Benq E2200 HD inverter failure
  • cheebster
    • May 2008
    • 374
    Hello ! I have this Benq E2200HD here i got for free. It powers on, goes to black after showing the benq logo and saying no signal. With a flashlight, image is displayed with a pc input so it's backlight failure.
    Here's a picture of the power supply with included inverter. Caps LOOK fine, however they are JAMICON in the inverter section (270UF, 50V)
    The smaller one at the other end, there are 3 25V 680UF Su'scon (wth), 5 220UF Su'scon, 1 black 25V 47UF Su'scon near the big cap, and a smaller 10uf 50V near the audio output.
    I've reflowed most of the pins on the bottom of the board in the inverter section to start. I'm not so sure what i should do next, i'm able to power on the screen's CCFL with an external inverter. thanks !!!!
    Oh, here's the actual picture of it attached. thanks for any help !!!
    Re: Benq E2200 HD inverter failure
    Did you check the resistance of High voltage windings of the inverter transformer?
    • selldoor
      Slow Learner
      • 7870
      Originally posted by cheebster
      It powers on, goes to black after showing the benq logo and saying no signal.With a flashlight, image is displayed with a pc input so it's backlight failure. !!!!
      \That sounds a bit odd shows a picture but reports no signal?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4476
        • Italy - Milan
        check smd mosfets on bottom, blue high voltage capacitors for short or leakage also to be sure..
        • Rtech
          • Jul 2010
          • 1095
          Is that a pico fuse F8802 on the Inverter side, ?? and have you checked that ??? also do as Budm asks ref the transformer.
          • cheebster
            • May 2008
            • 374
            Sorry for the lack of input on this one, been a bit busy here.
            budm: don't know exactly if im looking right here, but i see 780ohms on each side
            selldoor, i did a few tests.. i mean i know it's the inverter that's in trouble. When a pc signal is connected, i see the faint image using a flashlight. works for 2-3 seconds
            davi.p : well, they don't look to have any shorts (the mosfets), they seem to tests ok. i'm not sure how to properly test the blue hv caps though ! i only have a fluke 115 to poke around.
            rtech; fb802 is a pico fuse yes and it tests ok !
            • selldoor
              Slow Learner
              • 7870
              I would have thought FB802 the black one in the middle is a ferrite bead however there looks to be a small yellow fuse at F802 near the connector
              Have you tested that also?
              • cheebster
                • May 2008
                • 374
                Yes, tests good as well !
                • selldoor
                  Slow Learner
                  • 7870
                  Have you any spare bulbs or anything you can plug the bulb leads into?
                    You need test lamps at this point to save time troubleshooting.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4476
                      • Italy - Milan
                      If you don't want to go crazy finding a spare test lamp, disassemble the screen and see if the lamps have darkened ends, if yes them are to change.
                      • cheebster
                        • May 2008
                        • 374
                        AH ! fixed this one. I just reflowed everything with fresh solder in the inverter section, re-assembled, and voila !! as new. tested for hours, it seems it's the only thing it needed, sounds odd no ? visually all looked fine...
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4476
                          • Italy - Milan
                          Some earlier Benq are known for bad solder quality..
                          • selldoor
                            Slow Learner
                            • 7870
                            I would have suggested that earlier but you said you had done it in the original post? anyway - well done
                            • cheebster
                              • May 2008
                              • 374
                              Yeah, i did reflow them but never tought it would have fixed it so easy, so i didn't bother to re-assmemble to test... but i should have, it fixed it
                              • seppde
                                Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
                                by seppde
                                I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
                                ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
                                The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
                                In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
                                02-09-2024, 05:19 AM
                                12/24 volt compressor cooler box inverter capacitor failure
                                by sam_sam_sam
                                This is my son’s cooler for his semi truck for his drinks the other day it started short cycling ( running for a second or two then shutting down ) and restarting four or five times then going into an error power cycle the controller then it would do the same thing again
                                Found a 47uf@63 volts double the ESR value of a new one
                                The 220uf@16 volts same as a new but 220uf@35 volt replacement capacitor
                                The main filtering capacitor was not replaced because I did not have that was not too tall
                                Where the 220uf capacitor is some type of switching power...
                                08-30-2022, 05:28 PM
                              • Gentian
                                APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                by Gentian
                                I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                03-06-2023, 07:07 AM
                              • valvashon
                                Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                by valvashon
                                For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                01-04-2024, 01:44 PM
                              • eccerr0r
                                A modified sine wave inverter + a grid tie inverter?
                                by eccerr0r
                                If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                08-31-2023, 09:14 PM
