64' Ford Falcon Radio Buzzing
  • R_J
    • 9569
    Re: 64' Ford Falcon Radio Buzzing
    The ones used in this radio are like this, they do rely on air as the gap but have an insulator so if you tighten the screw too much it won't short
    There are a few other types listed on this site http://variable-capacitors.blogspot.ca/
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      I know the ones you are talking about an there is are just air caps. The plates would rust together. Even on the mica ones they can get to a point were they can not be turned. The right type of cleaner will not harm the mica. The problem comes when people use like WD 40 and car degreaser that may attack metal or what ever you may have. So it is important to get the correct contact cleaner. Usually when the cleaner is listed as a contact cleaner it will be safe, but you always have some bafone that sells crap. I have attached a picture of a large air cap. It is the same principle in a smaller package however some cars did utilize the larger ones. These would only get cob webs in them and dust until they got the smart idea of enclosing them.
      here is a smaller one
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        R_J This is a interesting read http://www.iequalscdvdt.com/air-variable.html
        I was looking for the old disk cap exposed to air and with the tiny mica peace that could break easy. I ran across it earlier but could not find it again.
          https://www.badcaps.net/forum/attach...1&d=1480447403
          as you can see, in those car radio, the tuning in of the station is done by moving the slugs of the tunning coils, you can see 4 of them in that tuner assembly. Fixed lot of old car radio when I was young, lot of them due to fail vibrator in the car radio with tubes!
          I also had to replace lots of the rubber clutch disk.
          • goontron
            5000!
            • Dec 2011
            • 4108
            • US
            #65
            Originally posted by R_J
            You no nothing of my experience and I've been in this industry for probably longer than you've been alive. I am far from NEW SCHOOL as you put it. In the repair business 100 radios is nothing.
            Yes, im sure following a repair script and having racks full of equipment makes you know everything in the world /s
            Follow the white rabbit.
            • R_J
              • 9569
              I was going to say something but whats the point, move on
              • keeney123
                Lauren
                • Sep 2014
                • 2536
                and thanks Caphair glad I could help
                So I am 63 years old. How long have you been repairing. Old school does things by their senses new school does things instrumentation. My experience is new school, but I have work with old timers that are old school. So have I miss read you?
                • keeney123
                  Lauren
                  • Sep 2014
                  • 2536
                  Do not give up. Problems get resolved by communicating.
                  You are not going to hurt my feelings and if you hurt other people's feelings because you say what you believe well that is too bad for them.
                    • 31114
                    did the fucking caps get changed yet, or is this just gointg to turn into an insult thread with a de-calibrated radio as a bonus??
                    • redwire
                      • 3912
                      caphair, if you're still out there, I tried to narrow down the make+year of the radio but no luck. Apparently Bendix, Motorola, Tenna, Automatic Radio, Philco were contenders.
                      A capacitor has 1962 date code in your pic. Nothing on the PNP output transistor p/n 8P404V as far as radio make.
                      Bendix was using PC boards, Motorola point-point wiring but not matching your pics. It looks real close to the 1958-1963 Motorola Volkwagen radio schematic, or the 1964 one.
                      For its age, the electrolytics (2caps+3 section can) are surely toast and probably need to replace a germanium transistor or two as others have mentioned. Unfortunately, they are a pain to find. To use silicon transistors needs some circuit mods to work.
                      I find it interesting these old car AM radios, RF section typically uses Japanese 2SA72 or 2SA73 transistors. They must have been better technology then.
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        #71
                        agreed.
                        everything is a waste of time till they are all replaced.
                        those epoxy ended callins are all open now.
                        and i align these by ear too.its a crude radio not rocket science!
                        • keeney123
                          Lauren
                          • Sep 2014
                          • 2536
                          Perhaps these people can narrow down the radio type. This is their email
                          ques@tpocr.com
                          • shelby5041
                            clock radio / radio lifespan?
                            by shelby5041
                            hi
                            ive got a modern digital clock radio approx 15yrs old
                            my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                            since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                            the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                            it uses very little power just a few watts i would imagine that may have something...
                            09-14-2024, 03:30 AM
                          • UserXP
                            Vintage SONY Digital Clock Radio ICF-C12W no audio
                            by UserXP
                            Dear all,
                            I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                            i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                            My question is, do you know of this brand of capacitors and how bad are...
                            07-21-2025, 08:35 AM
                          • praveenramavath
                            Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                            by praveenramavath
                            Hello All,
                            I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                            https://www.hifivision.com/threads/m...-screen.98243/
                            Troubleshooting Summary: Majority Internet Radio - Flash Chip
                            04-26-2025, 09:08 AM
                            HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
                            This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                            09-12-2024, 02:00 PM
                          • Omron
                            Kenwood KDC 3051G Car Radio permanently stuck in Demo Mode please help
                            by Omron
                            Hello Guys! I have trouble with my car radio Kenwood KDC 3051G I hope someone more knowledgeable can help me, I tried everything in my power that I stumbled upon online.
                            My radio is permanently in demo mode, it says Press Volume Knot Cancel Demo and when I press it nothing happens.
                            - Tried to unplug radio and plug it back in into power,
                            - Tried to reset radio by holding reset button key for 5,10,30 seconds while in power and without power, plugging it back in, it wouldn't work.
                            - Tried to hold 3,6 while turning it back on and then pressing 1,2...
                            05-23-2024, 01:27 PM
