Fix for Benq FP737s 17" (Q7T3)
  • jetadm123
    • 2169
    #281
    Re: Fix for Benq FP737s 17" (Q7T3)
    Originally posted by rbrt86
    I really need your help. I've got a Benq FP737 with the same sympthoms as post #263: white backlight when monitor is off
    The blacklight used to be broken but then I:
    1) replaced the picofuse
    2) replaced the 4 c5707 transistors
    3) replaced the fu9024 fets
    Now the monitor works but smells like smoke and the backlight is white when off
    I noticed that one of the fu9024 fets gets really hot
    Is it a short circuit?
    Please help, your advice is very much appreciated!!
    Did you also remember to resolder all the transformer pins?
    • Smiffy
      • Feb 2006
      • 16
      #282
      My FP737S has 2SJ598s in Q743 and Q 751.Is it ok to replace them with FU9024Ns?
      All transformers resoldered.all 2SC5707s replaced and bulging caps done(nearly all of the 470uf 35v ones)
      Smiffy
      • retiredcaps
        • Apr 2010
        • 9271
        #283
        PlainBill answered this ...
        https://www.badcaps.net/forum/showpo...7&postcount=20
        --- begin sig file ---
        --- end sig file ---
        • Smiffy
          • Feb 2006
          • 16
          #284
          Thanks RetiredCaps
          Smiffy
          • balu
            • Nov 2011
            #285
            Hai Everybody,
            I joined in this forum yesterday. It is a very useful and helpful one. I could get some essential information regarding my damaged Benq LCD Monitor. Could somebody give the values of Caps @ C501 and C509 in Benq Q7C5 Power Supply Inverter Board? Thanks....
            • jayoung
              • May 2011
              • 172
              #286
              LCD monitor manufacturers use various power supplies and inverter boards for monitors with the same model number. You will need to open up the monitor and then you will be able to read the values of the needed capacitors. Many members here recommend replacing all of the electrolytic caps at the same time (except for the large main filter cap). There are several threads on here about ordering capacitors and recommended brands. If you make a list of the capacitors that are on your board, and list what replacement caps you think you should order, someone here can verify if you are ordering the right ones. Pictures also help people help you, use the manage attachments below the text area when posting through advanced messages.
              • soulraven
                • Mar 2012
                #287
                hi, please help me with a problem, i have a benq FP731 monitor with a strange problem,
                the screen is white and nothing is displayed, only a few small lines colored.
                i have try to press and the ribbon from the lcd panel to logical board, but nothing.
                the monitor enters in standby or exit from standby when i disconect the input cable.
                any ideea where is the problem?
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #288
                  1) You could have a blown SMD fuse on the panel card that runs the length of the monitor. The panel card is usually at the top of the monitor.
                  2) There could be a bad voltage regulator on the main board.
                  3) You could have bad, but not bloated, caps on the main board.
                  • soulraven
                    • Mar 2012
                    #289
                    thx,
                    i have check the fuse from the lcd panel and is ok,
                    but after that i have power again the monitor and is just work, no white screen, just work, but after a few hours or running ok, after i reconnect the monitor to power i get again the white screen. The last thing that i have work on it is the connector from the panel and the logical bord.
                    After that i have try again to check the connector, to check again the connection but nothing, still withe screen
                    any idea what about that? strange thing
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      #290
                      Hi check the fuse again - if you can get to it, try very gently pressing on it ( With something insulated )while everything is switched on -may be bad contact?
                      If it is a flat cable connector did you clean it. If it is pins have you checked for bent or broken pins.
                      "the monitor enters in standby or exit from standby when i disconect the input cable."
                      Do you mean the input from the PC - you should not plug/unplug any internal cables when it is switched on.
                      • soulraven
                        • Mar 2012
                        #291
                        i will check the fuse again tomorow
                        i mean the d-sub cable between pc and monitor
                        • soulraven
                          • Mar 2012
                          #292
                          i have check the fuse and nothing, i also measured and is ok.
                          i am sure that a imperfect contact somewhere. any idea about that? or something to measure and determine if everything is ok?
                          • bignick8t3
                            • May 2012
                            • Uk
                            #293
                            I have 2 Benq FP737s, 1 work's perfectly well the other well I'll elaborate...
                            When switched on the LED will light up green but the backlight will flick on and off randomly, the signal/picture is still there as when it's flickering on and off if you shine a light on it you can still see the image.
                            So it hasn't completely died yet. I have searched this thread and apologise in advance if these symptoms have been seen before.
                            Thanks in advance.
                            Nick
                            • pappa_smurf
                              • Sep 2012
                              • 5
                              • mozambique
                              #294
                              Hi All
                              New guy from Mozambique,
                              MAN! I wish I had a Pinch of the Knowlwdge floating around this forum, Good going Guys.
                              I have a Benq Q7T3 which has been good for years, now it has died a quiet death.
                              No lights no nothing, have done a cursory test of trannies and such, resoldered all joints, did not remove solder just resoldered and nothing happens.
                              I am a hobbyest and don't know much, am also 1000Km from civilization and batle to get spares quickly, have to wait till I go go to South Africa from time to time to purchase.
                              Please tell me where to start to look for the problem, I do have the diagram and understand a bit about testing.
                              Any help will be much appreciated
                              Kind Regards
                              • ronszon
                                • Sep 2012
                                • NA
                                #295
                                Thanks for the info in this thread, it saved me a screen! (Though I was thinking of buying a new HUGE one already... damn...)
                                I have two HP 1740, one of them first was not able to switch off the backlight (nice LCD-going-off effect, then white), then after a week it died completely.
                                It has inside a derivative of the Q7T3 board (48.l1g02.a01) for which I could not find an exact schematic... (annoying!) It is slightly different since it does not have the PF751 (Vinverter fuse). What happened is one of the MOS switches (FU9024) blew to short (that's probably the screen not going off anymore?) and one of the bipolar c5707 blew as well (that's the screen dying I guess).
                                I got a repair kit from ebay, replaced all transistors (4 c5707, 2 FU9024), replaced the (only) fuse PF701 (that's the fuse before the large diodes with heatsink) and it worked! Tadaaa!
                                Thanks again! I just wonder how much longer these old screens will live (so I can finally buy myself something bigger )
                                Kuba
                                BTW. I also resoldered the inverter's transformers. It indeed looked like there is some wear on the joints...
                                • oddbodd
                                  • Mar 2013
                                  • 121
                                  I just joined this forum, and have read through numerous posts to try and fix my Q7T3 Benq monitor.
                                  I have been getting the "2 seconds to black" problem. Although, at first, after switching the monitor off and on a number of times, it would work OK.
                                  There's nothing immediately apparent on the board itself. So, I tested the following, but replaced them anyway...
                                  1) the 3A picofuse
                                  2) the 4 2SC5707 transistors
                                  3) the 2 FU9024N fets
                                  ... but no difference.
                                  I have just retouched the solder on the inverters, and still no change... at first, anyway. After switching the monitor on and off a few times, I now get the Benq logo flashing every second or so.
                                  So, any ideas where I go from here, please?
                                  I also read that the octocoupler might need resoldering. Is this IC602 on my board? [48-L8302-A30].
                                  I'm fairly new to a lot of this stuff, so thanks for any help.
                                  • selldoor
                                    Slow Learner
                                    • Dec 2010
                                    • 7870
                                    #297
                                    Re touching may not be enough - You need to get some leaded solder to mix with the old solder then remove it -or most of it then resolder with new solder.
                                    • selldoor
                                      Slow Learner
                                      • Dec 2010
                                      • 7870
                                      #298
                                      IC602 probably is - re solder it anyway wont do any harm 4 legs? cant see it on pic.
                                      You should aso resolder those gray box caps with a k on between the 5707s and also the blue ceramic caps - and the inverter transformers and main transformer in fact if your good at soldering solder as much as you can be bothered with.
                                        Sch:
                                        The inverter transformer driving circuits are setup as self Osc Royer OSC, if the MOSFET which is PWM driven at the Gate to provide variable DC (more dc more brightness) for the Royer Osc, if the MOSFET shorted out (jump Source and Drain), the inverter will be running at full mode disregarding the PWM IC is working or not.
                                        • oddbodd
                                          • Mar 2013
                                          • 121
                                          OK, thanks.
                                          IC602 does have 4 legs.
                                          Will resolder all, and report back...
