Urgent Ebay Listing Question about ESR METER?
  • ComputerGeek
    • Oct 2011
    • 262
    Hey, guy's I found this on eBay and was wondering if it is any Good? The listing ends soon.
    http://www.ebay.com/itm/Creative-Ele...#ht_500wt_1361
    Do I also need a Meter to test Caps? My Meters are here https://www.badcaps.net/forum/showpo...8&postcount=38
    I assume this does not do Esr?
    http://www.ebay.com/itm/Digital-capa...#ht_500wt_1361
    I also was looking at these,
    http://www.ebay.com/itm/NIPPON-AMERI...ht_4408wt_1000
    http://www.ebay.com/itm/circuit-Capa...ht_1340wt_1486
    Can this really do in-cuircut testing?
    Any Help, And recommendations would be great!
    ---Edit Also What about these?
    http://www.ebay.com/itm/ESR-Meter-El...ht_2110wt_1344
    http://www.ebay.com/itm/New-ESR-and-...#ht_515wt_1344
    http://www.ebay.com/itm/Esr-Meter-Te...ht_2152wt_1344
    THanks!
  • Toasty
    • Jul 2007
    • 4171
    Re: Urgent Ebay Listing Question about ESR METER?
    No analog meter can read low enough to accurately determine a bad, low ESR cap. You can "guesstimate" with them, but you can not distinguish a reading of 0.030Ω from a 0.010Ω.
    I use and recommend the Bob Parker Blue ESR meter from AnaTek.
    http://www.anatekcorp.com/esr.htm
    Buy the kit form, save $30, and learn something about it.
    AnaTek also offers the Atlas ESR Plus and there are a few other Digital ones out there that I've heard forum members speak of, but I have no opinion on those.
    Toast
    veritas odium parit
    • smason
      • 1652
      Agreed. An analog ESR meter can find the odd bad cap with high ESR, but isn't accurate enough to really test low ESR caps.
      I'd go with the Parker, or the Russian Mike ESR Micro unit, both get great reviews.
      • multimeter
        • Jan 2011
        • 739
        • united kingdom
        i dont like analogue esr meters they tend to be a bit vague,for accurate results go with the digital esr meter,the one i use is a little gem its an peak atlas esr70,it will identify all litics at a bat of an eyelid,and with spot on results
        fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
        please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          What they said...
          Mann-Made Global Warming.
          - Dr Seuss
          • Agent24
            I see dead caps
            • Oct 2007
            • 5037
            • New Zealand
            I also built and use a Bob Parker Blue ESR meter and really like it.
            If you could get an analogue ESR meter like that for $5 or something it might be worth it, but not for that auction price.
            -David VanHorn
            • bigbeark
              • Jan 2010
              • 661
              I use the last one you listed, from the Hungarian guy.
              It uses an easy-to-find 9V battery and has worked well for me. I have had it for a couple of years now. The Blue Meter may be more accurate but it's also about $40 more. In addition it comes with alligator clips. I believe you will want the test probes which are another $10 or so.
              Bear in mind that the ESR meter enables you to find bad caps in circuit.
              Most of the caps that go bad will be in the VRM circuit and these may be harder to spot because they are wired in parallel and the bad cap may be
              hidden by the good caps in the circuit.
              That said, caps that have really high ESR are frequently bulged or domed.
              Careful visual inspection is helpful.
              What surprises me is how many caps that look OK and measure OK in circuit turn out to have drastically degraded capacitance when tested with
              a capacitance meter when removed from the board.
              I always test new caps before installation, with both the ESR and capacitance meters. This is where you catch the fake caps. Typically their capacitance is all over the map or way too low. Generally their ESR is also too high for their intended use.
              • Peter9DO
                • Dec 2011
                • 277
                I have a Peak Atlas ESR+ (ESR70) that I just bought and am very happy I decided to spend the extra money on this tester! I was looking at just about every option you have there, checking out web site after web site, asking people their views on every model and the one that kept coming to the top was the Peak Atlas ESR70. I would consider spending the extra $50 if you can, you will be very pleased, without a doubt!
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Finding bad caps in-circuit is mostly advertising hype.
                  It works -sometimes- and less often than not.
                  Especially true on motherboards.
                  - Dr Seuss
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    especially in the VRM, where the caps are in parallel... you always test out of circuit.
                    sigpic
                    (Insert witty quote here)
                      This is so true. I was debugging an LG plasma TV power supply. About 9 of the caps had bulged and were causing problems for it. So I checked them and they measured okay ESR (<0.01 ohms for 5x in parallel.) When removed from the circuit, almost all of them measured 1 ohm ESR each.
                      • Bob Parker
                        Technician
                        • Feb 2007
                        • 182
                        100% agree. The Dick Smith/Blue meter was designed back in 1995 for fault-finding CRT TVs etc where it's unusual to find paralleled electrolytic caps. In that kind of circuitry you almost never see anything with a very low high-frequency impedance shunting electrolytic caps so you can usually test in circuit.
                        Motherboards and anything else with paralleled caps are a totally different story. You have no choice but to disconnect one lead of each cap and test it individually. And only then after it's cooled down from being desoldered because the heat makes the ESR drop and the cap appear to be better than it is.
                        It is a good shrubbery. I like the laurels particularly...
                        • popeye
                          • May 2011
                          • 155
                          Peak are very good most engineers I know use them analog meters are not up to the job
                          • QuantumCheese
                            • Jan 2012
                            • 35
                            I've often wondered if i should get one of these, the little research i had done was leading me down the Peak route.
                            Saying that, i have quite a good fluke which is also good at in-circuit capacitance measurements, and if not whip em out & test. I've replaced a lot of caps in my time, mostly bulging but some not and they all had degraded or out-of-spec capacitance when measured. So do i really need a ESR meter i keep saying to myself??
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Capacitance is often fine even when the ESR is bad.
                              I personally don't do much that isn't Low ESR applications.
                              In that range ESR seems to go bad first.
                              Lacking an ESR meter I would miss a LOT of bad caps.
                              But, if you only do say a half dozen projects a year (or less) then just replacing all the 'usual suspects' by default might be a better plan.
                              It's usually best to do that anyway in mobos, SMPS and LCD screens.
                              If you're going to replace the cRaps regardless then checking ESR only serves as a confirmation.
                              It's also nice to catch new ones that are duds but that isn't very common.
                              - Dr Seuss
                              • ComputerGeek
                                • Oct 2011
                                • 262
                                Thanks for clearing all of this up guy's I am going to get a peak of something similar after I get a sale. Thanks!
                                • kc8adu
                                  • Nov 2003
                                  • 8832
                                  • U.S.A!
                                  another thing that will trip up ANY esr meter is caps in paralell with mlcc.
                                  the 10@16 sm lytic can be open but the mlcc gives a good reading.
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 5037
                                    • New Zealand
                                    And that would be 'Multi-Layer Ceramic Capacitor' ?
                                    -David VanHorn
                                    • chth96
                                      Is it possible to test small ceramic disc capacitor with analogue meter?
                                      by chth96
                                      I read EBOOK of Testing Electronic Component and found that
                                      "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                      Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                      It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                      Is it really possible to test small ceramic disc capacitor with analogue...
                                      03-09-2024, 10:03 PM
                                      Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                      by sam_sam_sam
                                      I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                      I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                      12-31-2023, 06:04 AM
                                    • jorpec
                                      Changing the scale of an analog meter
                                      by jorpec
                                      Hi
                                      I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                      I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                      Thnaks
                                      01-23-2023, 10:37 AM
                                      How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                      by sam_sam_sam
                                      About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                      Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                      Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                                      12-14-2023, 07:45 PM
                                    • Stephan Mathers
                                      EDMI ATLAS MK10 Electronic Meter Discussion
                                      by Stephan Mathers
                                      Greetings, new guy here but always interested in the crazy universe of modding
                                      We just finished construction of around 25 vacation houses, all inside the same private area.
                                      Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
                                      The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
                                      Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
                                      05-20-2025, 09:09 AM
