Faulty Dell ST2210
    Re: Faulty Dell ST2210
    Can you expand on "Just shut off" - could mean almost anything
      well, it literally just shuts off, I turn it on, the self check thing comes up, 10 seconds later, it goes off, clicking the power does not do anything, I have to unplug the main power a wait a little before I can power it back up again :/
        What does the power led do?
          power led just goes off
            It is connected to running PC?
              nope, just by itself
                Some monitors dont stay on without a source.
                EDIT - would also be useful to know if the pC recognised it correctly
                  it's supposed to stay on without a pc connected to it, there's the self test "box" that floats around.
                  also, I dont think I can get enough time to plug it into a pc, it shuts off so quick
                    ?? You have it connected to a pc before you switch it on
                    See post 24.
                    Also did you try again with your old monitor lamps
                      Dell monitors will usually show the floating box unless connected to a video port and the computer is off. The cable senses that it is connected which disables the "self test" floater and goes straight into standby. If you've got a cable connected to the display try disconnecting it.
                        See post 24.
                        Sorry, I might have been slightly sleepy when I wrote that :P
                        Yeah, I'll do another test with the old lamps
                        Nope, just the power cable.
                          I've got ST2210B monitor and just wanted to inspect PCBs, but have no idea how to open up the casing. All I can see - it consists of 3 "layers", so I presume there are clips somewhere there. How to start ?
                          Cheers
