Why do AAA batteries leak so often?
  • lti
    • May 2011
    • 2548
    I have seen more AAA batteries leak than any other size of battery. Today, I saw a new, unused Duracell AAA battery leaking inside the factory packaging. What makes them so likely to leak? It seems like the larger cells do not leak as often.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Why do AAA batteries leak so often?
    They could be fakes. I've never seen a Duracell leak yet, but then again, i tend to use NiMH rechargeables on everything.
    A working TV? How boring!
    • Rulycat
      • Apr 2010
      • 724
      • United Kingdom
      I've only seen really old stock leak. I find the cheap batteries you get with your TV for the remote never seem to leak. Ever. No matter who makes them.
        My dad bought some "2800" mAh cells from eBay, against my advisory instead to buy some good brand 2000 mAh such as eneloops. Anyway, he used them in his emergency torch, but after about a month one of them sort of exploded, it expanded and leaked... something. Half the LEDs on one side of the torch don't light up any more (melted plastic) and the board is bent upwards. These were AA too. I wonder how much capacity these cells actually have? I'm guessing around 1000-1500mAh. If China have figured out 2800mAh cells already, and the biggest you can get retail from say Duracell is 2650mAh, I'm shocked!
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          Well, the only brand battery I've ever consistnently seen leek are rayocraps. Other than those, only antes Duracell, fujifilm, energizer, etc.
          I think the AAAs are just made cheaper so they leak more often.
          • popeye
            • May 2011
            • 155
            You need to by better quality batteries and when they have expired remove then no more leaks simples
            • lti
              • May 2011
              • 2548
              I don't think they're fake. They were purchased from the local grocery store, just like all of the other batteries I have used. I have seen a lot of Duracell AAA batteries leak with little use. This one had never been used and had a use-by date of 2017. I have some old C and D batteries that are nearly a decade past the use-by date and have not leaked.
              • ncovert
                • Feb 2011
                • 291
                Dunno. I guess since they have a lower current capacity, they just conk out easier
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Maybe it is because the can is smaller, and the seal sometimes isn't quite right.
                  To tell the truth, I don't use Duracells anymore because of them leaking or exploding on me
                  Especially the Duracell 9v batteries, they bulge out at the end and after a few weeks they explode, even with light use, or just sitting there not being used.
                  -Ben
                  Muh-soggy-knee
                  • b700029
                    Banned
                    • Sep 2010
                    • 640
                    The smaller can has a lot to do with it. There is less volume for pressure to build before something gives.
                    Originally posted by http://en.wikipedia.org/wiki/Alkaline_Battery
                    The reason for leaks is that as batteries discharge — either through usage or gradual self-discharge — the chemistry of the cells changes and some hydrogen gas is generated. This out-gassing results in increasing pressure within the battery. Eventually, the excess pressure either ruptures the insulating seals at the end of the battery, or the outer metal canister, or both.
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      -Ben
                      That's because Duracell 9V batteries are in reality 6 AAAAs in a can. like AAAs but smaller and thus even more likely to leak. (good to know if you need AAAAs but are cheap).
                      The same is true for 6v latern batteries... although what kind and quantity varies by brand. some have C cells, some have AAs...
                      sigpic
                      (Insert witty quote here)
                      • c_hegge
                        • Sep 2009
                        • 5219
                        I've seen one AA battery leak before. It was some really old no-name brand IIRC. I've never seen a duracel leak, or any other AAA, although I mostly use Energizer Lithium batteries. Lithiums are great because they last for ages and make excellent fireworks when they do eventually die.
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          never seen lantern batts with other than 4 f cells or in some cases 4 d cells.
                          lots of crap fake video of various batteries full of aa.
                          eveready used to make a fancy lantern battery in a plastic case that was easy to open.
                          i repacked some with nimh f cells and reused a charger station that came from odd lots.saved a lot with those.
                          as for aaa leaking i suspect that in the race for best capacity things like wall thickness of the can and the seal crimp took a back seat .
                          thick can=less active material.tall crimp area=wasted volume.
                          this is one way to spot the fake bullshit nimh aa cells.these are made on old low tech equipment and the crimp is huge!.
                          compare to your eneloops and take note.
                          • Rulycat
                            • Apr 2010
                            • 724
                            • United Kingdom
                            Just had a thought. I've not really seen the failures of Duracells you in the U.S have, and E.U Duracells are made in Belgium whereas yours are made in the U.S.A I think. Some problem at the factory perhaps?
                            Energizers are still made in the U.S.A here though.
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              +1
                              Well, I've never had one of these explode on me, but the 9V Duracell definitely bulge a lot more than others near their end of life. Energizer 9V batteries on the other hand, do not bulge as much (if at all), but they often corrode their terminals near end of life. Basically I have a box full of batteries that needs to be thrown away and those were my observations from it.
                              As far as AAA batteries go - yes, those do indeed leak more often than AA and other larger batteries.
                              • RJARRRPCGP
                                • Jul 2004
                                • 6304
                                The Eveready ones that weigh super light with cat logo, sux!
                                On a CD player, they die like ni-cads on an RC car!
                                ASRock B550 PG Velocita
                                Ryzen 9 "Vermeer" 5900X
                                Arc A770 16 GB
                                eVGA Supernova G3 750W
                                Alienware AW3423DWF OLED
                                • lti
                                  • May 2011
                                  • 2548
                                  I have seen some 9V Duracell batteries that bulged so much that they were difficult to remove. They were almost 1/4" longer than a new battery.
                                  Maybe I should switch to another brand of AAA batteries. These Duracells leak too often. The one that leaked inside the packaging must have been defective, but I have seen many Duracell (Durasmell?) AAAs leak after almost no use. I don't want the batteries in my calculator to leak.
                                  The picture below shows the batteries I put in the CMoy amp I built about a year and a half ago. I used it for a few minutes, decided that it didn't sound very good, and put it in my junk drawer. Today, two of the batteries are leaking. They were old, but they had been unused until I tried to power the amp with them.
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 4963
                                    • New Zealand
                                    In my experience, they will all leak eventually when given enough time (years) - The cheaper ones just leak faster.
                                    Never leave batteries of any kind in anything if you're not using it regularly enough to notice when they go flat.
                                    -David VanHorn
                                    • Shocker
                                      Banned
                                      • Dec 2011
                                      • 635
                                      Is the problem that they need to put vents on batteries??? Like on caps???
                                      • stevo1210
                                        • Oct 2006
                                        • 4156
                                        That's actually a reason why I buy energizers. I've had Duracells leak as well. A close friend of mine runs a business and got scammed with fake duracells at one point which leaked in the packaging on the shelves, I personally could not tell a difference between the fake and real ones.
                                        Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
                                        • carrzkiss
                                          Cyberpower cps1500avr not charging batteries
                                          by carrzkiss
                                          Hello, all.
                                          Cyberpower Battery Backup Unit.
                                          I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                                          When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                                          In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                                          Checking the voltage, it was down to 22v.
                                          I quickly removed everything...
                                          06-15-2024, 02:10 PM
                                        • howardc64
                                          Where do repair shops buy MB replacement batteries?
                                          by howardc64
                                          Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
                                          Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
                                          BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
                                          07-25-2024, 10:42 AM
                                        • Astonished
                                          Fixing the Charge Circuit of the Batteries of the DC Motor
                                          by Astonished
                                          Hi friends of electronics
                                          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                          Please help me fix this circuit.
                                          (the datasheet of the IC: https://pdf.datasheet.live/28...
                                          01-28-2025, 06:24 AM
                                        • dbuergi
                                          DIY: Modified smart charger for all types of batteries
                                          by dbuergi
                                          sometimes i'm in need of a charger / tester for very small batteries and even if my multimeter doesn't show anything there is a chance that a smart charger helps to revieve. I'm happy with my Keenstone smartcharger and i made a small mod just to use it with smaller batteries like in smartwatches or even camera batteries with special contacts.
                                          Soldering wires on the charger contacts and using needles as probes. I covered both with a shrink hose with integrated solder.
                                          My first work was to bring my Samsung watch battery back to life with was not recognized...
                                          07-18-2025, 03:17 AM
                                        • davidebaldini
                                          UPS ruins batteries every three months
                                          by davidebaldini
                                          Problem description:
                                          My UPS requires new batteries every ~3 months; in this time frame, an average of about 5 to 10 power flickers or short power interruptions (< 2 minutes) occur. After an average of 3 months, a new pair of batteries begins to fail to keep the UPS up during any flicker or power interruption. The load it powers is a single computer/workstation running 24/7 with a continuous consumption between 200W to 300W.
                                          UPS model:
                                          The Atlantis 1001 is a non-inexpensive (~120€ back then) home/office offline UPS, rated 1000VA, 600W, designed for two 7Ah...
                                          10-02-2019, 06:19 AM
