test active pfc power with lamp test
  • khelane
    • Apr 2015
    • 172
    • xxxx
    Hello
    I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
    Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
    Is there a way to safely test these active pfc power supplies?
    Thank you​
    • 31310
    use a bigger lamp, i use a 400W halogen floodlamp
    another guy on the forum uses a water heater or a toaster or something like that!!
    • khelane
      • Apr 2015
      • 172
      • xxxx
      tnx
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8352
        Or multiple incandescent lamps to increase wattage.
        • khelane
          • Apr 2015
          • 172
          • xxxx
          Thank you for your advice.
          The main problem is that when I turn on the device with the test lamp, the lamp quickly turns off and on, and I don't know if there is a connection in the circuit or not. When the hot part has a connection, the lamp turns on completely, but after testing and troubleshooting, I want to start the device with the test lamp, it turns off and on quickly, and I'm afraid that if I turn on the test lamp, it will explode. A few days ago, I repaired a device. The lamp blinked or turned on and off during startup and startup. When I started it with the main power, the varistor exploded.
          In normal power supplies, the test lamp has no problem with starting the power and turning on, but in active pfc power supplies, when I turn it on with the test lamp, if there is a connection in the hot part, the lamp turns on completely as before, but when there is no connection or maybe a component has a leak, after turning on and testing the output voltages, the test lamp quickly turns off and on. Is this turning on and off my problem?​
          • harp
            • Jun 2022
            • 650
            • Planet Earth
            First use a 100w test lamp, to see if there is short. If you see the simptoms of apfc (clearly blinking lamp), use a regular toaster (700w), and confirm stable outputs, input voltages, etc... sucessful repair. When is all ok, power on directly from mains with armor and finger crosed... Electronic can explode at any time, so dont be worry about that.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8352
              Also you shouldn’t test an active PFC PSU with the test lamp all the time. The test lamp is to limit the current. Problem with that is it makes the PFC work harder then it drops out, starts again… hence the blinking. What kind of wattage on the incandescent light bulb are you using?
                master hoarder
                • May 2008
                • 12176
                Presume you were talking about me.
                Yes, I actually use both - 450W dishwasher heating element for "lighter" loads and a 700W/1400W mini toaster oven, with the 700W setting being my "medium power" level, and 1400W for when I actually want to test with a fairly "large" load on the PSU (100-120 Watts or less, and I'll explain why.) The idea is to keep the load at less 10% of the heating element's rating so that the voltage going to the PSU doesn't fall too much (below 100V), as otherwise APFC PSUs will turn off below that... so for a 1 kW or more heating element, 100-120 Watts is about the max you can do.
                I DO like your idea of using high-power halogen lamps, though - they have a very low cold resistance and as such are less likely to cause issues with APFC circuits (I think!)
                Also you shouldn't test an active PFC PSU with the test lamp all the time. The test lamp is to limit the current. Problem with that is it makes the PFC work harder then it drops out, starts again… hence the blinking.
                Indeed.
                Though for those of us living in countries with 220/230/240V AC, we can have the AC voltage drop a lot more from the series light bulb or heating element before the PSU refuses to turn on.
                On that note, it would help if some of new member here actually bother to put their country in their profile name, so that way we can know what AC voltage they have available. (Seriously, no one will be that desperate to come and find you if you post what country you live in. )
                • khelane
                  • Apr 2015
                  • 172
                  • xxxx
                  Do you mean after starting with a 100-watt bulb, if the bulb starts to flicker, should I turn it off and instead of a 100-watt bulb, should I use a 700-watt toaster or a 400-watt halogen? And then turn on the power supply? And test the voltage of the power supply? In the end, I am in a place where it is very difficult for me to find a part. I want to minimize the damage.
                  • petehall347
                    • Jan 2015
                    • 4451
                    if it makes toast then its time to stop and eat whilst wondering what to do next .
                    • bauto601
                      KDM 480W PSU upgrade succes! (opinions?)
                      by bauto601
                      Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                      A "nice" YoungYear unit? - Badcaps
                      The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                      12-26-2023, 03:05 PM
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • iMic
                      Vintage AT Power Supplies - Selecting Capacitors
                      by iMic
                      Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
                      The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
                      02-19-2023, 06:45 PM
                    • PantherDave
                      by PantherDave
                      Hi all!
                      05-29-2024, 02:01 PM
                    • istvanszasz99
                      Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                      by istvanszasz99
                      Product ID: RZ09-0421
                      Motherboard: CH580
                      Bios File Size: 32,768 KB
                      Dear Forum Readers!
                      !!! MY RAZER BLADE...
                      11-24-2025, 05:52 PM
