Ω ?W
                                            -R927 is open - 20Ω ?W
                                            On top side, I see:
                                            -R931 open - 0.68Ω ?W
                                            Metered short:
                                            -P9NK65ZFP...
                                            06-01-2022, 05:16 PM
                                          • jean luc ferre
                                            laptop hp g72 b52sf screen problems
                                            by jean luc ferre
                                            on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                            the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                            i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                            i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                            06-07-2025, 03:27 PM
                                          • drscoot
                                            HP X360 convertible battery blown fuse error, not charging
                                            by drscoot
                                            HP Modelnumber: 14-dh0061nb​
                                            This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                                            The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                                            I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                                            And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                                            All these 3 batteries are charging...
                                            12-15-2023, 05:54 AM
                                          • Hondaman
                                            USB problems?
                                            by Hondaman
                                            Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                                            (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                                            I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                                            08-12-2024, 03:26 PM
                                          • swerg
                                            Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
                                            by swerg
                                            Hey everyone,
                                            I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
                                            I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
                                            I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
                                            06-06-2024, 03:39 PM
