LG 32lc46 totaly dead
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    hi new to the forum today feel bad already asking for help but here goes.
    i picked up a lg 32lc46 up from my local freecycle site (even came in original box with stand remote and power lead) the person said when i collected it she had a quote and its a power supply issue? so today i replaced all the caps all 19 of them ( used panisonic i think) just in case and guess what still as dead as a dodo lol as in no power leds nothing. i checked to see if i have 240 volts at the 5 amp on board fuse i do. so i now need your help fault finding i have resoldered any bad joints i could find using a x30 maginfiying lamp nothing remotly looks burnt or has any holes blew in it so can anyone help me with fault finding i only have a auto ranging multimeter no scope so can you help step by step with voltages to test etc and where to place the test probes correctly when testing etc i have the board out at the minute. the board number is EAX318450201/13 REV 1.2 cant upload any pics at the minute due to lending camera out to relative on holiday.
    Re: LG 32lc46 totaly dead
    Those two black capacitors - check that you get 160 - 320V across them. Are you in US or UK?
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      thanks for your reply iam in the uk right so i check the 2 largest caps in the power supply ie black multi meter lead on cap neg red on cap poss set multi meter on ac volts correct? cheers
      • randtek
        • Oct 2011
        • 280
        • US
        Should be DC volts, not AC.
          Yes in the UK you should see 310 - 350V across those caps.
          If you get that check the standby voltage - as you can't take pics look for anything labelled "STBY" e.g. 5VSTBY.
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            cheers guys just going to test now on dc volts report back in a min
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              yes 338 volt dc each now where to test the other voltage you mentioned do i put neg lead to a chassis screw on the power supply other on 5 volt test point?
              found 2x st5v on a socket will test them now
              yes just checked both have 5 volts says p201 on plug socket
              any other ideas to check next
              just check socket p202
              19v 0 volts
              19v 0 volts
              gnd
              gnd
              6v 0 volts
              gnd
              3.4 0 volts
              gnd
              12v 0 volts
              gnd
              a bit more testing done top right middle in the pic i posted theres a white socket p204 wires go to invertor board marked 24 volts on 5 seperate pins no voltage to them is this because i cant get it to come out of standby?
              • randtek
                • Oct 2011
                • 280
                • US
                Yes, you won't get those voltages until the power supply turns on. Look for a pin on the power to main board connector labeled PS-ON. Try connecting that pin to the 5v line through a 1k ohm resistor. See if your power supply turns on, and all voltages come up. (You should probably disconnect the power connector at the main board before doing this.)
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  found a pin that says on off right next to 5 volt pin just got to find a 1 k resistor now
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    just done that now and ps does not start my 5 volts i had before adding this load has gone down to 3 volts? with resistor as a load
                    edit a question should i be testing this with just the mains connected to the board all other connectors disconnected ie one goes to invertors 2 go to the other board.
                      No need for load - this tells us all we need to know.
                      With this pull up resistor what is voltage across those big caps? Should be around 380 - 420V.
                      On the heatsink on the secondary side there are some devices. These are probably diodes. Check all the pins for shorts (<0.1V on diode test.)
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        both read 344 volts 2 different dmms
                        will test all the devices on the heat sinks on secondary side now
                        just checked all 7 none seem short at in tested in circuit not removed.
                          Hmm, did it increase from 338V? Could just be mains voltage fluctuations. Pretty common.
                          The fact that the PFC didn't start up is important, but more important is why the rails aren't there. Even with bad PFC there should be some voltage. The PFC might not be starting up because it is powered from the main rails in some way, but I'm not certain.
                          Listen carefully to the power supply. Do you hear a faint ticking sound when you attempt to turn the power supply on with the resistor?
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            • uk
                            yes increased by 6 volts under load just edited my last post no ticking what so ever under load or with all connectors on
                            on the connector i am placing the resistor load on it says
                            adc
                            on/off
                            st/5v
                            gnd
                            i-c
                            err
                            i-b
                            st/5v
                            gnd
                            dim
                            6v
                            gnd
                            3.4 on
                            i have been placing the load between on/off and the st/5v
                            is this correct?
                              Okay - no shorts.
                              Here's where a picture would be helpful. On the board there's likely to be a controller IC. I would highlight it if you have a picture of the back side of the power supply.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                see my above post please i will look at board now and get back to you how big is this chip on primary or secondary side? of board
                                primary side are these 5501a_id07725 8 legged
                                0001-h26 8 legged
                                location u101 cant read 8 legged
                                secondary side 62t03gh
                                725504 diode?
                                u3037m
                                705523
                                does this help? can i get a diagram to get part numbers values etc
                                  Good pictures of the connectors, so we see the labels on them, good closed up of the bottom side and top side of the board, also closed up of all 1/4 section of the board.
                                  That will help a lot if we need to trace out the copper traces.
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    usually when there are no rail voltages, the controller is bad?
                                      Here are the service manuals, one of these should match your chassis.
                                      http://elektrotanya.com/?q=showresul...oria=&kat2=all
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        could someone help me find the controller ic part number can this item be tested using a dmm?
                                        will post pics up but leant camera out as in first post wont get back untill monday.
                                        • Acnologia
                                          Lenovo Thinkpad E15 Gen 2 NM-D011 - No display ? External , yes!
                                          by Acnologia
                                          Here is a pretty crazy one.
                                          Step 1.
                                          Laptop was brought to me as dead not working. Removed everything , cleared everything.
                                          Step 2.
                                          Some liquid damage close to the Type - C connector, and the connector even though it was cleaned wasn't charging the battery . Removed the Type-C port, and replaced it. Now the laptop turns on and charges battery. Shows external screen , not internal.
                                          Step 3.
                                          Took out the screen and checked it to a secondary Gen 2 i have, screen works like a charm.
                                          Step 4.
                                          Lets ,dive into the board. I see the edp cable on the...
                                          05-07-2025, 07:16 AM
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • hoarderteks_kyriakos
                                          Dell Latitude E5570 - No display, turns off after a minute of pressing the power button.
                                          by hoarderteks_kyriakos
                                          Hello.
                                          Yesterday my mother encountered a problem with her laptop, which led to it not turning on and expressing the behaviour mentioned in the title (you press the power button and then it turns off after a minute)
                                          Here is what happened:
                                          At one point i was fixing a setting on the laptop to make the laptop properly recognize the NVMe drive i put in months ago. All worked until all of a sudden the computer blue screened. The screen said it would reboot, but it never did. So she held down the power button, powering it off. Pressing it again, the screen briefly turned...
                                          10-08-2025, 07:33 AM
                                        • disorder
                                          ps5 edm-033 dead after hdmi/usb ports destroyed
                                          by disorder
                                          hello guys,
                                          i need help to repair a edm-033 ps2
                                          history : as always hdmi port and usb ports destroyed after unplugged
                                          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                          so i changed it
                                          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                          i don't see any projection of liquid metal on pcb.
                                          01-14-2025, 12:48 PM
                                        • eastcoastcomputing
                                          Lenovo Legion7 16ACHg6 no post
                                          by eastcoastcomputing
                                          Hi there, I need help with the diagnostic on this board (NM-D563 Rev2.0).
                                          I could not find schematics nor boardview for it.
                                          The laptop was working, playing game when it suddenly crashed. Thermal paste is good and fans are clean. Since then, when power gets plugged in the laptop tries to come on (led lights light up, on off button lights up CPU and GPU warm up) for a minute or so before shutting down. No Display, no beeps no flashing led
                                          There's no liquid damage. I've checked the board under the microscope and can't find any damaged components. I've checked...
                                          06-24-2025, 04:26 AM
