Panasonic Inverter Refrigerator model NR-BY602XS - suddenly not cold overnight
  • beetle1303
    • Jul 2019
    • 279
    • Singapore
    #41
    Re: Panasonic Inverter Refrigerator model NR-BY602XS - suddenly not cold overnight
    Originally posted by stj
    you could wire them so one end of each lamp is joined, and the other end is hooked to the V,W & U signals like in the diagram,
    that would be pins 7,9 & 11
    Pardon me for being extra cautious as I am quite terrified of high voltage wiring - please help confirming the wiring is correct per your description.
    Thank you.
      • Jul 2011
      • 6039
      Yes you could do that way as long as the voltage rating on light bulbs is above what the voltage of compressor would see
      I would still read the voltage across each leg
      1 and 3 / 2 and 3 / 1 and 2 the voltages should be no more than 10% different from each other unless there is a high leg
      • beetle1303
        • Jul 2019
        • 279
        • Singapore
        #43
        Thank you for confirming the wiring diagram.
        I have done the reading across each leg:
        1) 1 & 2: 160.x vac
        2) 1 & 3: 160.x vac
        3) 2 & 3: 160.x vac
        I did it once only but taken a few readings over a few minutes. Each time the readings are about the same.
        Just to be sure:
        I inserted a straighten paper-clip each into pin 7, 9 and 11, and measure the voltages across 7 & 9, 7 & 11, 9 & 11. Hope this is correct way to measure them.
          • 31019
          the lamps are in series-pair so you would need more than 480v to damage them.
            • Jul 2011
            • 6039
            1) 1 & 2: 160.x vac
            2) 1 & 3: 160.x vac
            3) 2 & 3: 160.x vac
            Just to be sure:
            Now you need to know if the amperage is the same on three legs with the lights bulbs and with the compressor
            Not all amp probes are the same when it comes to reading VFD drive output because of the waveform that a VFD drive has some of can not read it
            But if your amp probe can read it there should not be more than 10% different between legs
            If the test results are very close to the same then it could be that the compressor has issues or you have a seal system fault of some kind
            Or
            You could have a problem with the inverter not working correctly
            • beetle1303
              • Jul 2019
              • 279
              • Singapore
              #46
              Or
              I only have 2x 40-watt bulbs, and could get another to try. So I wire up my DMM in series, without the bulbs, with each of the 3 pins, one at a time:
              _______________start-up_____1-minute later
              Pin 7(W):_______~0.265A_____~0.235A
              Pin 9(V): _______~0.258A_____~0.223A
              Pin11(U):_______~0.276A_____~0.210A
              So all the pins started a little higher, and lowered down a little bit after a minute or so.
              Are these readings valid? And of so do they look normal?
                • Jul 2011
                • 6039
                How bright do the light bulb get this amperage seems a little low
                Can you do this test with 100 watt bulbs if possible
                • beetle1303
                  • Jul 2019
                  • 279
                  • Singapore
                  #48
                  I only have 2x 40 watts bulbs. Can I wire them in series and connect the 2 ends at any 2 of the 3 pins like in the pic below?
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    #49
                    Here's the link for 1 such pic that caused this error: https://we.tl/t-lLIq3zXP41
                    ** I just did a resized from 15mb to 4mb, then it loads OK.
                    Sorry for the delay, I have changed the PHP settings to allow larger files to upload.
                    I tested with your linked picture and it works fine now.
                    But this one was 4MB, does the 15MB version upload fine too now or does it still error out?
                      • Jul 2011
                      • 6039
                      The only one with heatsink is this giant one labelled IMP301 on the board. The only IGBT I can see but without heatsink is MIP414MD
                      IMP301 part is not a good part number
                      The MIP414MD is a good part number but it a some kind-a power switching power supply regulator
                      You have not found something like a IGBT module module mount in the case some where
                        • Jul 2011
                        • 6039
                        I see a couple of problem with the power to the compressor
                        The compressor data label clearly state that the voltage is 240 volts
                        Why are you only getting 160 volts number one
                        Why is your amperage look low to me this might be issues number 2
                        Issues number 3 is you say that when the compressor run it is not very cool and the heat comes from the condenser coil is not very hot I being to think that something might be wrong with the compressor or your meter device or you might have a gas leak
                        Does this unit have a data plate on it if it does can you post a picture of it
                          • 31019
                          i doubt most meters will give decent readings on a high frequency drive.
                            Some info I found about Panasonic Inverter compressor:
                            http://web.mit.edu/parmstr/Public/x/...onsumption.htm
                            • beetle1303
                              • Jul 2019
                              • 279
                              • Singapore
                              #54
                              This is strange - the original file from my phone camera is 4.3MB, transferred to my Windows 10, resize shown 15.2MB!
                              But I have since tried loading file sizes bigger than 4MB, all OK now. Thank you.
                              • beetle1303
                                • Jul 2019
                                • 279
                                • Singapore
                                #55
                                I did some tests with a 40 watt bulb, one pair of pins (7&9, 7&11, 9&11) at a time. All results are all the same:
                                - The bulb lights up for a about 1 second, then goes off, and remains off.
                                - It grows from nothing to peak (about 10% of normal I guessed) and dims down to nothing all within a second, then remained off for next few minutes during tests.
                                - The compressor never get turned on from the start! But the evaporator fan is on, interior lights are one, and panel indicators are on.
                                • beetle1303
                                  • Jul 2019
                                  • 279
                                  • Singapore
                                  #56
                                  I found a few of these SMT type of transistors, not sure what they are.. Other than these there isn't anything familiar to me..
                                  • beetle1303
                                    • Jul 2019
                                    • 279
                                    • Singapore
                                    #57
                                    By data plate do you mean this in the pic below?
                                    I am just curious - if the compressor runs at whatever speed, and the inlet is slight cool, the outlet is warm (not hot), and the evaporator coil has refrigerant flowing with gurgling sound, etc, shouldn't the evaporator coil be slightly cool the the touch?
                                    • Per Hansson
                                      • Jul 2005
                                      • 5895
                                      • Sweden
                                      #58
                                      The picture of Win10 you refer to shows the picture size in megapixels.
                                      I.e. resize from 15 megapixels to something smaller...
                                      4608 x 3456 = 15925248 or 15.93 megapixels
                                      • R_J
                                        • 9535
                                        Refrigerators don't make cold, they remove heat, so the evaporator might not feel very cold. the gurgling sound does suggest the compressor is running. But the diagnostic still gives an error?
                                        • beetle1303
                                          • Jul 2019
                                          • 279
                                          • Singapore
                                          #60
                                          Ahh.. MP, not MB. Thanks, all good now.
                                          • SuperAman
                                            Hitachi Refrigerator R-Z270AUN7KV not cold.
                                            by SuperAman
                                            Hi, I have a Hitachi Refrigerator R-Z270AUN7KV. The fridge is on the bottom and the freezer is on the top. My problem is no matter what setting (1-9) the freezer is, the fridge is not getting cold but the freezer is always cold. I have tried all combination of settings for the fridge (Min, Mid, Max) but nothing. Fridge is always hot now. Before it would sometimes do this but now always fridge is hot. I believe the service center peeled some of the foil from the thermostat and that seemed to help a few years back. I replaced the thermostat recently and it worked off and on for a few weeks but now...
                                            10-29-2020, 02:01 AM
                                          • x_orange90_x
                                            by x_orange90_x
                                            01-29-2025, 09:24 PM
                                          • Gentian
                                            APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                            by Gentian
                                            I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                            It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                            03-06-2023, 07:07 AM
                                          • valvashon
                                            Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                            by valvashon
                                            For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                            History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                            01-04-2024, 01:44 PM
                                          • eccerr0r
                                            A modified sine wave inverter + a grid tie inverter?
                                            by eccerr0r
                                            If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                            Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                            08-31-2023, 09:14 PM
