LG 32lc46 totaly dead
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    #41
    Re: LG 32lc46 totaly dead
    explaine please what multi meter setting i need it on?
      Since the PFC Voltage boost did not make the Voltage on the Main DC filter go up, Iwould like to contentrate onthe PFC circuts as hown in the PDF, Iwould like to get the P/N of the U800? and a good close up picture in the red area, there should be a switched transistor that is turn on to supply the VCC to the PFC IC when the PS_ON is present. Please see PDF. If I uderstan you correctly the DC voltage on the two large balck eletrolytics caps (450vdc rating) in the primary side stay at 340vdc with the TV on or off?
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        #43
        yes the voltage stays roughly the same across the 2 caps tv on or off
        U800 IS A
        5501A
        1DO7725
        sorry cant get more pics at the minute my mate took them but will do as soon as i can
        is there anything else i need to check for you?
          Yes two caps are connected in parallel.
          U800 IS A
          5501A
          1DO7725
          These numbers doess not sound right, I need to Goolge it tonight.
            OK, I found the spec for the PFC IC P/N 5501A, we need to check the VCC pin
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #46
              boost diode part number is FSU10A60 mosfet for pfc is W20NM60
              can i check the U800 as i only have a dmm is so where do i test and what settings does the multimeter go on?
                You will be working in the AC primary side of the circuits which can be fatal, so be careful not to touch anything with your body, place the black probe of the DC meter to the neagative leg of one of the two large caps, this is the circuit ground point of the primay dc circuits, do not confuse this with the primary AC safety ground, the red probe will be on pin 8 of U800. Turn the power swithc of the TV to on and see if you get DC reading on this pin 8. I will need to get your good pictures later to find out who generate the VCC for pin 8 of this IC.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  #48
                  right will check this out for you tomorrow morning for you should be able to get pics as well for you will post readings up. cheers guys for your help.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    #49
                    well just done the test as you suggested and guess what 0 VOLTS will pop up to my mates in a bit to get better pics of that area you have outlined.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      #50
                      pics as requested
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        #51
                        U502 is a KA78L 15AZ HI3 transistor
                        U500 is a ICE 3B 1565J
                          OK, looks like we are getting some where here, I will download your latest pictures and try to figure out where pin 8 of this U800 is connected to, it will not be easy since the board is not front of me to Ohm out the connection, you may have to do some probing for me.
                          I think it will be connected to one leg of the transistor close by, this transistor will act like a switch with one leg (more likely to be the Collector) connected the standby power supply extra DC supply, this transistor will turn on when the PS_ON is received.
                          The standby power supply transformer should have 3 winding on it, one is the primary drive winding, the second one is for the 5Vdc standby supply, the third (for 10~12vdc supply, this is not the same 12Vdc generated by the 12v/24v power supply) will be for self sustain of the standby power supply once the kick start is done, this voltage will be used for the PFC IC. I hope I am not confusing you on how the TV works.
                            OK, I look at the pictures, please see the PDF, you need to check the DC voltages as shown, you will be working on the HOT (LINE) side of the power supply and it is LETHAL, so take good precaution! You will have to connect the board back in place. You can solder some wires to those test points so you can take easier measurement, just make sure the wires will not touch ANYTHING else.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #54
                              2f is wrote on that trasistor you cant read which earth point do i use? i will solder wires on it will be safer and easier for me.
                                Use one of the negative terminals of the two big capacitors for ground.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  #56
                                  cheers tom66
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    #57
                                    well guys it one of them days remember your words of wisdom test carfully as its the hot side well all was going well i soldered the wires on ready to test and relplaced the board in the set but i did not see as i plugged the mains lead in it had moved one of the wires and guess what it was touching the chassis so i have found one item defently short circuit says 639 uf1007 a diode but after replaced this and the fuse before i tested it again i read across the live and nuteral pins on the board by the fuse holder got a short circuit reading tested all items have now found a D3SRA60 device connect to a heat sink
                                    it has four pins from left to right + squigly line squigly line - tested this out of circuit on the 2 squigly lines and - sign it reads short circuit in all directions so guess i need one of these before i can do more testing so guys any idea where i can get one from in the uk?
                                    and yes leson learnt by me dont rush these jobs check and double check before plugging in.
                                      well guys it one of them days remember your words of wisdom test carfully as its the hot side well all was going well i soldered the wires on ready to test and relplaced the board in the set but i did not see as i plugged the mains lead in it had moved one of the wires and guess what it was touching the chassis so i have found one item defently short circuit says 639 uf100f a diode but after replaced this and the fuse before i tested it again i read across the live and nuteral pins on the board by the fuse holder got a short circuit reading tested all items have now found a D3SRA60 device connect to a heat sink
                                      Do you have a picture of the component that was damaged?
                                      I have done this before. Twice, on the same board. It only blew the fuse twice, nothing else was damaged. That was lucky.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        #59
                                        well we all by our own mistakes sods law it cost money though
                                        best pic i could take it a D3SRA60 device connected to a heat sink
                                          That's a bridge rectifier. It can be replaced with a 600V 4A device, such as GBU4J.
                                          • Acnologia
                                            Lenovo Thinkpad E15 Gen 2 NM-D011 - No display ? External , yes!
                                            by Acnologia
                                            Here is a pretty crazy one.
                                            Step 1.
                                            Laptop was brought to me as dead not working. Removed everything , cleared everything.
                                            Step 2.
                                            Some liquid damage close to the Type - C connector, and the connector even though it was cleaned wasn't charging the battery . Removed the Type-C port, and replaced it. Now the laptop turns on and charges battery. Shows external screen , not internal.
                                            Step 3.
                                            Took out the screen and checked it to a secondary Gen 2 i have, screen works like a charm.
                                            Step 4.
                                            Lets ,dive into the board. I see the edp cable on the...
                                            05-07-2025, 07:16 AM
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                          • hoarderteks_kyriakos
                                            Dell Latitude E5570 - No display, turns off after a minute of pressing the power button.
                                            by hoarderteks_kyriakos
                                            Hello.
                                            Yesterday my mother encountered a problem with her laptop, which led to it not turning on and expressing the behaviour mentioned in the title (you press the power button and then it turns off after a minute)
                                            Here is what happened:
                                            At one point i was fixing a setting on the laptop to make the laptop properly recognize the NVMe drive i put in months ago. All worked until all of a sudden the computer blue screened. The screen said it would reboot, but it never did. So she held down the power button, powering it off. Pressing it again, the screen briefly turned...
                                            10-08-2025, 07:33 AM
                                          • disorder
                                            ps5 edm-033 dead after hdmi/usb ports destroyed
                                            by disorder
                                            hello guys,
                                            i need help to repair a edm-033 ps2
                                            history : as always hdmi port and usb ports destroyed after unplugged
                                            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                            so i changed it
                                            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                            i don't see any projection of liquid metal on pcb.
                                            01-14-2025, 12:48 PM
                                          • eastcoastcomputing
                                            Lenovo Legion7 16ACHg6 no post
                                            by eastcoastcomputing
                                            Hi there, I need help with the diagnostic on this board (NM-D563 Rev2.0).
                                            I could not find schematics nor boardview for it.
                                            The laptop was working, playing game when it suddenly crashed. Thermal paste is good and fans are clean. Since then, when power gets plugged in the laptop tries to come on (led lights light up, on off button lights up CPU and GPU warm up) for a minute or so before shutting down. No Display, no beeps no flashing led
                                            There's no liquid damage. I've checked the board under the microscope and can't find any damaged components. I've checked...
                                            06-24-2025, 04:26 AM
