help with a APC ups mod
  • yonu
    • Nov 2007
    • 138
    OK all u have a APC back-ups 350 es with a blown inverter. What I would like to do is repurposed the circuit by removing the 110v inverter and using it as a 12v monitor/ trikle charger for another project. I wanted to see what anyone more knowledgeable with PSUs and UPSs thought of this idea.
    Thanks,
    Yonu
  • Kiriakos GR
    Banned
    • May 2012
    • 940
    • Greece
    Re: help with a APC ups mod
    Its like seeking for trouble.
    All the job regarding charging is made automatically by it electronic controller (main chip).
    What makes you think that this one survived from been blown too ?
    • yonu
      • Nov 2007
      • 138
      Well I don't know I do know that according to my voltmeter the battery connections still put out 12v and if I hook abattery to it windows sees the battery so I figured if nothing else I could reuse the monitoring part.
      Thanks,
      Yonu
      • Kiriakos GR
        Banned
        • May 2012
        • 940
        • Greece
        I do not wish to discourage you, but is far complex to modify it than repairing the blown inverter.
        • yonu
          • Nov 2007
          • 138
          OK thanks
            So you can hook up the computer to it and you can use APC software to see the AC line voltage and the Batteries info? I sounds like the MOFETs or the drive circuits are damage but not the monitoring circuit are not damage, those circuit is working when the UPS is not in batteries mode any way (inverter section is not need to be running). You have to connected the batteries to it and check the charging current, the low end UPS does not really have complex charging system where it goes through many charging stages.
            • yonu
              • Nov 2007
              • 138
              Ok please be nice as this is more than likely going to seem very stupid. I have a Idea of how/what I want to do this just not familiar enough with the internals of a ups to sort out what I need to remove or disconnect.
              ok I have tested every part of the back-ups 350 es I have setting here and the only thing I can tell is dead is the inverter. now I have no reason for repair/replace the inverter as I don't need it.
              What I would like to do is make a new casing and put the unit inline with my 12v battery backup system I have on my low voltage equipment the total load is 3A at 12VDC as I am tired of having to check the batteries. Now I could simply splice in the battery connectors so that it can read the battery voltage and send it to the computer via USB. However my goal is to have it setup so that the load is setup so that the UPS can stay plugged in to 110v for lack of any other way to put it but to act as a giant wall wart unless the power is out then switch to the batteries basically like it works for 110v currently.
              Oh and since I know this will be asked part of reason for this is so that I can pass the battery levels over to my Home automation system.
              Like I said I more than likely sound like a nut job,
              yonu
                OK, I see, you want 12VDC UPS (instead of 120VAC UPS) with batteries charger, and monitoring capability through USB interface. I do not believe the charger circuit can put out 3A + Plus charging the batteries at the same time, more likely to have 1A at most.
                The model is 350, not something like XX-350?
                How is the "12v battery backup system" working right now, just run of the batteries with or without charger?
                • yonu
                  • Nov 2007
                  • 138
                  I don't have it in front of me right now but I think the model number is BK350R the current setup is 2 deep cycles I charge every couple weeks. I started doing this because 2 of the wall warts caused to much RF in my HAM radios and after 2yrs it has been working fine.
                  Thanks,
                  yonu
                    This one? It is quite new.
                    https://www.apc.com/products/resourc...base_sku=BK350
                    • yonu
                      • Nov 2007
                      • 138
                      Sorry it is a BE350R I went out and checked
                      not sure why I thought BK
                      Thanks,
                      Yonu
                        OK, one of those plastic case one.
                        • yonu
                          • Nov 2007
                          • 138
                          You got it.
                          • yonu
                            • Nov 2007
                            • 138
                            Out of curiosity is the 40amp fuse in the charging circuit or the inverter circuit just cant figure out why they used such a large fuse.
                            Thanks,
                            yonu
                            • Kiriakos GR
                              Banned
                              • May 2012
                              • 940
                              • Greece
                              Are you talking about some colored ones ( car Fuse type) ?
                              • yonu
                                • Nov 2007
                                • 138
                                Heap a 40A ATC automotive fuse
                                  Can upload the pictures of the inside of the unit? That fuse is in series with the batteries, to produce 230W (350VA) output from 12V, you need more than 20A (~30A) of current from batteries.
                                  • yonu
                                    • Nov 2007
                                    • 138
                                    sure pics will be right up and wasn't sure was just curious about the fuse
                                    • yonu
                                      • Nov 2007
                                      • 138
                                      Ok here are the pics of the PCB
                                        Please look at that TO-220 device to get the P/N, I expect it to be xx317 printed on it.
                                        • x_orange90_x
                                          by x_orange90_x
                                          01-29-2025, 09:24 PM
                                        • Gentian
                                          APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                          by Gentian
                                          I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                          It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                          03-06-2023, 07:07 AM
                                        • valvashon
                                          Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                          by valvashon
                                          For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                          History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                          01-04-2024, 01:44 PM
                                        • eccerr0r
                                          A modified sine wave inverter + a grid tie inverter?
                                          by eccerr0r
                                          If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                          Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                          08-31-2023, 09:14 PM
                                        • caseyjay_48
                                          Sony KDL-46BX450 Inverter Troubleshoot Logic
                                          by caseyjay_48
                                          I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                                          I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                                          09-23-2022, 08:08 PM
