Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
  • andrhouseolly
    • Dec 2020
    • 28
    • Ukraine
    Hi.
    I kindly ask you to help me solve the problem.
    Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
    The board turns on, there is no image.
    Read more. When the power supply is connected, the front panel indicators light up briefly.
    When you press the power button, the button indicator lights up. The board works
    there is no image, there is no matrix initialization, there is no image on HDMI.
    When turned on, the fans do not spin, but when they warm up they start spinning.
    When you turn off the button, the fans spin up to full speed for a short time,
    the board turns off.
    Without memory, the board turns on, the front indicators blink in the sequence:
    three times white, twice yellow. Several times, after which the board turns off.
    Unfortunately, it's not possible to reflash the BIOS; I couldn't find a dump of the "Dell Precision 5510" anywhere
    (out of curiosity, I tried dumps for Dell XPS 15 9550 AAM00 LA-C361P REV 1.0,
    stopped responding normally to being turned on).
    More details on the board.
    I used the schematic "Dell XPS 15 9550 LA-C361P Rev 0.0 (M00).pdf".
    There is no Power Up Sequence in this diagram, so Power Up Sequence
    taken from the schematic "XPS 15 9570 LA-G341P MB 4PHASE Schematic.pdf" (p. 76)
    According to "Power Sequence diagram" (p.53) "Dell XPS 15 9550 LA-C361P Rev 0.0 (M00).pdf":
    +3VALW (+3VALW) - 3v
    +5VALW (+5VALW) - 5v
    PCH_1V (+1VALW) - 1v
    +1.2V (+1.2V_DDR) - 1.2v
    +0.6VS (+0.6VS) - 0.6v
    +1.35VSDGPU (+1.35VSDGPU) - 1.35v
    VCCIO_0.95V (+VCCIO) - 0.95v
    +1.05VGPU (+1.05VSDGPU) - 1.05v
    VGA_CORE (+GPU_CORE) - 0.9v
    +VCC_CORE (+VCC_CORE) - 1.05v
    +VCC_GT (+VCCGT) - missing !!!!!!!!
    +VCC_SA (+VCCSA) - 1.08v
    By +VCC_GT: no PWM sequence on PWM1_GT, PWM2_GT with PU1100 (ISL95829HRTZ-T)
    forming +VCC_GT with PU1300, PU1301
    According to "Power Up Sequence" (p. 76) "XPS 15 9570 LA-G341P MB 4PHASE Schematic.pdf":
    Absolutely all levels rise, except for the last two "+VCCGT" and
    "DDR_DRAMRST#" (on LA-C361P it's like "DDR4_DRAMRST#")
    On display connector JEDP1:
    +INV_PWR_SRC - 5v
    INV_PWM - missing!!!!!!! (DV2 on anodes nothing)
    DISPOFF# - !!!!!!!!!!! (DV1 on the anodes nothing)
    EDP_PANEL_DAT - missing!!!!!!! (UV17 no EN signal - EDP_CTRL_EN_C)
    EDP_PANEL_CLK - missing!!!!!!! (UV17 no EN signal - EDP_CTRL_EN_C)
    At the inputs UV17 - DOCK_TNY_SMB_CLK, DOCK_TNY_SMB_DAT there are pulse sequences.
    If anyone can advise or help, I will be very, very grateful.
    Thank you.
  • mon2
    • 14489
    What is the voltage to ground of the following?
    EDPVDD
    UV17 - pin # 8
      • 21407
      LINK to schematic - https://www.badcaps.net/forum/troubl...ematics-needed
      Reminder: rules and organization of this section - https://www.badcaps.net/forum/troubl...f-this-section
      Quote: If you request/offer BIOS/schematics/boardviews, please post in the appropriate subsection, and you can link to it in the troubleshooting topic.​
      • andrhouseolly
        • Dec 2020
        • 28
        • Ukraine
        UV17 - VCC (pin # 8), EDPVDD - 3.3v
        RV545, RV546, RV548, RV549 - none.
        UV17 - EN (pin # 5), EDP_CTRL_EN_C via RE107 (zero) to UE3 - (pin # B53 EDP_CTRL_EN) - missing.​
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          VCCGT is not of concern as it'll rise only under load. DRAMRST# must be 1.2V. What is the current consumption on your dc supply?
          01.With ram stick
          02.Without ram stick
          • CyberDe@th
            • Jul 2022
            • Norway
            You'll find Cleaned BIOS file in the attachment. It's helped me with one bricked Precision 5510. It hasn't worked with the other one. I don't remember where I've found it. Maybe at the BadCaps
            https://www.badcaps.net/forum/troubl...-12-0-me-clean
            • andrhouseolly
              • Dec 2020
              • 28
              • Ukraine
              Thank you dear CyberDe@th, but unfortunately the attached file is not available.
              • andrhouseolly
                • Dec 2020
                • 28
                • Ukraine
                01.With ram stick
                Thank you. I heard and read about VCCGT, but I wasn't sure. Thanks for confirming.
                DRAMRST# is missing (or rather “noise” is about 50 mV).
                More precisely, here is H_DRAMRST# (PCH output, pin# BC14), via RD31 (short), to DDR4_DRAMRST#, with a pull-up to 1.2V_DDR.
                I checked this chain, everything is intact, the resistors match. RESET is not cleared.
                By currents (without peripherals, only RAM):
                1. By +DC_IN (Main Power):
                With ram stick - 1.3A (1.35A with warm-up)
                Without ram stick - 1.2A (1.25A with warm-up)
                2. By +1.2V_DDR:
                With ram stick - 260mA-270mA
                Without ram stick - 45mA-50mA
                3. By H_DRAMRST#/DDR4_DRAMRST# (RD35 - 470 ohm):
                With ram stick - 2.2mA-2.4mA
                Without ram stick - 2.2mA-2.4mA​
                • CyberDe@th
                  • Jul 2022
                  • Norway
                  I've uploaded again. Let's see if it works this time...
                  Just in case, below you'll find the link to the Google Drive:
                  https://drive.google.com/file/d/1qmH...ew?usp=sharing
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Going by your measurements at post#8, try flashing the bios linked at post#9. Measure voltage on pin 1/6/3/4 of QH4. If you have oscilloscope,it will be much better to check pins on QH4.
                    • andrhouseolly
                      • Dec 2020
                      • 28
                      • Ukraine
                      Thanks to CyberDe@th for providing the dump.
                      Unfortunately the situation remains the same.
                      All supplies are raised (except +VCC_GT).
                      According to "Power Up Sequence", DRAMRST# is not removed.
                      According to measurements on QH4:
                      2,5 pin (+3VS) - PowerOff - 0V, PowerOn - 3.3V
                      1 pin (PCH_SMBCLK) - PowerOff - 0V, PowerOn - 3.3V, after switching on one packet (QH4_1pin).
                      6 pin (SMBCLK) - PowerOff - 3.3V, PowerOn - 3.3V, after switching on one package (QH4_6pin).
                      4 pin (PCH_SMBDATA) - PowerOff - 0V, PowerOn - 3.3V, after switching on one package (QH4_4pin).
                      3 pin (SMBDATA) - PowerOff - 3.3V, PowerOn - 3.3V, after switching on one package (QH4_3pin).
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Does these packets of data appears only once or they come in succession for 3-4 times? If the data comes only once,very very likely its CPU fault.
                        • andrhouseolly
                          • Dec 2020
                          • 28
                          • Ukraine
                          I checked again. The package appears only once, after switching on. Then there is only a constant high level.
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            This means ram is not detected properly by the system. Often the culprit is bios but sometimes its the memory controller inside CPU.
                            When ram is detetced properly ,you should see atlest 3-4 times burst of data packets .
                            • andrhouseolly
                              • Dec 2020
                              • 28
                              • Ukraine
                              Yes. Understood. I will “bury” the board. Thank you very much for the help.
                                DELL G5 5510 Notebook Specification for Upgrade or Repair
                                This specification for the DELL G5 5510 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5510 boardview and 5510 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL G5 5510 Notebook is...
                                09-07-2024, 03:10 AM
                                09-07-2024, 02:50 AM
                                09-07-2024, 02:20 AM
