Directly replacing NiMh cells with Li-Ion cells - bad idea ?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Directly replacing NiMh cells with Li-Ion cells - bad idea ?
    No, it could not have been a cheap cell. The internal impedance of this cell necessarily is low because of the heavy load it needs to drive. Remember this thing needs to discharge at 8C. Surely if it's discharged at 8C, it can be charged at 1C at least?
    Does that cheap battery you buy get hot at 2C load? Probably does if it gets hot at 2C charge.
    Oh BTW:
    I charged it with a CC-CV charger when I first got it as a test, and it did not get warm at all!
      • Jul 2011
      • 6063
      If this is case then I am confused about why charge the battery at such a low rate
      I curse what brand name is this battery that is in this unit
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Yeah the battery was covered in paperboard (which was around the heatshrink), so I couldn't get a brand or model number without ripping it apart. I figure let sleeping dogs lie, it works, don't fsck with it or fsck with it minimally. I guess I have to stick with my conclusion even if it's unfounded, at least until it stops working... mainly had to make assumptions because I needed to charge it and didn't want to buy/integrate a fast charge system for it.
        Besides, if I needed to run this vacuum more than even 5 minutes at a time, I might well try to use an AC powered vacuum. Or even the 12VDC vacuum I have...
          • Jul 2011
          • 6063
          You have a good point
            • Jul 2011
            • 6063
            You’re assumptions might be correct in that if only used for a few minutes at a time then you do not necessarily need to have a fast charging rate if used in this manner because most of the time people would have the unit on charge all the time anyway
              • 31190
              it's probably just lazy designers,
              charge controllers cost peanuts now.
              that said, larger psu's dont.
              so it may be slow to reduce the cost of the transformer.
              btw, all the solar lights i'v opened have been NiMH
              it would be a bit risky putting a lithium or lipo in the hot sun!!
              there are other exotic chemistry's about, but they arent cheap or superior to NiMH
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                #147
                Well guys he did it again: my super skilled old man here replaced some cordless DRILL batteries with Li-Ions now and added a Wii-U charger in parallel to charge/power the thing, so if you thought the vac deal was questionable, this is downright dangerous IMO I'm afraid we might see the shop up in flames one day
                Wattevah...
                  • 31190
                  still in the shop??
                  i would love to know the stall current of the device.
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    #149
                    Originally posted by stj
                    still in the shop??
                    Yeah, I'm still here amazingly, if that's what you were getting at
                    The stall current is precisely what I was thinking of too, because we know high-torque motors can draw quite some amps - they put BMSs in there for a reason ! I don't know for sure since I haven't measured it and probably never will, but the 3.5a adapter would occasionally give up and the drill would stop when you start putting significant pressure on it. He doesn't seem to get it, so he keeps believing there's some sort of thermal trip in the drill itself or something...I doubt the cells were new to begin with, so couple that with the insufficient current of the adapter and you've got the reason: when the load suddenly increases, the current draw first causes the adapter to shut off and the batteries to drain instantly (provided they held some charge in them to begin with !) and it takes a few seconds for the adapter to restart and allow the drill to at least turn again...
                    It's guys like these who are treated like gods around here sadly....age is just a number I say Louis Rossmann drove this point home a couple of times when he showed some very competent youngsters on his channel. Same here: I don't claim to know sh!t, but COME ON !
                    Wattevah...
                      • 31190
                      looking forward to the smoke & flame.
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        #151
                        Yeaaaah...don't really think that's going to happen that easily, but who knows how much abuse those things can take and what their failure mode is
                        Wattevah...
                        • redwire
                          • Dec 2010
                          • 3912
                          I would plan my escape route, so when the fire starts, grab your tools and RUN AWAY. Or stay away from the charging station.
                          But these idiots are like a cat and have 9-lives.
                            It sounds like the owner of the business does not care either.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              Technically I'm also playing the dice with that HT with unprotected li-ion cells... been "manually" balancing them... eek (can't protect them from overdischarge!)
                              I really should get a bms board for them...
                              (oh btw, this was acquired second hand, though I didn't design it, I suffer the consequences if I accidentally abuse it...)
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                #155
                                No, not at all...as long as the joint runs, that's good enough. He doesn't know half this stuff either - i.e. he's not tech-minded. Just your average-Joe running a business....which somehow happens to be the biggest in town
                                Wattevah...
                                • Dannyx
                                  CertifiedAxhole
                                  • Aug 2016
                                  • 3912
                                  #156
                                  PFFTTT....geez, you have no idea how right you are how often I think the same thing >_>
                                  Wattevah...
                                    • 31190
                                    your co-worker is following the old saying, "if at first you dont succeed, try try again"
                                    (at starting a fire!)
                                    • Dannyx
                                      CertifiedAxhole
                                      • Aug 2016
                                      • 3912
                                      #158
                                      Yes, to his merit, he's persistent and he often pursues some avenues which seem completely ridiculous and sometimes ends up with total success and praise from tech-illiterate people around him who don't know better. Sad, considering "nice" guys like me who try to do everything nice and perfect are shoved to the side...all well....
                                      Wattevah...
                                      • Dannyx
                                        CertifiedAxhole
                                        • Aug 2016
                                        • 3912
                                        #159
                                        Sorry for digging up such an old thread. Hopefully people are still following Today I came across something which comes oddly close to what my dear old dinosaur friend was doing to that vacuum way back in the first post - remember him ? Of course you do
                                        So: someone bought a(n overpriced) flashlight from an online shop, one of those things with overblown specs, which of course came without batteries. It's rechargeable by USB. The small instruction sheet that came with it claim it accepts an 18650 cell OR 3 AAA NiMhs, which I find a bit concerning in the long run...what do you think of this ? A flashlight capable of charging BOTH NiMhs and 18650 with no user interaction ? Not only they're completely different capacities, but also different chemistries, so is this the recipe for disaster and trashing some good cells ? :|
                                        Wattevah...
                                        • eccerr0r
                                          Solder Sloth
                                          • Nov 2012
                                          • 8701
                                          A 18650 with protection you can charge fairly easily. And NiMH cells usually are tolerant with charging (at least they won't burst into flames.) But if you optimize for one, the other won't work to their potential, so choose one.
                                          However if you design it such that it can detect chemistry and choose proper charging algorithm.
                                          Now if you stuck Alkaline AAA's in there, all bets are off...
                                          • AlexVG
                                            Replacing the WiFi module on a vacuum cleaner iROBOT i7
                                            by AlexVG
                                            I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
                                            I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
                                            (This board does not respond, only the LEDs light up in a circle.
                                            The liquid damage is catastrophic and restoration is impractical).
                                            (I bought this board to get the WiFi module and camera).
                                            The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
                                            If...
                                            10-22-2024, 07:20 AM
                                          • Chaks
                                            The ups takes 3 x 18650 cells in Parallel - Can I extend to 6 x 18650 safely?
                                            by Chaks
                                            I need help to extend the runtime of the ups board (see attached image).
                                            This is ups board for a CM4 which has 3 18650 cells in parallel. Can I extend the 3 cells to 6 cells for a longer runtime? by soldering a wire to each of the battery terminal and connecting it to a separate battery case with 6 cells.
                                            Thanks and kind regards,
                                            chaksindia...
                                            01-21-2025, 11:39 AM
                                          • flat-earther
                                            Hoover FM216LI cordless vacuum refuses to charge
                                            by flat-earther
                                            I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                                            I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                                            5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                                            So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                                            06-06-2025, 03:14 AM
                                          • Petr0x
                                            Bosch 12V and 18V chargers modification
                                            by Petr0x
                                            Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
                                            You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
                                            Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
                                            05-24-2024, 01:00 PM
                                            ZD-915 vacuum pump motor mount service alert
                                            If you have this Desoldering Gun Station there is something you should be aware of the two screws that hold the motor to mounting for pump can come loose and make raddling noise
                                            One note this unit has been repaired already once because of switching power supply regulator ic chip failure
                                            Now this with the vacuum motor mounting issue yes I give this Desoldering station a very hard work out and use about every weekend to do some type of project
                                            The fix is taking the vacuum pump assembly out and take the metal cover off and you will see the two screws on it
                                            09-19-2021, 02:15 AM
