Vintage SONY Digital Clock Radio ICF-C12W no audio
Hello, guys. I have been quite busy for the past few weeks, so I didn't have much spare time to work on the radio. I did, however, manage to get in touch with the local radio club and they recommended visiting them as they have several members who deal with older pieces of electronics in the field of radio. But, I didn't have the time to do that as they are open only on two specific days per week after 7 pm, but I definitely intend to visit them as soon as possible.
Now, and idea comes to my mind. If you remember, I replaced the original Tracon capacitors in this unit going with with the same ratings from the single same manufacturer (WE). I now have the idea, since I mended the damaged IF transformer and got promising results, that maybe I should go closer to the original caps. My other working unit has Rubycon CE W series (light blues sleeve) capacitors inside rated at 85°C. Do you know which modern Rubycon series is the closest equivalent of this exact series? I am thinking about ordering them if they are still produced in all the same ratings and go with the Japanese caps altogether. This will also provide me with proper spare caps for my other unit should I need to do any other replacements as well.
Thanks as always for any info on this.Comment
Rubycon's most basic general purpose series is currently PK, or WA if you want a smaller can size. Both are only 85 degrees rated.
I imagine they would be the closest to the originals, although maybe harder to get since most people want low ESR or higher temperature these days.
I'd be surprised if it made any difference, though, the ones you put in are probably fine. From what I saw you used WCAP-ATG5 series? They are general purpose too, just 105 degrees rated instead."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
Yes, that is true. In the service manual, all the capacitors have the same capacitance as the one printed on the caps -except for 16v33uF which is supposed to be 16v10uF. I first went with those ratings, but I will include a 16v10uF this time as per manual to see if it will make a difference. I've read that using caps with higher capacitance in radio/audio circuits can actually hinderv the frequency reception.
Also, I have a question. When opening T4, I noticed that its internal cap looks like a coil actually, in the shape of a hollow tube. On each side the "wire" is simply straightened and goes to the lead where it's soldered. One of these ends was torn when the T4 suffered the damage in which it lost one of the pins and the ferrite coil contact.
Now, i was thinking, by soldering an extension wire from that capacitor's end to the pin, it may have influenced the total capacitance of this internal capacitor. Would it be possible to measure the capacitance of this cap and possibly replace it by adding an external one soldered between the respective T4 pins?Comment
Or, unwinding 3-4 turns of the cap's original wire just enough so it can reach the pin for being soldered onto (would this dramatically change that capacitor's performance)?
For the first suggestion, I would surely have to unsolder on end of the cap off the pin to attempt to measure its capacitance, if possible. Could then use an external cap?Attached Filesif you find these attachements useful please consider making a small donation to the site
Just the way they've connnected the wire to it, I'd say. I would leave it alone, if you damage it you don't know what the value is.
I think what you need to do is to get it aligned correctly now that you fixed the broken connection."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
Hi, people.
After a long pause, I would like to kind of update this topic. I took the radio to a local radio club, but they couldn't do it. I then decided to try and align the reception a bit by myself. I first replaced the CF, just to see if it would make a difference. I then made a small plastic tool to use for turning the snugs. I then confirmed that T1, T3 and T4 influence the FM signal, T2 and T5 (both red) affect the AM sound.
The blue T4 increases the volume the most and there is very small range within which it has that effect and no crackling or distortion. T3 impacts only the sound set by T4, it increase the overall volume a bit too. T1 has a very mild effect on the loudness, so I left it in the sweet spot position - but that's it.
Bottom line, the highest volume I was able to set is still about 50% lower than it should be.
The IC1 is new, the CF is replaced, all the capacitors... all snugs positioned where the volume is at its highest, reception is great, but low in volume. I don't know, there must be something inside the frequency transformers, a cracked or worn ferrite core, bad internal capacitor... I am out of ideas.
Unfortunately troubleshooting further likely needs equipment like an oscilloscope and such. But hey at least it works at all! You solved some interesting problems and I'm sure learned a lot.
The only other thing that springs to mind is a leaky diode or such that's causing problems under load. Basic Vdrop measurements on a multimeter won't typically tell you if a diode is leaky, only if it's shorted or open."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
by mikey5791Hi forum members,
In the past i have had many helpful hints from generous forum members in diagnosing and solving issue related to most of my electrical things.
Fyi, i have been keeping this unit of Sony radio cassette player as the cassette belting has worn off but the radio has been working fine before. Recently, out of a sudden i found out i can't get any radio reception at all (no signal from FM,MW or SW band) except some buzzing warp noise from the speakers.
I opened the casing inside and checked for any dry solder, burned component or loose wires...-
by BOSCHNJAKABOUT ME INTRODUCTION FILE
2024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
2022 BEV, PROJECT ?
2021 BEV, PROJECT ?
2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...-
Channel: Visitor Messages
12-28-2023, 02:09 PM -
by CapSnap123I'm trying to fix a digital multimeter. It was working until I blew the fuse (actually the "buzz" for continuity wasn't working). I've now replaced the fuse but it's acting strangely. When I turn the dial to V, nothing happens. But when I turn to anything else, it makes a continuous, very fast clicking sound - like the piezo buzzer is trying to do something. And at each position of the dial (other than V) there are brief flashes of life on the LCD. It doesn't seem to matter if the probes are connected. I wasn't sure where to start, so I've tested most of the diodes and cleaned the...
Hello All,
I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
https://www.hifivision.com/threads/m...-screen.98243/
Troubleshooting Summary: Majority Internet Radio - Flash Chip...-
by Carlos#2003%Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
Channel: Schematic Requests ONLY!
- Loading...
