Directly replacing NiMh cells with Li-Ion cells - bad idea ?
    • Jul 2011
    • 6062
    Re: Directly replacing NiMh cells with Li-Ion cells - bad idea ?
    This is the type of charge I use for a one cell 18650 battery they work very well But I check to make sure that it cut the voltage at level it suppose to
    https://www.ebay.com/itm/Free-Shippi....c100005.m1851
    I am sorry but I just bought the last two that they had
    But I will still leave here so you can see what type of battery charger I use
    One note I do recap them before I use them
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      The question is why was my vacuum designed with such a slow charge? Does it benefit the battery to have a slow charge after a fast discharge when it's being used. Current setup is like 0.1C charge, 8C discharge...
      I suppose this is not any worse than the original NiCd system that also charges probably at 0.1C.
        • Jul 2011
        • 6062
        No it just that most items that are worth a shit
        come with a very shite charge I find this a lot
        and most of the time the battery or batteries are real shit
        Here is an example of what I am talking about
        https://www.tractorsupply.com/tsc/pr...t&cm_vc=-10005
        This is very good flashlight and good quality batteries but the charging board over current the batteries and causes them to become very warm
        I will not use the charger base because of this and this is with good quality batteries
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Well, the charger does properly cut off when charging at 0.1C ... battery is full and never gets warm during charge.
          Now I never checked temperatures during discharge, now that's a different story...
            • 31185
            https://www.ebay.com/itm/283423505664
            those are what they supply with the lights, but i dont like them so i just kept the cable and binned the psu.
            have a zener diode decide if my lithium is charged - hell no!
            btw, they cost a couple of $ - not 10!!
              • Jul 2011
              • 6062
              Yes I know and I seen them to
                master hoarder
                • May 2008
                • 12175
                #127
                If I had to guess... probably so that they could use a cheap wall-wart adapter for the charger instead of a more beefy SMPS adapter. Make sense from a cost stand-point at least: just tell the user to keep the vac always plugged in and charging so that it's ready when needed. Since most people don't user these kind of vacs too often (like you said, it's only good for the occasional small stuff), chances are they won't have a problem with leaving the vac to charge somewhere at its own slow pace.
                The reason you sometimes see this slow "trickle charge" on Ni-Cd and Ni-MH batteries is because they are generally much harder to charge than Li-ion. By that, I mean the charge process is more complex. A good (proper) Ni-Cd / Ni-MH charger will not only limit the current going to the battery (charge rate), but also look at battery temperature *and* specific battery voltage curves of the battery. Depending on how fast you charge a Ni-CD / Ni-MH battery, the charge voltage will rise and then fall a bit when reaching near full charge. But how much this voltage "fall" will be, tends to vary with the charge rate and temperature. So a good Ni-CD / Ni-MH charger needs to have a not-so-simple micro-controller that can calculate when the battery is actually fully charged based on the parameters above - that is, if you want to optimally charge a Ni-Cd / Ni-MH battery and minimally affect its life.
                But because Ni-CD and Ni-MH chemistry is a lot more forgiving to over-charging and under-charging than Li-ion (at least when it comes to safety), some manufacturers just choose to use a "dumb" charger that charges the cells at a specific charge rate or for a specific amount of time... or a combination of both. And if the cells are aging and not taking the charge too well from this "dumb" charger, they will over/under-charge... which will then decrease their life further as time goes on.
                That said, trickle-charging on Ni-Cd and Ni-MH batteries can be quite safe (to the battery's optimal life) if the charge rate is very, very slow, as the battery will dissipate the extra charge as heat (which there wouldn't be too much of, really.) I don't remember exactly off top of my head any exact values, but I think something like 0.01C, you can keep the batteries on the charger indefinitely and they won't get damaged.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Actually, the wall wart looks like a SMPS with a very high impedance as far as I know. At least the pictures that I've seen, the wall wart is tiny, much like a modern phone charger... That being said I've not had my hands on the real wall wart.
                  The main reason for saying that the 0.1C charging is not any worse than the original NiCd is that it won't take any longer for the Li-ion system to charge, 10 hours (typical of old dumb NiCd chargers) when we typically can charge li-ion in less than 3 hours! :o The smarts in the charging system is all in the "protection" board as far as I can tell, but it sure is not capable of handling high current. At least it does protect the Li-ion from overcharge, as li-ion will go "fuming" mad at 0.01C or even 0.001C overcharge.
                    • 31185
                    how many lithiums are we talking here, 1 or higher?
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      #130
                      I need to brush up on my battery basics - haven't cared about them too much TBH, so what is C ? Coulomb ? Rate of charge ?
                      Wattevah...
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        This is only a 1-cell system so no balancing is required. AFAIK no real reason why one couldn't charge faster than 0.1C...
                        ... other than if there is some penalty involved with doing fast charging and fast discharging... which may be the case, but not sure what the limitations are with the cell.
                        Perhaps the main reason is to slow down usage of the vacuum cleaner, so that the 400 charge-recharge cycles takes a year to wear out the lithium ion cell, instead of just weeks by finishing a charge-discharge cycle every 3 hours...
                          https://batteryuniversity.com/learn/..._is_the_c_rate
                            • 31185
                            if it's a single cell, use those smart usb charge modules i posted an ALI Link for.
                            you can set the charge current with one resistor upto 1Ah and they are $1.60 for 10!!!
                            attaching the DS.
                              https://www.ebay.com/sch/i.html?_fro...P4056&_sacat=0
                              I bought some of these PCBA based on TP4056 but never have time to try them out yet.
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                #135
                                Still on the topic of batteries, my colleague got his hands on two rather beefy SLAs which saw hardly any use, essentially brand new, and he claims their full charge should be around 14v+. As they stand, after being on a charger today, they peaked at 13.9v which to him is not satisfactory...I call that BS, as 13.9v is more than enough voltage to call those cells perfectly fine and healthy.
                                Wattevah...
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  Eh no, the question was not how to charge it faster than 0.1C, but rather why they limited the li-ion charge to 0.1C from the factory -- it would have been a more attractive product if it charged faster... but would wear out the battery in fewer months, perhaps increasing warranty replacements. They probably figured that it was no worse than the old NiCd "overnight" chargers so that's the way they designed the Li-ion, and hope that the battery will last longer than warranty.
                                    https://www.powerstream.com/SLA.htm
                                      • 31185
                                      the answer to the question is in the datasheet,
                                      because it's not safe to fast-charge lithium with just a set current - you need a profile curve.
                                      a controller that lowers the current as the voltage aproaches the max so you dont go over it and damage/heat the cell.
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8701
                                        Wow...
                                        Backing up a bit, as far as I can tell the system that was sold as is for the vacuum is this:
                                        Say we have the 15V wall wart, CV. Has 100 ohm resistor in series or is its ESR to limit it to 150mA. Straight wired to charge controller, that apparently cuts off charging once it gets to ~ 4.2V. The charge controller has only SOT23s on it, and has no inductors - so it could not possibly charge at high rate. The battery, 1.5Ah, is straight wired to the switch/motor. This is a slow two-state charger system, and won't go past 4.2V (actually I think less) because it cuts off charge there and doesn't try to charge if it's even close to 4.2V. So the battery should be protected against overcharge.
                                        The question was always: why did they build it this way, why didn't they put in a CC/CV 2-stage at least, if not a full 3 state charger so that the battery could be charged much faster. The current system, due to limit of 150mA, requires at least 10 hours to fully charge, though more like 8 hours perhaps - read on.
                                        Again my take is that this was done to extend battery life as well as being cheap. The sarcastic reason is detailed above due to limiting the lifetime number of discharge/charge cycles because the charge cycle takes 40x the discharge cycle. However the other aspect I just thought, since it does not do the CV absorption charge, it never fully charges - and hence only gets to 85% charge or so. Because of this, the battery is less stressed, and can sustain more charge/discharge cycles than if left fully charged. The manufacturer thought this was "okay" to take overnight to overcharge just because "it's always been done this way" since NiCd was typical like this.
                                        More design tradeoffs?
                                          • Jul 2011
                                          • 6062
                                          Wow... :confused
                                          I have a feeling that the type of battery that used is the same type that they use outdoor solar power lights
                                          Because the charging curve is a lot less than the normal ( meaning that you can not charge them with the same current maybe the same voltage ) Li-ion cells and if try to charge them this way they become very warm very fast
                                          I bought some one time and change them on a Li-ion charger never again ( set at 2 amps )
                                          ( set at 200 milliamperes maybe )
                                          The cost for 4 of this type of battery is about $10.00
                                          For a good quality Li-ion cell is about $7.00
                                          So $2.50 versus $ $7.00 this your trade off you were asking about
                                          • AlexVG
                                            Replacing the WiFi module on a vacuum cleaner iROBOT i7
                                            by AlexVG
                                            I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
                                            I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
                                            (This board does not respond, only the LEDs light up in a circle.
                                            The liquid damage is catastrophic and restoration is impractical).
                                            (I bought this board to get the WiFi module and camera).
                                            The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
                                            If...
                                            10-22-2024, 07:20 AM
                                          • Chaks
                                            The ups takes 3 x 18650 cells in Parallel - Can I extend to 6 x 18650 safely?
                                            by Chaks
                                            I need help to extend the runtime of the ups board (see attached image).
                                            This is ups board for a CM4 which has 3 18650 cells in parallel. Can I extend the 3 cells to 6 cells for a longer runtime? by soldering a wire to each of the battery terminal and connecting it to a separate battery case with 6 cells.
                                            Thanks and kind regards,
                                            chaksindia...
                                            01-21-2025, 11:39 AM
                                          • flat-earther
                                            Hoover FM216LI cordless vacuum refuses to charge
                                            by flat-earther
                                            I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                                            I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                                            5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                                            So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                                            06-06-2025, 03:14 AM
                                          • Petr0x
                                            Bosch 12V and 18V chargers modification
                                            by Petr0x
                                            Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
                                            You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
                                            Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
                                            05-24-2024, 01:00 PM
                                            ZD-915 vacuum pump motor mount service alert
                                            If you have this Desoldering Gun Station there is something you should be aware of the two screws that hold the motor to mounting for pump can come loose and make raddling noise
                                            One note this unit has been repaired already once because of switching power supply regulator ic chip failure
                                            Now this with the vacuum motor mounting issue yes I give this Desoldering station a very hard work out and use about every weekend to do some type of project
                                            The fix is taking the vacuum pump assembly out and take the metal cover off and you will see the two screws on it
                                            09-19-2021, 02:15 AM
