The ups takes 3 x 18650 cells in Parallel - Can I extend to 6 x 18650 safely?
  • Chaks
    • Sep 2015
    • 115
    • India
    I need help to extend the runtime of the ups board (see attached image).
    This is ups board for a CM4 which has 3 18650 cells in parallel. Can I extend the 3 cells to 6 cells for a longer runtime? by soldering a wire to each of the battery terminal and connecting it to a separate battery case with 6 cells.
    Thanks and kind regards,
    chaksindia
    • 31265
    you can.
    but a few things to remember:
    your charge circuit is the same so it will take longer to charge,
    your cells must all match and be balanced when you put them in - so you cant mix-n-match
    the more cells you use the faster they will go out of balance and have to be manually balanced.
    you do that by charging each of them seperatly so they all have *exactly* the same voltage.
    laptops used to use 2 cells in parallel without issies btw.
    • Chaks
      • Sep 2015
      • 115
      • India
      So this seems a bit tricky ... I have 6 x 18650 (3000 mAh) in parallel going to the UPS charge circuit which has inbuilt parallel charge circuit for 3 x18650 cells.
      if I have to manually balance the other 3 cells in parallel separately then I am stuck.
      ... Because balancing the cell individually while at the same time they are connected in parallel (and live) to the UPS.
      Are there any BMS modules that do this? If so then how to connect it to the same UPS charging +- terminals.
        • Jul 2011
        • 6070
        STJ has is correct for the most part but I would also add this
        Depending on the BMS protection boards some of them will allow you to use them in parallel but the issue that most of them they do not tell you if can use it in this configuration or not you would have to try it ( meaning that you have three in series to a BMS then another three in series and another BMS board ) the way that you can tell if your BMS protection boards allows this configuration is you have to put a heavy load on both BMS protection boards in parallel and check the output load on both BMS boards are they very close to each other and check the voltage on the individual battery cells and see if the voltage is consistent between battery cells on both BMS protection boards if they are roughly the same on each battery pack then you are good to go with this part but also do the same thing in the charging mode as well you should get the same results if so then the two BMS protection board are compatible with each if you do not get these results do not use them in this configuration look for a different set of BMS protection boards are compatible with each other )
          • 31265
          another option is to replace the 18650's with 5 o 6 AH 26650's or 26700's
          double the capacity with the same number of cells
            • Jul 2011
            • 6070
            I would agree with you the only problem is finding well known brand name manufacturer made in Japan or Taiwan or Korea I would not necessarily use batteries from Canada because there quality is questionable to from my experience 26650 and 26700 it is very hard to find 21700 are also hard to find but you can find Japan made cells
            The quality of Chinese made batteries manufacturers are from good quality to very bad quality that I would not even consider using at all I have seen some decent quality made Chinese battery manufacturers but unfortunately because they use so many different manufacturing names it very hard give you any advice on what and how to choose good quality battery from China
            But you can tell very quickly if you got bad quality ones versus good quality ones but one other thing I have noticed is that if the only thing on the heat shrink tubing is the battery size and maybe the milliamperes and no manufacturers name you can much figure that they are going be poor quality ones to stay away from
            Here is a case in point I had bought a special power tool to install thread rivets and the battery was rated for 2 amp hours but this battery seemed to not last a very long time using the tool and then it sat for several years because the part of the tool broke but the impact tool motor still worked so did the battery pack which I just found it again but the battery was completely dead no voltage at all on all cells
            I have had other battery cells that have sat for several years and still have voltage but granted maybe not much but at least a volt or a little bit more and these are Japan made battery cells
            • Chaks
              • Sep 2015
              • 115
              • India
              Thanks a lot for all the suggestions ...
              The complexity of adding 3 additional 18650 cells in parallel to the UPS has put me off ... as there are too many critical variables to be taken care of and the amount of time/effort required for getting something called stable. To be honest I am scared to take any chances with Charging/Discharging LI-Ion batttery circuits.
              My only other option is to get a battery case for 3 x 21700 5Ah cells and pull each parallel connection from the UPS and Connect it to the respective battery terminals. This is the safest I thought.
              Genuine 26650 and 26700 are rare or very expensive here in India.
              21700 5Ah cells Samsung INR21700-50S 3.6V 5000mAh 9C Li-ion Battery is availabe here in India and costs about 8 USD each so its 24 USD for 3 cells.: Total Capacity :15 Ah
              18650 3.5 Ah cells SAMSUNG INR18650-35E 3500mAh (2c) LI-ION BATTERY is availabe here and it costs about 6 USD each so its 18 USD for 3 cells. Total Capacity : 10.5 Ah
              I will settle for roughly 50% increase in capacity (10.50 Ah vs 15.00 Ah).
              Will the charging circuit designed for 18650's work efficiently with 21700's ?. and more importantly ... safely?.
              Chaks India
                • 31265
                the charging circuit only cares about voltage, using bigger batteries just means it takes longer to charge.
                  • Jul 2011
                  • 6070
                  I would second this the only thing that might happen is if it has a fuel gauge device that tells you how much power left it might not be accurate anymore because of using high amp hour battery capacity so it might show that you are about to run out power but in really there might 1/3 more power than what it is reporting
                  • spleenharvester
                    Reverse engineering of 18650 4-channel tester
                    by spleenharvester
                    Hi friends
                    I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                    05-04-2025, 02:43 AM
                  • Patriarxis
                    DELL latitude 5490 it takes 0.002A instantly and then goes at 0.
                    by Patriarxis
                    Hello
                    i have a DELL latitude 5490 it takes 0.002A instantly and then goes at 0A
                    it dosent turn on .
                    01-16-2025, 04:28 AM
                  • Crystaleyes
                    Calculating resistor values in parallel with Caps
                    by Crystaleyes
                    Hi all.
                    I recently picked up a dead car amplifier from the flea market, with the intention of learning some more in the area of audio repair.
                    It has a stereo output with an added mono woofer output. The stereo channels are on one board, whilst the woofer section is on a separate board. There are also three large (ish) transformers.
                    Apart from the fact that it was seriously dirty inside, it seems to be essentially complete with the only clearly damaged component being a toasted 1/4 watt resistor on the woofer board and it is this which I am wondering...
                    05-21-2023, 07:35 PM
                  • edugimeno
                    Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                    by edugimeno
                    Hi There!
                    I'm trying to help my friend who owns a restaurant be just bought.
                    He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                    It's stuck using, I guess, the 2 sided tape that comes with the strip
                    The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                    09-05-2024, 09:34 AM
                  • spike93
                    Xbox 360 parallel caps
                    by spike93
                    I'm probably going to ask a very noob question but after many readings and videos I'm still unsure on the answer.
                    I've broken one of the caps around the gpu of an xbox 360 by overheating it. In the forum I've found this thread where the user had exactly my situation (same console version and same broken caps): https://www.badcaps.net/forum/showthread.php?t=24983
                    The difference is that I've broken only one of the Rubycon caps (or at least that's what I can tell from a visual inspection). Now I'm planning to use a solid capacitor as replacement,...
                    02-18-2023, 10:45 AM
