Directly replacing NiMh cells with Li-Ion cells - bad idea ?
+ More Options
Posts
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    #81
    Re: Directly replacing NiMh cells with Li-Ion cells - bad idea ?
    Originally posted by eccerr0r
    Currently I just use my power supply to power it if I need to use it.
    Yeah, a friend of mine did this with an ATX supply
    Wattevah...
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      #82
      Vac works once again with the LiIon "mod" and I have mixed feelings: first of all, he's tested it under light load conditions all this time. Once you activate those roller brushes and they start dragging along the ground, I can imagine that causes additional load which may be detrimental to the cells. Overdischarge could be handled by the IC after all, despite the chemistry being different.
      Second, the charging: as previously discussed, not sure if the IC that's in there is "tuned" for LiIon cells - different current, different voltages....all sorts of problems, so I definitely wouldn't sleep soundly after doing such a mod for a client and charging for it...
      Wattevah...
        • 31170
        there may not be discharge protection - ni-mh dont need it.
        you can just run them into the ground and charge them just fine after.
        btw, do you have a DC clamp meter??
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          #84
          Aye. An UniT UT-210e. He's packed it back up unfortunately, so measuring stuff is no longer an option at this point I'm afraid...
          Wattevah...
            • 31170
            it will probably be back!
            (hopefully not chared and in an "evidence" bag!!)
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              #86
              Originally posted by Dannyx
              Odyssey more like
              Glad you're having fun. I sure am (I'm such an ass, aren't I ?).
              Well, yes and no (to all that). I mean, I would have probably done the same too, up to a point. But if I see someone is doing something stupid, I'd always offer to lend them a hand, even if it's likely to backfire on me (as in, the other person get grumpy about it, because they thought you are insulting their "intelligence". ). In any case, I would probably walk to the guy and jokingly throw a, "are you still working on this piece of crap"... then just "lightly" suggest that IKEA might have the real proper parts he needs to fix this and just get it done.
              It's a good thing I had it round the shop, even in this semi-functional form, because it enabled me to assess its suction power, which is certainly not going to be on-par with a canister or mains powered vac, but still satisfactory for the aforementioned endeavors.
              Yeah, IDK... I personally hate battery-operated "power" tools and appliances. I consider them pretty much "disposable". The only batt-operated power tool I have is a hand drill / screw driver, and it's already been "converted" (more like kludged / jury-rigged) to run off an Xbox 360 PSU. It's kind of weak and slow compared to my corded drills so I rarely use it. But sometimes when I don't feel like walking to the garage to get my corded drills and need to drill into something thin / soft, the "Xbox 360 drill" (as I call it now ) does the job OK.
              Same with Ni-Cd.
              Only problem with deep-discharging Ni-Cd and Ni-MH packs with series cells is some cells will discharge before others... and the ones that do could be forced to "reverse-charge" from still somewhat-charged cells. Neither Ni-MH nor Ni-Cd cells like this, so they'll get trashed over time. However, if you take the individual cells and deep-discharge them, you can keep them stored like that for years (and in fact is the preferred method for them, as it prevents dendrite growth).
              LOL Very likely, yes.
              Just like that song:
              https://www.youtube.com/watch?v=LjMffHG1V_Q
              Speaking of which... Danny, I think you should play that for your colleague while he's fixing the vacuum... see if he gets any hints.
              P.S. I think I'm a bigger ass than you, aren't I? Or maybe we are just "disrespectful youth" as your OG colleague would say about us anyways.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                I wonder how much longer NiCd/NiMH packs would last if there was an overcharge/overdischarge controller ... now that's a thought...
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  • Romania
                  #88
                  I find it interesting that the same mod he attempted on a similar vac is still working...or at least it hasn't returned. I can't tell if that's because the chap simply didn't use it or they simply got lucky...both of them
                  Wattevah...
                    • 31170
                    or he died in his sleep from smoke inhalation!!!
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      • Romania
                      #90
                      No police around here yet
                      Wattevah...
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        #91
                        Maybe the batteries burned so bad there was no evidence left of what caused the fire?
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          • Romania
                          #92
                          Vac's still in the shop BTW, all packed up and ready to go. "Mr. Battery" called the client to come pick it up, but he hasn't showed up so far. Guess the chap is too afraid something might go pop and doesn't want to pick it up again LOL Occasionally "Mr. Battery" here gives it a whirl, sucks up some stuff and plugs it back in to keep it all nice and topped up and I'm like talking to those cells "hang in there, he'll relent soon enough"
                          Wattevah...
                            So the company you work for will be reliable if something goes wrong?
                            • Dannyx
                              CertifiedAxhole
                              • Aug 2016
                              • 3912
                              • Romania
                              #94
                              Of course - there's a 3 month warranty period for all repairs, which makes perfect sense from the client's perspective (it's also in the law here AFAIK), but it can become problematic for the company if doing semi-functional repairs like these where something is bound to go wrong...
                              Wattevah...
                                So the company gives freedom to do what ever he wants even it is dangerous.
                                • Dannyx
                                  CertifiedAxhole
                                  • Aug 2016
                                  • 3912
                                  • Romania
                                  #96
                                  It's assumed that "he know what he's doing" given that's what he's employed for. There's no real way management can actually gauge a technician's performance and/or overall skills and knowledge, other than keeping a close eye on the service tickets they receive, how they go around handling them and how many they've actually successfully fixed.
                                  Wattevah...
                                    • 31170
                                    maybe the vac owner read this thread!
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      • Bulgaria
                                      #98
                                      Either that or the fact that it's been so long has perhaps made the owner realize they don't need this vac... or they already bought another one and don't want to come pickup this one because they don't want to pay the service fee (after all, I suppose you charge the customer after the item is fixed, correct?) In this last case, your friend, "Mr. Battery" will have a neat little vac to clean his bench... until it burns down the shop anyways... or the batteries die again.
                                      • Dannyx
                                        CertifiedAxhole
                                        • Aug 2016
                                        • 3912
                                        • Romania
                                        #99
                                        Yes, but in this case it's considered to be under warranty since the first set of batteries went kaput last time, so I don't think he'll be charged anything extra. I also just recently learned that it's not a client per-se, but rather another employee from a different department who asked him to take a look at this vacuum, so the rules are more relaxed here as far as fiances go at least...we'll see. No grudges against him - it's all a learning experience
                                        You were right: I'm having just a little bit too much fun with this thread
                                        Wattevah...
                                        • eccerr0r
                                          Solder Sloth
                                          • Nov 2012
                                          • 8701
                                          Well, I picked up another junk handheld vacuum cleaner for a buck. I grabbed it because it seems to still be spinning, and said "lithium 3.6V" ... Jackpot, it might actually match the specifications I need for the one I have.
                                          I opened it up, and it appears to have a similar wiring diagram...battery straight to the switch and motor. It looks like it has a single small circuit board in it, wonderful, it's got to be a protection/charger board. Inspecting it closer...weird, no big FET on it? This thing needs to withstand 10A and no SOT-23 will do it, must at least be a D-PAK?
                                          Oh well, so I pulled the battery and the circuit board and measured the voltage. It was down to 3V, which is probably still fine. Supposedly it's a 1.5Ah cell, and it says 3.6V, and appears to also be rated for 5.4Wh - so this is probably a lithium ion manganese cell versus a cobalt or iron phosphate cell. So I stuck it on an external charger bypassing the board, and see how it goes... up in flames maybe? Hopefully not, I still need to figure out how to charge this thing.
                                          Well why not keep this vacuum and ditch my old one? The one I have is a wet/dry unit, and this one has a funky charger connector... Combine and get the best of both worlds.
                                          • AlexVG
                                            Replacing the WiFi module on a vacuum cleaner iROBOT i7
                                            by AlexVG
                                            I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
                                            I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
                                            (This board does not respond, only the LEDs light up in a circle.
                                            The liquid damage is catastrophic and restoration is impractical).
                                            (I bought this board to get the WiFi module and camera).
                                            The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
                                            If...
                                            10-22-2024, 07:20 AM
                                          • Chaks
                                            The ups takes 3 x 18650 cells in Parallel - Can I extend to 6 x 18650 safely?
                                            by Chaks
                                            I need help to extend the runtime of the ups board (see attached image).
                                            This is ups board for a CM4 which has 3 18650 cells in parallel. Can I extend the 3 cells to 6 cells for a longer runtime? by soldering a wire to each of the battery terminal and connecting it to a separate battery case with 6 cells.
                                            Thanks and kind regards,
                                            chaksindia...
                                            01-21-2025, 11:39 AM
                                          • flat-earther
                                            Hoover FM216LI cordless vacuum refuses to charge
                                            by flat-earther
                                            I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                                            I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                                            5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                                            So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                                            06-06-2025, 03:14 AM
                                          • Petr0x
                                            Bosch 12V and 18V chargers modification
                                            by Petr0x
                                            Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
                                            You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
                                            Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
                                            05-24-2024, 01:00 PM
                                            ZD-915 vacuum pump motor mount service alert
                                            by sam_sam_sam
                                            If you have this Desoldering Gun Station there is something you should be aware of the two screws that hold the motor to mounting for pump can come loose and make raddling noise
                                            One note this unit has been repaired already once because of switching power supply regulator ic chip failure
                                            Now this with the vacuum motor mounting issue yes I give this Desoldering station a very hard work out and use about every weekend to do some type of project
                                            The fix is taking the vacuum pump assembly out and take the metal cover off and you will see the two screws on it
                                            09-19-2021, 02:15 AM
