Dell 3008wfp faulty power supply
  • Curamrda
    • 10
    • Czech republic
    #81
    Re: Dell 3008wfp faulty power supply
    Can anyone help to find out how to get out the power board? I have removed all screws...but it still holds in...
    • Rtech
      • Jul 2010
      • 1095
      #82
      If you turn it over,is there screws going into the Heatsinks on the Board ???
      • Curamrda
        • 10
        • Czech republic
        #83
        yes..they were there..but the are also out....
          Those heatsink compound can sometime make them stick together like glue.
          • fuus
            • 123
            • England
            #85
            just pull
            • fuus
              • 123
              • England
              #86
              Pics attached! How on earth do I get this last heat sync off?! You guys can probably make out the charred remenants as a result of a 40W soldering iron and flux x)
              • Rtech
                • Jul 2010
                • 1095
                #87
                I normally add new solder first, then remove them.
                • fuus
                  • 123
                  • England
                  #88
                  I've tried, and it just doesn't work :/
                  • fuus
                    • 123
                    • England
                    #89
                    Well, the monitor lived for all of 5 minutes, and has now completely died again x( any ideas guys?
                    • fuus
                      • 123
                      • England
                      #90
                      It lives again, then died. I'm experiencing a cycle of the monitor working for about 10 minutes and then cutting out again?
                      • Gingerbeer
                        • 11
                        Something overheating, or maybe a dry joint?
                        • fuus
                          • 123
                          • England
                          #92
                          Another clue to add, the monitor is recognised by my laptop when the display is non functional, could this be a loose connection, or is it still likely to be the PCB?
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            #93
                            As long as the logic (5v) supply is up, the monitor will be identified by the device it is connected to. The problem with this monitor is the 14v rail, so no, it can't be a loose connection. Check voltages when the monitor stops working.
                            A working TV? How boring!
                            • fuus
                              • 123
                              • England
                              #94
                              I have re-disassembled it, and have the Power Supply ready to test, could you possibly point out to me where I should be testing? I'm a complete amateur to this business
                              http://imgur.com/a/9fGor I uploaded a few pictures of my circuit board
                              • Curamrda
                                • 10
                                • Czech republic
                                #95
                                HOLY FCKING FCK FCK FCK FCK FCKING SHT!!!
                                I have replaced the diode and it works!!!!!!!!!!
                                Thank you so much for this thread! it saves me a lot of money!
                                Mira
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  #96
                                  Problem here is we have a lot of pictures but at odd angles and not really clear enough for trouble shooting.
                                  Can you do a clear front and back of each board straight on - they need to look like these
                                  https://www.badcaps.net/forum/attach...1&d=1290283049
                                  https://www.badcaps.net/forum/attach...7&d=1280167246
                                  Use the manage attachments button, which is found by clicking "go advanced" under quick reply.
                                  There appear to be a few cold joints but cant really tell In Pic 5 there is a row of about 6 joints in a row and the nearest looks really bad. In Pic 6 there is something with 3 legs that also looks badly soldered.
                                  • Lumberjack777
                                    • 464
                                    #97
                                    Mira
                                    That's great! You took your time and didn't rush it. Way to go. Another satisfied customer
                                    I'm curious as to the concensus of the current Schottky diode that is being used as a replacement in this monitor. Since the one I used to originally to fix this monitor is out of stock at DigiKey.
                                    Good job figuring out about the possibility of voltage spikes taking out this monitor Th3_uN1Qu3
                                    • Frankey76
                                      • Jul 2012
                                      Hi All. I live in Darwin and also lost power three weeks ago on a DELL 3008wfp monitor out of the blue. Found your site and replaced power supply diode 22 with STPS60170CT. And it's working like a treat. Front bezel removal was a pain in tha a##...fingers.
                                      Cant thank you all enought, fantastic forum.
                                      • Curamrda
                                        • 10
                                        • Czech republic
                                        #99
                                        Originally posted by Lumberjack777
                                        yeah, I disassemble the monitor very lazy and carefully. It took me 3 weeks. I have to thanks the r-sherwood, who sent me the diode. But without this forum , i will be fuck_d!
                                        I didnt believe it will work :] . But as I see how much people have the same problem ... i dont trust Dell anymore. It wasnt the cheapest LCD :] infact its one of the most expensive... and such design mistake is not cool.
                                        Anyway. LCD is back thaks the good people here. So I wish everybody long further usage of their repaired monitors .
                                        See ya
                                        • Lumberjack777
                                          • 464
                                          #100
                                          I checked the specs and that looks right. Thanks mate.
                                          If any newcomers come along: try replacing the Schottky Diode located at D22 with STPS60170CT
                                          You can buy one at Mouser in the USA - http://www.mouser.com/ProductDetail/...bnfvkvqmLQgo4k
                                          And a big thank you to "Th3_uN1Qu3" in post #5 for figuring out the problem.
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                          • Borse2008
                                            Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                            by Borse2008
                                            Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                            I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                            • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                            • There’s
                                            07-15-2025, 04:55 AM
                                            by sam_sam_sam
                                            07-01-2024, 06:34 AM
                                          • master3112
                                            by master3112
                                            07-29-2025, 01:55 PM
