Faulty Dell ST2210
  • Guest
    Re: Faulty Dell ST2210
    Originally posted by SteveNielsen
    Yes, you can use the working tubes from the other monitor to test the inverter.
    so do I just connect the psu board to the driver board, plug it into the wall, plug the tubes from the other monitor to the board and then wait?
    • SteveNielsen
      Retired Tech
      • 2327
      No, there is high voltage present. Connect the boards and tubes and to the wall outlet LAST.
      • Guest
        alright, so I just run it without connecting it to anything else? like a computer or anything so that it does not fall asleep?
        • SteveNielsen
          Retired Tech
          • 2327
          I don't think that is necessary just to test the inverter. The Dell monitors I have experience with go into a self test feature check mode with the video cable disconnected so the back-light would be on. If it is connected to a computer that is OFF however, it will go directly into standby and no back-light.
          • Guest
            Right, I remember seeing that self test thing (floating box). so I'll just plug it in for an hour or so and hope for the best
            • Guest
              #26
              welp, 1 hour has passed and the backlight from my old monitor is still on (damn, this thing is bright) so I guess I just have to order new tubes and replace them?
              Update:pulled both the tubes out but broke both of them, they are stuck in really tight ._.
              • selldoor
                Slow Learner
                • 7870
                #27
                Originally posted by Razroid
                what difference does swapping the plugs make?
                ._.
                A bit irrelevant now though you could still try.
                When there are only two lamps top and bottom the lamp at the top gets all the heat from the whole monitor as well as the heat from the bottom lamp and its own heat. Consequently this causes it to wear out more quickly.
                For some reason swapping the bulbs over seems to stop the protection kicking in
                so the bulbs light up.
                  Are the end of the lamps blackened?
                  • Guest
                    #29
                    little bit, yeah. About 2mm is blackened on each end.
                    • Guest
                      #30
                      Has anybody done a monitor with fans in it before :P
                      Might be a cool mod to do. (pun intended)
                        Great Sage ι½Šε€©ε€§θ–
                        • 31199
                        i have, and tv's
                        • Guest
                          #32
                          Alright, I have ordered the tubes, will report back if it works.
                          Thanks guys! This really helped me
                          • Guest
                            #33
                            UPDATE: got the new tubes in, top one went in fine, but I broke the bottom one when trying to squeeze it in, why is the bottom one so tight? any ideas? few more weeks before a new tube arrives
                            • selldoor
                              Slow Learner
                              • 7870
                              #34
                              Can you get the same length in a smaller diameter - ask seller if it will be ok?
                              • Guest
                                #35
                                The one I got is an actual Dell st2210 one, with the plastic frame and all.
                                • Guest
                                  #36
                                  I'm back. I got the new tubes in and left it powered on (just the tubes plugged in) for 30 mins and it didnt shut down, so I reassembled everything and plugged it in to the wall, about a minute later, it shut off, any ideas?
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    #37
                                    Check all your cables.
                                    Was the bulb still tight ? maybe expanded and had nowhere to go!! so crack.
                                    Try again with you old monitor lamps.
                                    • Guest
                                      #38
                                      yeah, it was slightly tight, but if it cracked, it won't light up right ._.
                                        "yeah, it was slightly tight, but if it cracked, it won't light up right ._" That is correct, lamp is under vacuum.
                                        • Guest
                                          #40
                                          soooooo any ideas? I spent so much time and money on this display already :/
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • Borse2008
                                            Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                            by Borse2008
                                            Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                            I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display β€” it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                            • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                            • There’s
                                            07-15-2025, 04:55 AM
                                          • master3112
                                            by master3112
                                            07-29-2025, 01:55 PM
                                          • diamon
                                            Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                            by diamon
                                            I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                            Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                            Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                            Pictures of these boards:
                                            Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                            Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                            Dell...
                                            02-28-2024, 12:51 PM
                                          • lalle-
                                            Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
                                            by lalle-
                                            Hello!
                                            I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
                                            [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
                                            I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
                                            The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
                                            I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
                                            08-11-2024, 02:01 PM
