Iiyama Prolite E431S Turns off
  • starfury1
    • May 2006
    • 1256
    Re: Iiyama Prolite E431S Turns off
    just looking around a few threads here
    did find a link to Hermei LZ series, These are suppose to be Ultra low ESR
    (and they might be for all of 5 minutes )
    original thread
    https://www.badcaps.net/forum/showth...&highlight=lcd
    So if they were LZ series then FM series possibly would have been the choice for the specs of the LZ crap
    although I tend to find around the FC range of caps being suggested for this type of application
    Humm anyway, if FC (or any cap for that matter) are run out of spec they will eventually die the same way.
    It really depends on the actual circuit demands even if they are LZ
    Just on the PCB I would guess it isn't in the high quality league and is probably a single sided PCB so when removing the caps try not to dump too much heat into it or you could lift the copper (like don't hold the iron on it for a minute)
    Also if you got no desolder gear check the FAQ's and use a Needle STAINLESS Steel to clear the holes
    Its quicker and less chance of damage from stuffing around with desolder pumps....if you haven't clear it with one of those by the second attempt, run the needle through.
    should be easier to do them trying to get VRM caps out of a MB.
    Lastly give the solder side a good visual check especially were the transformers are or any components mounted to heat sinks
    if you notice discoloration around these area's thats from heat, it can actually warp the PCB
    what happens is expansion and contraction on the solder joint with fixed components can cause the solder joint to fracture
    (hair line thats sometimes is hard to see)
    rework any joints that are suspect in this regard is my advice but there also "if it ain't broke don't fix it" too
    Good luck and post back on it, its nice to have a conclusion
    Cheers Mike, All
    • spunkmyer
      • Apr 2008
      • 10
      Ok...................
      Here goes............. Removed the 1000uf 16v cap but it took some time as I am good with solder work but not on this scale of size.
      Cleared out the old solder,put it to position the 1200uf 16v using the wait of the board to keep it close to the pcb then using solder lent by a good friend who is the electronics engineer who suggested this type of solder for pcb work, soldered the cap in to place carefully making sure not strays of solder.
      After this decided to test the screen so hooked up the kettle lead and d-sub and taking a deep a breath pushed the power button and after a few seconds the screen powered on and showed a clear picture of Call of Duty 4 and did not repeat the fault.
      so I will replace other three caps in the next few days.
      Again thanks for all your help so far Starfury1 I am grateful for your help and also thanks to for you help Gonzo0815, i4004, Krankshaft
      Mike
      • i4004
        • Oct 2006
        • 2029
        good to know you fixed it.
        • gonzo0815
          • Feb 2006
          • 1600
          Nice that you fixed this one, i am getting the same monitor in the next few weeks. I hope that the caps are the problem there too.
          As far as i have informations, the problem is that it always is showing a error message, thus it is may be a semiconductor problem.
          But until i haven`t replaced some caps, hope is there.
          • spunkmyer
            • Apr 2008
            • 10
            So far so good no problems very good monitor 8ms response 17in screen very happy as it was given to me by one of my customers.
            I supplied the LCD screen 3 years ago and it broke 1 month after the warranty runs out oh well, strange to think that it has come back to me .
            So in at cost £18 to fix not bad really and I have a few spare caps that my be useful.
            Mike
            • gonzo0815
              • Feb 2006
              • 1600
              #26
              AFAIK it is an IPS panel screen, still expensive, 16,7M colors and fast response time.
              • Geddon
                • Sep 2007
                #27
                Hi, I'm the guy who repaired/recapped his E431S in the earlier thread. I realise I'm a little late here but the replacement caps I used were bought from RS Components and had the following part numbers:
                526-1266
                526-1389
                7 months later and the monitor is still going strong. Hopefully the info will be of some use to the next person who has problems with this model.
                • gonzo0815
                  • Feb 2006
                  • 1600
                  #28
                  Well, Panasonic FM, one of my favorite capacitor series. High endurance, very low ESR and good availability.
                  • JEWilson
                    • Sep 2007
                    • 369
                    • Scotland, United Kingdom
                    #29
                    I fixed an Iiyama ProLite E481S yesterday
                    Usual culprits - bad crapacitors
                    Four of these inc. the Hermei were noticably bulged and
                    two of 16V 1000uF had electrolyte leakage.
                    Tested with ESR but reported ok
                    The fault sympton was screen failed to start - stuck in standby
                    Replaced the following
                    O/P Filter
                    2 of 470 uF 16.0V 105 deg - done, replaced with Panasonic FC, C101 and C916
                    2 of 1000 uF 16.0V 105 deg - done, replaced with Panasonic FC, C914, C915
                    Beside Inverter
                    2 of 220 uF 16.0V 105 deg - done, replaced with Panasonic FC 16V 470uF, C201, C223
                    Primary
                    1 of 22 uF 50.0V 105 deg - done, replaced with Panasonic FC 50V 33uF, C907
                    1 of 33 uF 50.0V 105 deg - done, replaced with Panasonic FC 50V 33uF, C207
                    2 of 1 uF 50.0V 105 deg - done, replaced with Panasonic NHG same value, C301, c302
                    The screen is ok now, cleaned up a bit and good to go
                    • Benedict
                      • Mar 2009
                      #30
                      Hey, sorry to bump this thread. Ive now got three of these monitors that were junked from my department at university. They all suffer the same problem in that they wont start up. As someone previously mentioned, the little light on the front keeps flashing about once a second, and nothing more. Very annoying. I would like to repair them, as I need to go dual screen for CAD, but dont have the money to buy let alone one new monitor.
                      The trouble is I havent touched a soldering iron since I was at school. Ive searched about the internet and capicitor failure seems the most likely defect.
                      I have two questions though, how straight forward a proceedure is it to replace the capacitors, and (utter noob question) how on earth do I get the covers off? I cant seem to locate the last screw which makes it all come loose!
                      Many thanks to all. I'm very glad I found this forum!
                      • PlainBill
                        • Feb 2009
                        • 7034
                        As far as getting the cover off, sorry, I've never worked with that monitor.
                        Replacing caps on a power supply is no big deal. The FAQ and this thread will help you identify the proper series. In general you want to keep the same capacity, voltage, and physical size. Even though you are on a tight budget, replace all of the caps on the power supply board, (except for the 100 uf 400V one) even if they look good. Expect to pay $.50 - 1.00 for each cap. If I count correctly, there are 11; getting all three monitors working will cost less than $50.
                        If you've used a soldering iron a few times you shouldn't have too many problems. I suggest a 25 watt. Buy one that uses replaceable tips and use plated tips, they'll last longer. When removing the old caps give the soldering iron plenty of time to melt the solder, remove one leg at a time until it's removed. I suggest making a sketch showing which value of cap was in each location. When soldering in the replacements make sure you have the orientation correct, and again make sure the solder has flowed freely over the pad and is adhering to the pad and the lead. Above all, don't rush. Think about getting $300 of monitors for $50 and take your time.
                        I always examine the soldering carefully with a lighted magnifier before trimming the leads. Leave just a little bit of lead extending above the solder fillet.
                        PlainBill
                        • JEWilson
                          • Sep 2007
                          • 369
                          #32
                          You may have removed all screws
                          Next step, is to pop the plastic cover to the rear of the screen.
                          With the stand and all screws removed, turn the VDU face down.
                          Place the VDU side on a material which will not scratch the panel.
                          To pop the plastic, use a small screwdriver or similar to run along
                          the edge of join between the rear plastic cover and the front of
                          the panel.
                          The join is only a 1mm wide! Start at the bottom of the screen.
                          Use the screwdriver to press the on the edge whilst moving along
                          it. If done correctly, (working from bottom to top) the rear
                          panel will progressively open just sufficiently to then pop the
                          next join fixing on the rear cover. The trick is, to persuade the
                          rear cover to separate from the front of the screen.
                          Exercise caution. Not so hard as to damage the plastic.
                          You will just require enough force to press on the edge join!
                          Once you have done 1 or 2, you'll get the hang of it.
                          • markzplace
                            • Apr 2009
                            #33
                            Excellent post replaced all the capacitors but did not work for me but got me in the right direction, turned out to be a short circuit transistor c5706 replaced all 4 with 2sc5707 now works again £3:00 plus postage on ebay.
                            • Chips
                              • Oct 2009
                              #34
                              Thanks to these forums I was also able to fix my Iiyama Prolite E481S.
                              On the basis of the previous post I replaced the four transistors by the inverters and replaced them with C5707s (NB: mine had to be soldered at a 180 degree orientation compared to the existing ones - D1691). This did not fix the blinking blue light, so I took another look at the board and realised I'd missed the obvious: 2 x 1000uF electrolytics that had bulged and leaked. Once I'd replaced those two it kicked into life. I believe they were branded NRSA, so not sure about the ESR rating, but at least they work.
                              See pics of the board and the leaky caps:
                              NB: I had removed one of the 4 transistors by the inverters at this point.
                              • bossaap
                                #35
                                hello,
                                i have a screen Prolite E432s llyama. if i turn it on its flashing 3 times (windows,motherboard,mouse) after these 3 things The screen goes black.but the bleu light stays on. it is not going on stand by. i have already replaced the caps but the problem stays.if i push on the button input/auto then i have for a few seconds visual screen. can anyone help?
                                excuse me for my poor english,dutch is my first language. Gerrit
                                • Bobdee
                                  • Jun 2008
                                  • 461
                                  #36
                                  Originally posted by bossaap
                                  hello,
                                  Hello Geritt
                                  Check out the 4 transistors C5707s or 6s either side of the 2 big blue caps, test for shorts
                                  • bossaap
                                    #37
                                    Hello Bobdee,
                                    thanks for the quick response.
                                    now my question is what would i notice or see on the transistors.
                                    do i have to measure them and if so what should be the values?
                                    the 4 transistors i have orderd them in the states if they arrive then i will put them in the board and check if the screen is working if not i'llbe back.
                                    Gerrit
                                    • Bobdee
                                      • Jun 2008
                                      • 461
                                      #38
                                      Hello Bobdee,
                                      Gerrit
                                      Its would have been better to check them first to see if they are the failure before buying
                                      If still in circuit then go with this method by Krankshaft
                                      With a DMM switch it to diode check measure from base to collector then flip the position of the probes. Voltage drop in one direction is fine do that same from base to emitter same testing rule applies.
                                      If out of circuit then test using lowest ohm setting and look for shorts between
                                      B+C
                                      B+E
                                      C+E
                                      Bob
                                      • bossaap
                                        #39
                                        hello Bob
                                        i have measured the transistors, 1 was broken.
                                        i have replaced them all (4) and now the flatscreen is working.
                                        thanks a lot for your advise.
                                        i wish you a merry xmas and a happy new year.
                                        Gerrit
                                        • gijss
                                          #40
                                          I had the same problem, found this forum and replaced the 4 transistors (Caps didn't looked bad). And now it works again!
                                          Thanks, I would never have found it without you guys!
                                          • mikey5791
                                            Need help replacing led strip on Iiyama Prolite XUB2390HS monitor
                                            by mikey5791
                                            Got this working ips led monitor by the brand of
                                            Iiyama Prolite XUB2390HS presumably a 23 inch type given to me with suspected bad led backlight. To test it, i unplugged the bad flat ribbon type connector and plugged it a good flat ribbon led connector scrapped from a HP Pavillion 27cw (led strip with 60 led). Good news is the HP led strip lights up but not fully, in between there are about 15 unlit leds.(as picture attached shows).
                                            Fyi, i had not opened and removed the old bad led strip. My question is whether is it possible to cut some of the extra leds(say...
                                            09-04-2023, 03:50 AM
                                          • Stephen
                                            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                            by Stephen
                                            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                            03-15-2024, 09:37 AM
                                          • www
                                            LG L192WS-BN backlight turns off after 1 second
                                            by www
                                            I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                            I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                            03-24-2024, 05:26 PM
                                          • andrhouseolly
                                            Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                                            by andrhouseolly
                                            Hi.
                                            I kindly ask you to help me solve the problem.
                                            Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                                            The board turns on, there is no image.
                                            Read more. When the power supply is connected, the front panel indicators light up briefly.
                                            When you press the power button, the button indicator lights up. The board works
                                            there is no image, there is no matrix initialization, there is no image on HDMI.
                                            When turned on, the fans do not spin, but when they warm up they start spinning.
                                            When you turn off the button, the fans spin up to full speed for a short...
                                            05-11-2024, 03:14 PM
                                          • Egidio85
                                            Samsung UE55F8000SZ Turns on and off immediately
                                            by Egidio85
                                            good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                                            This defect happens continuously, hearing the classic click of the relay every time.
                                            Power supply board BN44-00636B
                                            disconnecting the mains and lamps from the power board always causes the same problem.
                                            Is it normal that without anything connected this power supply turns on and off cyclically?
                                            any suggestions on what to check?
                                            thanks in advance
                                            03-11-2025, 12:45 PM
