Bob Parker ESR Meters
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    #81
    Re: Bob Parker ESR Meters
    Assembled my MK2 ESR meter now, it's working fine, right at the first try also
    Included some pics of it almost complete...
    The test probes as was already said above do not work too well though, gonna buy a new pair at Elfa, need a pair for my multimeter anyway because they have also given up :/
    Will also buy 2x 1N5404 diodes to put on the testleads to protect the meter from charged caps... Anything else I could add to make it even more safe?
    And thanks Bob.P for joining the forum and designing the ESR meter for us crazy fools
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      #82
      Just a thought to my post above, what if I also put 5w resistors after the diodes; should not that make the capacitor dissipate it's charge slowly and nicley while at the same time protecting the ESR meter?
      Because the diode only approach sounds a bit dangerous if I connect it to a really big charged cap, I think bad stuff will happen
      • Bob Parker
        Technician
        • Feb 2007
        • 182
        Hi Per,
        You've built it very well. Congratulations that now you've got a Mk2 ESR meter!
        In fact the crazy fool I designed the ESR for was ME. I thought it was so useful that I'd make the design public. Of course I'm very happy that lots of other crazy fools (and some sensible people!) are using it too.
        So far I have not heard of anyone damaging an ESR meter after installing the big protection diodes. But if you connect it to a big charged high voltage capacitor, it will burn the tips off your new probes.
        It is a good shrubbery. I like the laurels particularly...
        • Bob Parker
          Technician
          • Feb 2007
          • 182
          The meter can only zero out test lead resistance of 0.99 ohms or less. This is a function of the design. You can't put resistors in series with the test leads. If you are really worried about connecting it to charged high voltage capacitors, you could put an inline fast-acting fuse in one of the test leads. The combined resistance of the fuse and test leads will need to be less than 0.99 ohms, so the choice of fuse will be more determined by that limitation than its current rating.
          When I designed the meter, I never imagined that so many people would connect it to big charged high voltage capacitors, so I didn't allow for this to happen and only gave it protection up to about 50V.
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            #85
            Thanks for the info Bob P, saw on your site the link to the Anatek DSESRSavr
            http://www.anatekcorp.com/testequipment/dsesrsavr.htm
            How does that thing work? To me it looked like just two big diodes and two resisitors plus the other two gigantic things I don't know what they are (capacitors?)
            So I thought I could build something similar myself...
            • Bob Parker
              Technician
              • Feb 2007
              • 182
              It's a patented device. I've tried it and it protects the meter very well. However it slightly reduces the accuracy and increases the test lead resistance, and takes up space in the case. I'm not sure if it will fit in the Mk2 meter case. I'd suggest that you contact Anatek and buy one if it will fit; they don't cost very much.
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16955
                Do I get one for free???
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                • Bob Parker
                  Technician
                  • Feb 2007
                  • 182
                  A protector or an ESR meter? Unfortunately I don't have any of either of those things.
                  PS: I'm not a guru - just a technician who needed my own ESR meter so bad that I had to design one.
                  • starfury1
                    • May 2006
                    • 1256
                    #89
                    Hi all
                    I thought I should mention this
                    (I don't think it has been mentioned)
                    If you use the meter near a monitor or TV that is going it will probably give spurious readings
                    So please make sure you are not near one when using it.
                    Not sure how bad with a TFT but probably ditto for them too
                    To get an idea,
                    try it for your selfs and at a few feet distance too.
                    It is mentioned in the notes somewhere or was it on Bobs site probably both.
                    This is something to beware of and its something you can easily forget too,
                    as we tend to have a computer or 2 close to our work bench.
                    The other thing is you might want to
                    get into the habit of discharging Higher voltage caps as a matter of course for your own safety
                    as much as for the meters.
                    When you get bitten by a cap sitting at 350 Volts DC you will know what I mean
                    Cheers
                    You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      #90
                      Look what I found in the mail
                      I also got the testleads, they where not kiddin though, with testleads it's really only the leads, no cables!
                      Meh, guess I'm keeping the postal office busy atleast
                      Ordered some nice gold plated cables, also managed to order only one diode when I was fully aware I needed two!
                      Meh, see my blog post to see what all the whine is about today
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        #91
                        There, got cables now too
                        Just to make sure, is this the way the safety diodes are supposed to be installed? (the two vertical things being the wires going to the test lead sockets)
                        • Bob Parker
                          Technician
                          • Feb 2007
                          • 182
                          Yes, that is correct.
                          • tazwegion
                            • Jun 2006
                            • 444
                            The values placed on the MKII silk screening were a little confusing @ first for a novice such as myself... I mean 100R??? equates to what exactly? thankfully the included guide contained a helpful schematic (see inset)
                            Sadly... this is as far as I've got with the kit as my (former) faithful 25w iron has fizzled out, dunno' about everyone else... but I figured the 'other' 40w iron I have may be a little too 'heavy duty' for such a delicate undertaking
                            Viva LA Retro!
                            • Bob Parker
                              Technician
                              • Feb 2007
                              • 182
                              Please don't try to use a non-temperature-controlled 40W iron to build the meter. It's sure to burn component pads off the board and do other damage. When I designed it, I thought only experienced repair technicians with soldering stations would be building (and using) it. [Whimper].
                              • tazwegion
                                • Jun 2006
                                • 444
                                I really had no intention of using the 40w iron, as I said it's too heavy duty for this delicate application, I generally only use the 40w on automotive jobs
                                Having the 25w burn out like it did is kinda' a blessing in disguise, as now I'll be able to purchase something significantly better, I mean when you consider it came with a DSE kit package I purchased more than 10 years ago... it's been productive
                                Thankfully the symbol on the silk screening combined with the photos & schematic provided in the guide booklet steered me in the right direction... BTW have no fear I'm not out to butcher your kit, it's only useful to me functional
                                Viva LA Retro!
                                • gdement
                                  • Jan 2007
                                  • 690
                                  #96
                                  Yeah, using a 40w iron is kind of rough. That was what I used, and I burned a few pads along the way. You have to move pretty fast for it to work, a little too fast for me to handle it sometimes. If the iron is there more than a couple seconds it'll fry.
                                  • Bob Parker
                                    Technician
                                    • Feb 2007
                                    • 182
                                    Whew... thanks for that. I've been supporting that kit since early 1996 and I've seen some real disasters caused by huge overheated soldering irons. I was hoping this wouldn't become the latest one.
                                    • tazwegion
                                      • Jun 2006
                                      • 444
                                      No worries, I've actually been weighing up my choices between a basic 25w Scope, a DSE (entry level) soldering station & a 13w 'Goot' pencil iron
                                      Viva LA Retro!
                                      • Bob Parker
                                        Technician
                                        • Feb 2007
                                        • 182
                                        I've briefly used one of the basic DSE soldering stations (with a little meter showing the temperature) and I thought it was pretty good.
                                        It's always hazardous soldering PCBs with an uncontrolled iron because they tend to get awfully hot and de-laminate the copper foil. But a temperature controlled one operating at around 350C generally does the job very nicely.
                                        • tazwegion
                                          • Jun 2006
                                          • 444
                                          Unfortunately, I missed the sale on that particular version T2200 (meter), but I did land it's little brother T1976 (minus meter), BTW thanks for the pointer(s) always appreciated
                                          The 17w ~ 25w hobbist irons are quite nice IMHO, but their tips don't make fine/detailed soldering easy by any means... but I digress
                                          Viva LA Retro!
                                          • chth96
                                            Is it possible to test small ceramic disc capacitor with analogue meter?
                                            by chth96
                                            I read EBOOK of Testing Electronic Component and found that
                                            "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                            Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                            It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                            Is it really possible to test small ceramic disc capacitor with analogue...
                                            03-09-2024, 10:03 PM
                                          • flibidy
                                            Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                            by flibidy
                                            I have here a Magnum IA.100 which belongs to my parents.
                                            The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                            Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                            What Ive done........
                                            01-01-2025, 01:26 PM
                                          • eccerr0r
                                            lowest current galvanometer/analog meter (passively powered!)
                                            by eccerr0r
                                            Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
                                            On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
                                            04-16-2025, 12:41 AM
                                          • chth96
                                            How Can I test PWM DM0365R?
                                            by chth96
                                            Hello
                                            I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                                            So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                                            I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                                            I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                                            06-18-2025, 04:14 PM
                                          • khelane
                                            test active pfc power with lamp test
                                            by khelane
                                            Hello
                                            I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                                            Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                                            Is there a way...
                                            06-03-2025, 01:00 AM
