Hoover FM216LI cordless vacuum refuses to charge
  • flat-earther
    • Dec 2022
    • 124
    • palestine
    I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
    I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
    5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
    So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries.
    The charger is an external AC to 26VDC charger with a barrel plug.
    When I opened the vacuum I noticed that the PCB that controls everything had a lot of dust buildup on it, (I already cleaned it and didn't take photos of the dust).
    This is the PCB after cleaning:
ID:	3653397 Click image for larger version
    When I was doing some probing on the board, one of the 0603 68K resistors near the power switch (this area had a lot of dust buildup) didn't give any reading and then I noticed that the solder joints of that resistor crumbled from my sharp probe tips, what does that mean?:
ID:	3653399 Click image for larger version
ID:	3653400 Click image for larger version
    After repeated probing of the resistor I managed once to get a 68kOhm reading measuring right on the resistor, but there was infinite resistance between the resistor and the transistor marked S3 even though they should be connected through a trace. (the other side of the resistor connected through a trace to the nearby 01C resistor had continuity)
    So I tried to reflow one side of the resistor with a soldering iron but that didn't help and after probing it some more the resistor just detached from the PCB completely, and after that I saw that the problematic pad on the PCB was in rough shape, but I managed to somewhat revive it with solder and wick:
ID:	3653409 Click image for larger version
    Anyway, now I fried that resistor so I need a new one.
    Do you guys think that resistor was the culprit of not charging? I wonder whether the charging will work again if I replace that resistor.
    Additional photos:
ID:	3653402 Click image for larger version
ID:	3653403 Click image for larger version
ID:	3653404 Click image for larger version
ID:	3653405 Click image for larger version
ID:	3653406 Click image for larger version
ID:	3653407 Click image for larger version
Name:	main body for floor cleaning.jpg
    PCB markings:
    AS-8206BPL2 21.6V
    LA-PABS-8206-A2
    This vacuum is designed such that the handheld unit detaches from the main body used for floor cleaning.
    I noticed there is a vacuum from another brand that looks physically similar, Rowenta Dual Force RH6751WO
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8261
    I doubt the resistor is the cause. Resistor marking 683 = 68k ohm.
    Did you verify the external power supply actually delivering 26VDC to the BMS board? Just to rule out any chance as a PSU issue. Look at that resistor I circled, it looks like it has a hole in it.
    • flat-earther
      • Dec 2022
      • 124
      • palestine
      Thanks.
      My bad, that white is residue from when I cleaned the board with alcohol and didn't dry it well. I wiped it clean now, here's some new photos.
ID:	3654808 Click image for larger version
ID:	3654807 Click image for larger version
ID:	3654806 Click image for larger version
      That resistor you circled measures 0.0 Ohms so it's okay.
      I have labeled the wires connected to the board so it's clear what each is for:
Name:	board wires labeled.png
      Measuring the charger plug output without connected to the vacuum, it is 27.50V, a bit higher than labeled, I assume that's fine and since it's not under load.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8261
        Check QC1 and D13. QC1 = AO4459 P-channel (so it is negative) mosfet with a body diode. Look at the gate drive. If there is no gate drive, the mosfet wont do anything. It is configured as a on/ off switch.
        Plug the charger in and measure the voltage coming in and going out of this mosfet.
        • flat-earther
          • Dec 2022
          • 124
          • palestine
          With the charger plugged in, black probe on ground, measuring voltage at input of the charging mosfet, I see it's constantly jumping between 27.5 and up to even 27.88V:
          Click image for larger version  Name:	image.png Views:	0 Size:	1.26 MB ID:	3654824
          At the mosfet's output the voltage is constantly jumping between 7.6 and 8V:
          Click image for larger version  Name:	image.png Views:	0 Size:	1.26 MB ID:	3654825
          At the mosfet's gate it's 27.2-27.6V:
          Click image for larger version  Name:	image.png Views:	0 Size:	1.26 MB ID:	3654826 Is such high voltage at the gate normal?
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8261
            Carefully get rid of that white beigeish goo on the inductor and suroundings. All of it. You may use heat and 99% IPA to pick / peel it off...
            • flat-earther
              • Dec 2022
              • 124
              • palestine
              BTW I have manually charged the cells with an external charger so they wouldn't be empty. Right now the battery is at 24V.
              How do you want me to check D13?
              • flat-earther
                • Dec 2022
                • 124
                • palestine
                Just to experiment, I have set an external power supply to 26V because that way I can see current draw on the power supply.
                When I plug that power supply to the vacuum I see a very brief about 1A current draw and then it instantly drops to zero.
                • flat-earther
                  • Dec 2022
                  • 124
                  • palestine
                  Well removing that glue was extremely difficult. I used a 25W iron with sharp tip to pick it, then tweezers, and I destroyed the inductor by accidentally pulling the copper wire along with the glue with tweezers and the wire snapped.
                  I will need to try and resolder that wire back but it's so short I'm not confident in it, if that doesn't work I may unwind it one rotation to make it longer. I hope I didn't short the winding by scratching it with the tweezers.
ID:	3654953 Click image for larger version
Name:	inductor wire cut.png
ID:	3654951 Click image for larger version
                  From one side of the inductor to the end of the broken wire it measures 0.3 Ohms, is that still okay?
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8261
                    The inductor should measure a short. Disconnect everything from the board and check D13 in diode mode. Should have something like 0.3V drop one way and an open the other way.. hmm dunno… maybe the HT66F018 went south. That would suck, as it is a programmable chip.
                    • flat-earther
                      • Dec 2022
                      • 124
                      • palestine
                      Disconnected all power from board, D13 in diode mode is open line one way and 0.217V the other way.
                      BTW while the inductor is essentially disconnected is there anything I should test in this state before reconnecting it?
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8261
                        Check that gate drive circuit again with that z5 etc in diode mode, no power.
                        that zener diode is a 15V zener. So it should be clamping down any excess voltage to 15V.
                        • flat-earther
                          • Dec 2022
                          • 124
                          • palestine
                          All power disconnected, measuring Z5 in diode mode, OL one way, 0.725V the other way.
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8261
                            That’s o.k.
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8261
                              I’d say replace that resistor that’s broken make sure the traces around there are going where supposed to be going, check across all the MLCC that there is no short, then try charging again.
                              • flat-earther
                                • Dec 2022
                                • 124
                                • palestine
                                I tested all ceramic caps, didn't find any shorted. Ceramic cap C9 near motor wires is about 1 Ohm but the motor wires are soldered there so I think that's just the motor resistance.
                                All power disconnected, I measured in diode mode diode D1, 0.663V one way, 0.571V the other way. Is that okay?
ID:	3655260 Click image for larger version
ID:	3655261 Click image for larger version
ID:	3655262 Click image for larger version
                                • CapLeaker
                                  Leaking Member
                                  • Dec 2014
                                  • 8261
                                  Take it out or lift one leg and check that diode again. Diodes should read to 99% one way but not the other, unless it is a bidirectional TVS diode.
                                  • flat-earther
                                    • Dec 2022
                                    • 124
                                    • palestine
                                    I removed the diode D1, in diode mode it measures 0.575V one way, OL other way.
                                    In resistance mode 68kOhm one way, OL other.
                                    • flat-earther
                                      • Dec 2022
                                      • 124
                                      • palestine
                                      D1 diode soldered back.
                                      Inductor repaired. I bent the copper wire down and soldered it to the pad.
                                      Click image for larger version  Name:	IMG_3253.jpg Views:	0 Size:	1.36 MB ID:	3655525 Click image for larger version
                                      • CapLeaker
                                        Leaking Member
                                        • Dec 2014
                                        • 8261
                                        Now replace that 68k resistor and make sure the traces are good around that area.
                                        • jinu_j
                                          by jinu_j
                                          Hi
                                          05-03-2025, 10:51 PM
                                        • mikey5791
                                          by mikey5791
                                          Hi to all forum members,
                                          12-26-2024, 04:55 AM
                                        • MidnightRoller
                                          Can a resistor lose resistance after hot air?
                                          by MidnightRoller
                                          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                          02-02-2022, 11:46 PM
                                        • artvandalai
                                          What resistor ohm will work better to repair this waterpik?
                                          by artvandalai
                                          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                          01-05-2025, 04:10 PM
                                        • chth96
                                          Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                                          by chth96
                                          I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                                          Since then, This AC/DC adaptor have been out of order.
                                          But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                                          After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                                          And Is there any possibility that it will suddenly explode as well as to be out...
                                          12-03-2023, 04:40 AM
