Faulty Dell ST2210
Guest -
Re: Faulty Dell ST2210
No, there is high voltage present. Connect the boards and tubes and to the wall outlet LAST.Comment
Guest
I don't think that is necessary just to test the inverter. The Dell monitors I have experience with go into a self test feature check mode with the video cable disconnected so the back-light would be on. If it is connected to a computer that is OFF however, it will go directly into standby and no back-light.Comment
Guest
Right, I remember seeing that self test thing (floating box). so I'll just plug it in for an hour or so and hope for the bestI don't think that is necessary just to test the inverter. The Dell monitors I have experience with go into a self test feature check mode with the video cable disconnected so the back-light would be on. If it is connected to a computer that is OFF however, it will go directly into standby and no back-light.
Guest
welp, 1 hour has passed and the backlight from my old monitor is still on (damn, this thing is bright) so I guess I just have to order new tubes and replace them?
Update:pulled both the tubes out but broke both of them, they are stuck in really tight ._.Last edited by Guest; 07-30-2014, 02:50 PM.Comment
A bit irrelevant now though you could still try.
When there are only two lamps top and bottom the lamp at the top gets all the heat from the whole monitor as well as the heat from the bottom lamp and its own heat. Consequently this causes it to wear out more quickly.
For some reason swapping the bulbs over seems to stop the protection kicking in
so the bulbs light up.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
Are the end of the lamps blackened?Never stop learning
Guest
Guest
Has anybody done a monitor with fans in it before :PA bit irrelevant now though you could still try.
Might be a cool mod to do. (pun intended)Comment
Guest
Alright, I have ordered the tubes, will report back if it works.
Thanks guys! This really helped me
Guest
UPDATE: got the new tubes in, top one went in fine, but I broke the bottom one when trying to squeeze it in, why is the bottom one so tight? any ideas? few more weeks before a new tube arrives
Can you get the same length in a smaller diameter - ask seller if it will be ok?Please upload pictures using attachment function when ask for help on the repair
Guest
The one I got is an actual Dell st2210 one, with the plastic frame and all.Comment
Guest
I'm back. I got the new tubes in and left it powered on (just the tubes plugged in) for 30 mins and it didnt shut down, so I reassembled everything and plugged it in to the wall, about a minute later, it shut off, any ideas?
Check all your cables.
Was the bulb still tight ? maybe expanded and had nowhere to go!! so crack.
Try again with you old monitor lamps.Please upload pictures using attachment function when ask for help on the repair
Guest
"yeah, it was slightly tight, but if it cracked, it won't light up right ._" That is correct, lamp is under vacuum.Never stop learning
Guest
soooooo any ideas? I spent so much time and money on this display already :/Comment
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by Borse2008Hi everyone,
I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:- The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
- There’s
07-15-2025, 04:55 AM -
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
by SMDFleaDell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
Some models have a choice of 2 different firmwares, it depends on the dell SKU.
The SKU is in brackets (****)
EDIT: NVM65...-
Channel: BIOS Requests ONLY!
by dell_sadnessBIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
Have extracted the BIN and want to know how to rebuild a clean BIOS
I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...-
- Loading...
